Double authentication using LDAP and RSA
Greeting all
If i`m using double authentication for my SSL VPN with LDAP as primary and RSA as secondary
does the username has to be the same inLDAP and RSA  or do i have to import users from LDAP to RSA...
how it really works ... i can`t find anything in the Config Guide of Cisco regarding double authentication
Seif
CCIE#26440
Is this authentication for VPN clients?
LDAP is only used for authorization, RSA can authenticate.
Federico.
Hi Federico
I`d like to keep my LDAP for authentication and add RSA for stongest password since i`m using the LDAP to map user to the correct connection profile
Any thoughts?!
Thanks for your reply
Hi Self,
by default when you enable double authentication the login form will have 2 username fields and 2 password fields. You can optionally configure the ASA to omit the second username field (then it will use the same username for both authentications - but I understand this is precisely the opposite of what you want so just use the default).
Alternatively (less secure but more convenient for the user) you could just use single authentication against RSA, and add LDAP authorization. The LDAP group mapping should still work and your users will only need to enter one username and (one-time) password.
hth
Herbert
