Clientless VPN works internally but NOT externally! Help please!
Achilleas
I setup my Clientsless VPN on a ASA Firewall 5510 and when accessing it internally (using the firewall's internall IP address) it displays fine.
But when I entering the externall IP address from home e.g. https://232.14.14.14/  it gives you the choise to procceed or not and wjen i choose it is a secure page in order to procceed then I get the following message:
Under Construction
The site you are trying to view does not currently have a default page. It may be in the process of being upgraded and configured.
Please try this site again later. If you still experience the problem, try contacting the Web site administrator.
If you are the Web site administrator and feel you have received this message in error, please see "Enabling and Disabling Dynamic Content" in IIS Help.
To access IIS Help
  1. Click Start, and then click Run.
  2. In the Open text box, type inetmgr. IIS Manager appears.
  3. From the Help menu, click Help Topics.
  4. Click Internet Information Services.
Any ideas please???
Awesome, thanks!!
Now, you have two options:
1- Remove the static translation or change it to a different port:
no static (inside,outside) tcp interface https Firewall5510_Server https netmask 255.255.255.255
2- Change the WebVPN port to something else:
webvpn
     no enable outside
     port 8443
     enable outside
So when you connect, you go to: https://1.1.1.1:8443
HTH.
Portu.
7 Replies 7
Hi Achilleas,
It looks like you have a port-forwarding to an internal IIS server on port 443.
Please issue a "show run nat" on your ASA and look for any static translation pointing to 443.
You could share the output here, I'll be glad to check it out for you.
HTH.
Portu.
Please rate any helpful posts.
That's the output:
Firewall5510# show run nat
nat (inside) 0 access-list inside_outbound_nat0_acl
nat (inside) 1 0.0.0.0 0.0.0.0
Firewall5510#
any suggestions?
Please share the "show run static", I thought the ASA was running 8.3 +.
Thanks.
Portu.
Firewall5510# show run static
static (inside,outside) tcp interface 3389 Firewall5510_Server 3389 netmask 255.255.255.255
static (inside,outside) tcp interface smtp Firewall5510_Server smtp netmask 255.255.255.255
static (inside,outside) tcp interface ftp Firewall5510_Server ftp netmask 255.255.255.255
static (inside,outside) tcp interface 465 Firewall5510_Server 465 netmask 255.255.255.255
static (inside,outside) tcp interface www Firewall5510_Server www netmask 255.255.255.255
Firewall5510#
Awesome, thanks!!
webvpn
     no enable outside
     port 8443
     enable outside
HTH.
Portu.
Hi Javier,
I tried option 1 and it didn't work.
But with option 2 works fine!
Thank you very much for your help, I really appreciate your help.
Many Thanks,
Achilleas.
Awesome!!
Have a nice day
