DNS Problems on AnyConnect
andrewgarlick
I am using Cisco AnyConnect 2.4.1012.
I have split-tunnelling enabled so home users can use their own Internet - everything works great apart from a DNS problem.
On the internet everything is good.
Local domain is good, resolves all names.
When I ping a machine by name in another domain it comes back with the internet IP however when I ping by IP address it resolves ok.
I have 4 domains - how can I add these so clients can ping by name on othe domains other than the default.
Andy
Jennifer Halim
You can use the split-dns to identify all the internal domains that you have within the group-policy configuration.
Here is the command for your reference:
http://www.cisco.com/en/US/docs/security/asa/asa82/command/reference/s8.html#wp1509524
Hope that helps.
