Help with SSL VPN with no split tunneling!!
Hi all,
We have an ASA 5505 which we use for client based SSL VPN access.  Due to NIST and FISMA rgulations we are not permitted to use split tunneling. When connected to the VPN some websites come up fine, (google , etc.) while others resolve, but never fully come up (Box.com for example.)  The trace routes all go through as expected.  What would cause this type of behavior??  I would expect that if the issue was routing, no external websites would be accessible correct?  Any and all help would be appreciated.
Shaun McCloud
Are the sites that don't come up using https vrs http?
I have had this traffic pattern happen to me in the past and it was more of a protocal issue then strait routing.
Shaun
