DMVPN PROBLEM
julfp
Community Member
Hi...
Im configring the DMVPN, ping between hub and spoke are ok...but some services VNC and REMOTE DESKTOP give me problems...
Starting the VNC from HUB to spoke sucess, but inverse the password is ask to me after the screen dont enter...
The same happens with terminal service....
Configurations in attachments..
Thanks.
jsivulka
Level 10
Level 10
Did you try lowering the MTU. That might work. Another possibility is that the problem is due to bursty traffic and queueing might be required.
d.chevalier
Community Member
On the hub side add:
ip tcp adjust-mss 1400
in your tunnel "definition"
it should resolve your issue.
You may have to do the same on the spoke side.
