Difference between PKI and RSA-signatures
abhijith891
Hi all, I believe the 3 authentication methods in a Site-Site VPN are PSK, PKI and RSA-sig. But I am not very clear about how different PKI and RSA Sig mechanisms are from each other. So can someone please explain the difference between same?
Abhijit
Graham Bartlett
RSA-Sig is basically using RSA Nonces(which are only used in IKEv1, not IKEv2), take a look here;
http://www.ciscopress.com/articles/article.asp?p=25474&seqNum=5
In summary you have the peers public key, but this is just the key and not sent in a certificate (like in PKI). So you need to manually configure all peers public keys that you want to talk to. PKI overcomes this limitations by using a CA.
cheers
A Site-to-Site VPN can use either PSK or certificates to authenticate. A certificate is either rsa-sig or ecsda-sig (Suite-B NGE) they are issued by a PKI (aka Certificate Authority). You need a PKI (Public Key Infrastruture) in order to distribute the certificates to use for certificate authentication.
Graham Bartlett
cheers
Thanks a lot Graham. Things are pretty clear now. Cheers.
