Help modifing a simple Lua DAP query
naim.cote
Hello I need help with something I can't figure out.
We currently have the following LUA script ( found in the Cisco DAP examples)
This rule allows a vpn client to connect if any AV software is installed, this is fine for PC and Mac, but now have users conneting from iOS device where no AV is running and we want to allow them in our exsiting LUA script.
assert(function()
    for k,v in pairs(endpoint.av) do
         if (EVAL(v.exists, "EQ", "true", "string")) then
              return true
         end
    end
    return false
end)()
We'd like to modify this simple script to allow any antivirus or any iOS based device.
I need to put in an OR  if (EVAL(endpoint.os.version, "EQ", "Apple Plugin", "string") then return true.
But in all honesty I don't have the skills to make it work.
Naim
0 Replies 0
