How does AnyConnect work with static IP addresses?
dgaikwad
Level 5
Level 5
Hi Experts,
In our environment, we have some endpoints that have been assigned static IP addresses.
Now, when it goes through compliance check, at that its in the limited access VLAN, but post compliance, as per posture profile, endpoint gets the production IP address.
But, what we are seeing is that, even post compliance, the user does get a pop-up indicating that its getting the full access, although the network address remains from the limited access VLAN...
The question is that, is there is configuration that I am missing from switch or from ISE or from AnyConnect perspective?
Mike.Cifelli
In your ISE Posture Agent Profile Settings that you configured in ISE under Policy->Policy Elements->Results->Client Provisioning->Resources there is a section named 'IP Address Change'. Ensure/try to enable 'Enable agent IP refresh'. The value should be set to yes.
