Connection denied to reverse path failure.
I have an old ASA 5505 and I have configured a remote access VPN to work with Cisco anyconnect.
It was working fine until I wanted to use our VOIP line through the VPN.
My softphone is not connecting and I went to check the firewall logs to find this message.
5Aug 26 202015:26:5730501310.69.11.24355448192.168.254.225060Asymmetric NAT rules matched for forward and reverse flows; Connection for udp src OUTSIDE:10.69.11.243/55448(LOCAL\cayyzalbe) dst INSIDE:192.168.254.22/5060 denied due to NAT reverse path failure
I'm not really good in VPN, I have setup that one using online tutorial.
Thank you.
15 Replies 15
I'm connecting throug ASDM 7.3.
Here is the file.
