Configuring a VPN solution over a DHCP enabled ISP connection
JeremiasTR
Greetings,
I am requesting assistance from the engineering community implementing a VPN solution within my business environment. I have attached the topology for your review. Essentially what I am trying to implement is a secure VPN solution using cryptographic encryption (AES 256) with (2) 3945 Cisco routers over a DHCP enabled ISP. These routers have a licensed securityK9 configuration.
Router1/Router2
Username (username) password secret 5 (password)
Crypto isakmp policy 1
Encryption aes256
Authentication pre-share
Group 2
Lifetime 480
Crypto isakmp client configuration
Key secret password
Domain (domain)
Crypto ipsec transform-set vpn1 esp-aes 256 esp-aes-hmac
Crypto ipsec secrutiy-association lifetime seconds 86400
Crypto dynamic-map dynmap 1
Set transform-set vpn1
Reverse-route
crypto map static-map 1 ipsec-isakmp dynamic dynmap
crypto map dynmap isakmp authorization list rtr-remote
crypto map dynmap client configuration address respond
crypto ipsec client ezvpn ezvpnclientconnect auto
group 2 key secret-passwordmode client
peer (public DHCP IP)
crypto ipsec client ezvpn ezvpnclient outsidecrypto map static-map!
int gi0/0
ip add DHCP
no shut
interface tunnel 100
ip address (a private business address)
tunnel source gi0/0
tunnel destination (whatever IP that Router 2 receives from its ISP modem, which is a public IP address)
no shut
Any assistance would be greatly appreciated. Thank you and have a great night.
0 Replies 0
