GRE tunnel with IPSec - problem, tunnel down
Velimir Filipov
Dear all,
I have a hub and spoke VPN.
Recently the hub was replaced with ISR 3925 with IOS 15.4(3)M1
The spokes are old 851 routers running 12.4 IOS
Now I am facing strange issue.
From time to time it happens that the IPSec SAs (phase 2) to a certain (each time a different) spoke by unknown to me reason disappear from the HUB.
Whenever that happens, the HUB brings down the line protocol of the GRE tunnel (linestate mode reg down) (this behavior wasn't present in the older IOS..).
When that happens, there is no way to bring the tunnel and the phase 2 SAs back up, other than manually:
1) shut/no shut the tunnel
2) clear the isakmp (phase 1) session
I have tried clearing the ipsec sa's (2nd phase), I have tried doing that on the spoke side - nothing happens.
I sniffed the traffic from the hub, and it seems that when that happens (no 2nd phase sa and tunnel goes down), the hub isn't actually trying to create phase 2 ipsec SAs, unless you clear the phase 1 SA..
I think that because the tunnel is down, it wouldn't try to use that tunnel, so that's why it doesn't try to create new SA's - which leads to a paradox..
Is there any way to fix that issue - either make the HUB try to negotiate new phase 2 SAs when it lose them, or make it not bring down the tunnel when that happens?
Any advice would be much appreciated.
Thanks and best regards.
Velimir Filipov
Here is some more information.
HUB#show int tu28
Tunnel28 is up, line protocol is down
  Hardware is Tunnel
  Description: **  SPOKE  **
  Internet address is 10.0.0.117/30
  MTU 17916 bytes, BW 5120 Kbit/sec, DLY 50000 usec,
  Encapsulation TUNNEL, loopback not set
  Keepalive not set
  Tunnel linestate evaluation down - linestate mode reg down
  Tunnel source 1.1.1.2, destination 2.2.2.2
  Tunnel protocol/transport GRE/IP
    Key disabled, sequencing disabled
    Checksumming of packets disabled
  Tunnel TTL 255, Fast tunneling enabled
  Tunnel transport MTU 1476 bytes
  Tunnel transmit bandwidth 8000 (kbps)
  Tunnel receive bandwidth 8000 (kbps)
  Tunnel protection via IPSec (profile "ipsec")
  Last input 01:24:09, output never, output hang never
  Last clearing of "show interface" counters 3w4d
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 4
  Queueing strategy: fifo
  Output queue: 0/0 (size/max)
  30 second input rate 0 bits/sec, 0 packets/sec
  30 second output rate 0 bits/sec, 0 packets/sec
     3905222 packets input, 1150452111 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     3827545 packets output, 2347906608 bytes, 0 underruns
     0 unknown protocol drops
HUB#show tunnel interface tu28
Tunnel28
   Mode:GRE/IP, Destination 2.2.2.2, Source 1.1.1.2
   IP transport: output interface Port-channel1.30 next hop 1.1.1.1
   Application ID 1: unspecified
   OCE: IP tunnel decap
   Provider: interface Tu28, prot 47
     Performs protocol check [47]
     Protocol Handler: GRE: opt 0x0
       ptype: ipv4 [ipv4 dispatcher: drop]
       ptype: ipv6 [ipv6 dispatcher: drop]
       ptype: mpls [mpls dispatcher: drop]
       ptype: otv [mpls dispatcher: drop]
       ptype: generic [mpls dispatcher: drop]
   Linestate - current down
   Internal linestate - current down, evaluated down - linestate mode reg down
   Tunnel Source Flags: Local
   Transport IPv4 Header DF bit cleared
HUB#show crypto ipsec sa interface Tunnel28
interface: Tunnel28
    Crypto map tag: Tunnel28-head-0, local addr 1.1.1.2
   protected vrf: vpn
   local  ident (addr/mask/prot/port): (1.1.1.2/255.255.255.255/47/0)
   remote ident (addr/mask/prot/port): (2.2.2.2/255.255.255.255/47/0)
   current_peer 2.2.2.2 port 500
     PERMIT, flags={origin_is_acl,ipsec_sa_request_sent}
    #pkts encaps: 2441779, #pkts encrypt: 2441779, #pkts digest: 2441779
    #pkts decaps: 2347707, #pkts decrypt: 2347707, #pkts verify: 2347707
    #pkts compressed: 0, #pkts decompressed: 0
    #pkts not compressed: 0, #pkts compr. failed: 0
    #pkts not decompressed: 0, #pkts decompress failed: 0
    #send errors 1, #recv errors 0
     local crypto endpt.: 1.1.1.2, remote crypto endpt.: 2.2.2.2
     plaintext mtu 1446, path mtu 1500, ip mtu 1500, ip mtu idb Port-channel1.30
     current outbound spi: 0x0(0)
     PFS (Y/N): N, DH group: none
     inbound esp sas:
     inbound ah sas:
     inbound pcp sas:
     outbound esp sas:
     outbound ah sas:
     outbound pcp sas:
HUB#show crypto isakmp sa | i 2.2.2.2
2.2.2.2   1.1.1.2    QM_IDLE          16169 ACTIVE
And then
HUB#clear crypto isakmp 16169
and after few secs everything came back up..
Here is the config of the Tunnel interface
HUB#show run int tu28
Building configuration...
Current configuration : 349 bytes
interface Tunnel28
 description **  SPOKE  **
 bandwidth 5120
 ip vrf forwarding vpn
 ip address 10.0.0.117 255.255.255.252
 ip mtu 1442
 ip tcp adjust-mss 1300
 load-interval 30
 tunnel source 1.1.1.2
 tunnel destination 2.2.2.2
 tunnel protection ipsec profile ipsec
 crypto ipsec df-bit clear
 service-policy output vpn-out
end
I have tried putting keepalives, but it didn't bring up the tunnel..
A post in this discussion has been removed due to possible misconduct. Please refer to the CSC terms of use for more details. - See more at: https://supportforums.cisco.com/discussion/12504546/setting-qos-sg300-series-ip-phones#sthash.K717soSy.dpuf
Velimir Filipov
anyone ?
any result to this? i am having same problem. thanks
