Connection problem of IP-Sec VPN between Cisco router and checkpoint R80.10 version
Naive
Hello Guys,
I am unable to contact cisco router and Firewall. getting error: %CRYPTO-4-RECVD_PKT_NOT_IPSEC: Rec'd packet not an IPSEC packet. (ip) vrf/dest_addr= /160.1.1.1, src_addr= 150.1.1.1, prot= 1.
I saw packets are not getting decrypted....
Below are ISAKMP and IPSEC configuration:
vIOS-PK-02#show crypto isakmp sa
IPv4 Crypto ISAKMP SA
dst             src             state          conn-id status
136.1.122.2     136.1.122.12    QM_IDLE           1009 ACTIVE
vIOS-PK-02#show crypto ipsec sa
interface: GigabitEthernet0/0
    Crypto map tag: vpn_map, local addr 136.1.122.2
   protected vrf: (none)
   local  ident (addr/mask/prot/port): (160.1.1.0/255.255.255.0/0/0)
   remote ident (addr/mask/prot/port): (150.1.1.0/255.255.255.0/0/0)
   current_peer 136.1.122.12 port 500
     PERMIT, flags={origin_is_acl,}
    #pkts encaps: 4, #pkts encrypt: 4, #pkts digest: 4
    #pkts decaps: 0, #pkts decrypt: 0, #pkts verify: 0
    #pkts compressed: 0, #pkts decompressed: 0
    #pkts not compressed: 0, #pkts compr. failed: 0
    #pkts not decompressed: 0, #pkts decompress failed: 0
    #send errors 0, #recv errors 0
     local crypto endpt.: 136.1.122.2, remote crypto endpt.: 136.1.122.12
     plaintext mtu 1446, path mtu 1500, ip mtu 1500, ip mtu idb GigabitEthernet0/0
     current outbound spi: 0x3019AB24(806988580)
     PFS (Y/N): N, DH group: none
     inbound esp sas:
      spi: 0xAAE08B57(2866842455)
        transform: esp-3des esp-md5-hmac ,
        in use settings ={Tunnel, }
        conn id: 13, flow_id: SW:13, sibling_flags 80004040, crypto map: vpn_map
        sa timing: remaining key lifetime (k/sec): (4358849/2907)
        IV size: 8 bytes
        replay detection support: Y
        Status: ACTIVE(ACTIVE)
     inbound ah sas:
     inbound pcp sas:
     outbound esp sas:
        conn id: 14, flow_id: SW:14, sibling_flags 80004040, crypto map: vpn_map
        sa timing: remaining key lifetime (k/sec): (4358848/2907)
        IV size: 8 bytes
     outbound ah sas:
     outbound pcp sas:
Mark Elsen
 - Check this document for guidelines as how to configure vpn between the router and checkpoint :
       https://www.cisco.com/c/en/us/support/docs/security/ios-easy-vpn/23784-ipsec-checkpt.html
 M.
@Naiveit looks like your router is encrypting the traffic...
...but nothing is being decrypted.
Can you check the configuration of the remote CheckPoint firewall and confirm they are not unintentially natting the traffic.
