Help with Remote VPN
Ben Sebborn
We have a Remote IPSec VPN setup on our Cisco ASA 5505.
This allows a connection, however when we try and route traffic for our internal network, plus a set of external IPs, we get the traffic blocked for VPN users.
I am presuming this is either an ACL or NAT issue but I'm not sure exactly.
I have created the following:
access-list skiddlevpn_splitTunnelAcl standard permit 192.168.2.0 255.255.255.0
access-list skiddlevpn_splitTunnelAcl standard permit 164.177.132.16 255.255.255.252
access-list skiddlevpn_splitTunnelAcl standard permit 164.177.128.200 255.255.255.25
I have also noticed that the DHCP pool we use for VPN clients is overlapping with our internal network:
ip local pool CiscoVPNDHCPPool 192.168.2.130-192.168.2.149 mask 255.255.255.0
This has worked before, but perhaps I'm now missing something?
I have noticed a few errors such as this, which I'm not sure if they are connected:
%ASA-5-305013: Asymmetric NAT rules matched for forward and reverse flows; Connection for udp src outside:192.168.2.130/54762 dst inside:OfficeWindowsServer/53 denied due to NAT reverse path failure
9 Replies 9
Ben Sebborn
I have now reconfigured this so the VPN DHCP pool does not overlap
address-pools value RemoteVPNPool
ip local pool RemoteVPNPool 192.168.4.1-192.168.4.254 mask 255.255.255.0
However, still no joy. I wonder i there's an issue because we use a gateway on our outside interface (192.168.3.1) - do I need to set this up for the VPN traffic?
route publicinternet 0.0.0.0 0.0.0.0 192.168.3.1 1
Are you sure this is the current config and it was in place when this log appeared?
In your config the interface names are
publicinternet and officenetwork
and  not inside and outside.
Do you still have such error messages with the above config?
Note: the pool is called 'VPN address pool' and not 'DHCP pool'. DHCP protocol is not used between VPN client and firewall.
Hi Peter
I've just updated the running config in the first post with the current info.
I'm not sure if we're getting that exact error I will need to check. The last time I tested the VPN, we were able to connect to non-tunnelled networks (the internet, etc) fine, but anthing defined in the tunnel was timing out.
Many thanks
Can anyone help with the above?
Many thanks
Not sure I am 100% clear on the issue but would be worth trying to add a route.
route officenetwork 0.0.0.0 0.0.0.0 xxx.xxx.xxx.xxx tunneled    (xxx.xxx..xxx.xxx = Next hop
If I try to add another route, I get the following:
Result of the command: "route officenetwork 0.0.0.0 0.0.0.0 192.168.3.1 tunneled"
ERROR: ERROR: Tunnel default gateway specified exists in route table.
ERROR: Cannot add route entry, possible conflict with existing routes
Result of the command: "show route"
Gateway of last resort is 192.168.3.1 to network 0.0.0.0
C    192.168.2.0 255.255.255.0 is directly connected, officenetwork
C    192.168.3.0 255.255.255.0 is directly connected, publicinternet
S*   0.0.0.0 0.0.0.0 [1/0] via 192.168.3.1, publicinternet
Hello Ben,
If you use a address pool using a network tnat is not local to the ASA it makes the routing more difficult.  I understand you had an overlap but for testing edit the pool that worlked before
(ip local pool CiscoVPNDHCPPool 192.168.2.130-192.168.2.149 mask 255.255.255.0)   This network is local because the inside interface or in your case the officenetwork.
Does this 192.168.4.x  newtork exist downstream from your ASA ?
I have now changed the pool, as below:
ip local pool CiscoVPNDHCPPool 192.168.2.33-192.168.2.62 mask 255.255.255.224
group-policy skiddlevpn attributes
dns-server value 192.168.2.199
vpn-tunnel-protocol IPSec
split-tunnel-policy tunnelspecified
split-tunnel-network-list value skiddlevpn_splitTunnelAcl
default-domain value skiddle.internal
split-dns value skiddle.internal
address-pools value CiscoVPNDHCPPool
We can now ping the ASA, however if we ping a device locally on the network:
5Nov 28 201313:57:44305013192.168.2.33
OfficeWindowsServer
Asymmetric NAT rules matched for forward and reverse flows; Connection for icmp src publicinternet:192.168.2.33 dst officenetwork:OfficeWindowsServer (type 8, code 0)denied due to NAT reverse path failure
If we try to access an external server, which is included in our tunnel group:
6Nov 28 201313:56:24302014192.168.2.331401164.177.132.1980Teardown TCP connection 1562997 for publicinternet:192.168.2.33/1401 to publicinternet:164.177.132.19/80 duration 0:00:30 bytes 0SYN Timeout (username)
I'm going to close this post now and start a new as I've managed to progress.
