dialup ipsec issues - IKE packet from x.x.x.x was not encrypted
lewplagoop
Hi all,
im configuring a dial up vpn between a cisco (dynamic) and a fortigate (static) but having issues getting it to work.
cisco is having issues with the return traffic saying that its not encrypted see below configs and logs.
Cisco Config
version 15.9
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
license udi pid C927-4P sn FGL2542L5AC
redundancy
controller VDSL 0
crypto isakmp policy 1
encr aes 256
hash sha256
authentication pre-share
group 2
lifetime 28800
crypto isakmp peer address remote peer
set aggressive-mode password supersecretpassword
set aggressive-mode client-endpoint fqdn local
crypto ipsec transform-set ok esp-aes 256 esp-sha256-hmac
mode tunnel
crypto map CMAP 10 ipsec-isakmp
set peer "remotepeer"
set transform-set ok
match address VPN-Encrpytion-Domain
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
interface Ethernet0
no ip address
shutdown
interface GigabitEthernet0
no ip address
interface GigabitEthernet1
no ip address
interface GigabitEthernet2
no ip address
interface GigabitEthernet3
switchport access vlan 10
switchport mode access
no ip address
interface GigabitEthernet4
ip address 192.168.202.1 255.255.255.0
duplex auto
speed auto
crypto map CMAP
interface Vlan1
no ip address
interface Vlan10
ip address 10.10.10.10 255.255.255.0
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.202.99
ip access-list extended VPN-Encrpytion-Domain
permit ip 10.10.10.0 0.0.0.255 any
tftp-server flash:/firmware/vadsl_module_img.bin
control-plane
line con 0
line vty 0 4
login
transport input none
scheduler allocate 20000 1000
end
fortigate config
config vpn ipsec phase1-interface
edit "TEST-xx-Site"
set type dynamic
set interface "wan1"
set keylife 28800
set mode aggressive
set peertype one
set net-device disable
set proposal aes256-sha256
set dhgrp 14 5 2
set peerid "local"
set psksecret ENC D4y3ZHLdOlinqKO3y8yaZEkivaxEDg6CR5t/DLJHBkFA31T0DFHxcnCtbTyRv8TIeMiyn08Wo5MTtJnclY/4XL9+8GfkOSuMHQYY1N5ZpiRmypli5/b5O+0e/jxMBw4MO5tyFkuA3xp3DvDqUrMR7t+TZxFHlFKQb2kOH+Q95BF79zPaqqUJ40w0TaBy06kcnI9p+FlmMjY3dkVA
next
end
edit "test"
set phase1name "TEST-BHF-Site"
set dhgrp 14 5 2
set keylifeseconds 3600
next
config firewall policy
edit 6
set name "test"
set uuid 5ea0a3b4-37de-51f0-904a-bc7cbf141bf8
set srcintf "TEST-xx-Site"
set dstintf "internal5"
set action accept
set srcaddr "all"
set dstaddr "all"
set schedule "always"
set service "ALL"
next
config router static
edit 11
set dst 10.10.10.0 255.255.255.0
set device "TEST-xx-Site"
next
end
Cisco shows the following
*May 27 14:05:44.615: %CRYPTO-6-IKMP_MODE_FAILURE: Processing of Aggressive mode failed with peer at x.x.x.x..
*May 27 14:05:47.711: %CRYPTO-6-IKMP_NOT_ENCRYPTED: IKE packet from x.x.x.x was not encrypted and it should've been....
fortigate logs
2025-05-27 14:37:15.561592 ike V=root:0: comes x.x.x.x:39554->x.x.x.x:500,ifindex=5,vrf=0,len=385....
2025-05-27 14:37:15.561693 ike V=root:0: IKEv1 exchange=Aggressive id=e587e69616f86626/0000000000000000 len=385 vrf=0
2025-05-27 14:37:15.561734 ike 0: in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
2025-05-27 14:37:15.561821 ike V=root:0:e587e69616f86626/0000000000000000:363: responder: aggressive mode get 1st message...
2025-05-27 14:37:15.561872 ike V=root:0:e587e69616f86626/0000000000000000:363: VID RFC 3947 4A131C81070358455C5728F20E95452F
2025-05-27 14:37:15.561917 ike V=root:0:e587e69616f86626/0000000000000000:363: VID draft-ietf-ipsec-nat-t-ike-07 439B59F8BA676C4C7737AE22EAB8F582
2025-05-27 14:37:15.561963 ike V=root:0:e587e69616f86626/0000000000000000:363: VID draft-ietf-ipsec-nat-t-ike-03 7D9419A65310CA6F2C179D9215529D56
2025-05-27 14:37:15.562008 ike V=root:0:e587e69616f86626/0000000000000000:363: VID draft-ietf-ipsec-nat-t-ike-02\n 90CB80913EBB696E086381B5EC427B1F
2025-05-27 14:37:15.562056 ike V=root:0:e587e69616f86626/0000000000000000:363: VID DPD AFCAD71368A1F1C96B8696FC77570100
2025-05-27 14:37:15.562100 ike V=root:0:e587e69616f86626/0000000000000000:363: VID draft-ietf-ipsra-isakmp-xauth-06.txt 09002689DFD6B712
2025-05-27 14:37:15.562145 ike V=root:0:e587e69616f86626/0000000000000000:363: VID unknown (16): 1040418B16F966264658C4D431E5A0DF
2025-05-27 14:37:15.562180 ike V=root:0::363: received peer identifier FQDN 'local'
2025-05-27 14:37:15.562238 ike V=root:0: IKEv1 Aggressive, comes x.x.x.x:39554->x.x.x.x
2025-05-27 14:37:15.562300 ike V=root:0:e587e69616f86626/0000000000000000:363: negotiation result
2025-05-27 14:37:15.562344 ike V=root:0:e587e69616f86626/0000000000000000:363: proposal id = 1:
2025-05-27 14:37:15.562376 ike V=root:0:e587e69616f86626/0000000000000000:363: protocol id = ISAKMP:
2025-05-27 14:37:15.562408 ike V=root:0:e587e69616f86626/0000000000000000:363: trans_id = KEY_IKE.
2025-05-27 14:37:15.562440 ike V=root:0:e587e69616f86626/0000000000000000:363: encapsulation = IKE/none
2025-05-27 14:37:15.562472 ike V=root:0:e587e69616f86626/0000000000000000:363: type=OAKLEY_ENCRYPT_ALG, val=AES_CBC, key-len=256
2025-05-27 14:37:15.562506 ike V=root:0:e587e69616f86626/0000000000000000:363: type=OAKLEY_HASH_ALG, val=SHA2_256.
2025-05-27 14:37:15.562539 ike V=root:0:e587e69616f86626/0000000000000000:363: type=AUTH_METHOD, val=PRESHARED_KEY.
2025-05-27 14:37:15.562572 ike V=root:0:e587e69616f86626/0000000000000000:363: type=OAKLEY_GROUP, val=MODP1024.
2025-05-27 14:37:15.562604 ike V=root:0:e587e69616f86626/0000000000000000:363: ISAKMP SA lifetime=28800
2025-05-27 14:37:15.562650 ike V=root:0:e587e69616f86626/0000000000000000:363: SA proposal chosen, matched gateway TEST-xx-Site
2025-05-27 14:37:15.562708 ike V=root:0:TEST-xx-Site:TEST-xx-Site: created connection: 0xaff9180 5 x.x.x.x->x.x.x.x:39554.
2025-05-27 14:37:15.562756 ike V=root:0:TEST-xx-Site:363: DPD negotiated
2025-05-27 14:37:15.562791 ike V=root:0:TEST-xx-Site:363: unsupported NAT-T version draft-ietf-ipsec-nat-t-ike-07
2025-05-27 14:37:15.562824 ike V=root:0:TEST-xx-Site:363: selected NAT-T version: RFC 3947
2025-05-27 14:37:15.562874 ike V=root:0:TEST-xx-Site:363: generate DH public value request pending
2025-05-27 14:37:15.562979 ike V=root:0:TEST-xx-Site:363: compute DH shared secret request pending
2025-05-27 14:37:15.563517 ike V=root:0:TEST-xx-Site:363: cookie e587e69616f86626/64b9748d57d8db4d
2025-05-27 14:37:15.563795 ike 0:TEST-xx-Site:363: ISAKMP SA e587e69616f86626/64b9748d57d8db4d key 32:06C5FB48AB0D265E57A4996942AE0FDD9CEF676C021C3AE7EA8102C0EF552771
2025-05-27 14:37:15.563878 ike 0:TEST-xx-Site:363: out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
2025-05-27 14:37:15.564003 ike V=root:0:TEST-xx-Site:363: sent IKE msg (agg_r1send): x.x.x.x:500->x.x.x.x:39554, len=416, vrf=0, id=e587e69616f86626/64b9748d57d8db4d
2025-05-27 14:37:18.570646 ike 0:TEST-xx-Site:363: out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
2025-05-27 14:37:18.570805 ike V=root:0:TEST-xx-Site:363: sent IKE msg (P1_RETRANSMIT): x.x.x.x:500->x.x.x.x:39554, len=416, vrf=0, id=e587e69616f86626/64b9748d57d8db4d
2025-05-27 14:37:19.678723 ike V=root:0: comes x.x.x.x:39554->x.x.x.x:500,ifindex=5,vrf=0,len=385....
2025-05-27 14:37:19.678794 ike V=root:0: IKEv1 exchange=Aggressive id=e587e69616f86626/0000000000000000 len=385 vrf=0
2025-05-27 14:37:19.678834 ike 0: in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
2025-05-27 14:37:19.678920 ike V=root:0:TEST-xx-Site:363: retransmission, re-send last message
2025-05-27 14:37:19.678961 ike 0:TEST-xx-Site:363: out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
Thanks for help in advance.
7 Replies 7
I can't help with the Fortigate config, sorry. However, I've noticed that your crypto ACL applied to the Cisco device has the destination defined as "any". Have you tried to replace the "any" keyword with the specific destination subnet? if not, could you please try that? on the Fortigate the ACL should be mirrored.
lewplagoop
Hi Thanks for the response.
unfortinetly that has not made any differance im still getting the same errors.
and i confirmed the fortigate matches the other end
On the router config snippet it doesn't show any NAT applied to the router, where NAT and NAT exemption are applied?
Hi the Nat is being preformed by a 5G gateway connected directly to the cisco on GE4
debug from the cisco returns the following.
its complaining about the has but these match and saying that the return traffic is no encrypted allmost like it dosnt like the aggressive mode return traffic.
*May 30 08:37:30.331: ISAKMP: (0):peer matches *none* of the profiles
*May 30 08:37:30.331: ISAKMP: (0):processing vendor id payload
*May 30 08:37:30.331: ISAKMP: (0):vendor ID seems Unity/DPD but major 69 mismatch
*May 30 08:37:30.331: ISAKMP: (0):vendor ID is NAT-T RFC 3947
*May 30 08:37:30.331: ISAKMP: (0):SA using tunnel password as pre-shared key.
*May 30 08:37:30.331: ISAKMP: (0):local preshared key found
*May 30 08:37:30.331: ISAKMP: (0):Scanning profiles for xauth ...
*May 30 08:37:30.331: ISAKMP: (0):Checking ISAKMP transform 1 against priority 1 policy
*May 30 08:37:30.331: ISAKMP: (0): encryption AES-CBC
*May 30 08:37:30.331: ISAKMP: (0): keylength of 256
*May 30 08:37:30.331: ISAKMP: (0): hash SHA256
*May 30 08:37:30.331: ISAKMP: (0): default group 2
*May 30 08:37:30.331: ISAKMP: (0): auth pre-share
*May 30 08:37:30.331: ISAKMP: (0): life type in seconds
*May 30 08:37:30.331: ISAKMP: (0): life duration (basic) of 28800
*May 30 08:37:30.331: ISAKMP: (0):atts are acceptable. Next payload is 0
*May 30 08:37:30.331: ISAKMP: (0):Acceptable atts:actual life: 0
*May 30 08:37:30.331: ISAKMP: (0):Acceptable atts:life: 0
*May 30 08:37:30.331: ISAKMP: (0):Basic life_in_seconds:28800
*May 30 08:37:30.331: ISAKMP: (0):Returning Actual lifetime: 28800
*May 30 08:37:30.331: ISAKMP: (0):Started lifetime timer: 28800.
*May 30 08:37:30.331: ISAKMP: (0):processing KE payload. message ID = 0
*May 30 08:37:30.333: ISAKMP: (0):processing NONCE p.ayload. message ID = 0
*May 30 08:37:30.333: ISAKMP: (0):SA using tunnel password as pre-shared key.
*May 30 08:37:30.333: ISAKMP: (1028):processing HASH payload. message ID = 0
*May 30 08:37:30.333: ISAKMP-ERROR: (1028):Hash payload is incorrect!
*May 30 08:37:30.333: ISAKMP-ERROR: (1028):(1028): Unknown Input IKE_MESG_FROM_PEER, IKE_AM_EXCH: state = IKE_I_AM1
*May 30 08:37:30.333: ISAKMP: (1028):Input = IKE_MESG_FROM_PEER, IKE_AM_EXCH
*May 30 08:37:30.333: ISAKMP: (1028):Old State = IKE_I_AM1 New State = IKE_I_AM1
*May 30 08:37:30.333: %CRYPTO-6-IKMP_MODE_FAILURE: Processing of Aggressive mode failed with peer at 185.137.67.65
*May 30 08:37:33.461: ISAKMP-PAK: (1028):received packet from x.x.x.x dport 500 sport 500 Global (I) AG_INIT_EXCH
*May 30 08:37:33.461: %CRYPTO-6-IKMP_NOT_ENCRYPTED: IKE packet from x.x.x.x was not encrypted and it should've been.
*May 30 08:37:33.461: ISAKMP: (1028):: incrementing error counter on sa, attempt 1 of 5: reset_retransmission
*May 30 08:37:34.461: ISAKMP: (1028):retransmitting phase 1 AG_INIT_EXCH...
*May 30 08:37:34.461: ISAKMP: (1028):: incrementing error counter on sa, attempt 2 of 5: retransmit phase 1
*May 30 08:37:34.461: ISAKMP-PAK: (1028):sending packet to x.x.x.x my_port 500 peer_port 500 (I) AG_INIT_EXCH
For the aggressive mode error I think you can replace the "set aggressive-mode client-endpoint" command to use the IP address of the router rather than the FQDN. It would be "set aggressive-mode client-endpoint ipv4-address 192.168.202.1". For NAT, you need to exempt the VPN traffic from being NAT'ed. Have you done that on the 5G gateway?
lewplagoop
Thanks for the feedback.
Ive got it working anyingly i didnt change anything i stripped down the config on both devices and built it back up again and this appears to now be forming the tunnels with no issues.
Thanks again for all your help.
