How to disable TLS v1.0 v1.1 on FTD using the FDM or cli
mjsu
Is it possible to disable TLS v1.0 and v1.1 on FTD using the cli or FDM? (do not have FMC). These are offered on the webvpn portal, which also seems to be non-obvious how to disable.
> show running-config all ssl
ssl server-version tlsv1 dtlsv1
ssl client-version tlsv1
ssl cipher default medium
ssl cipher tlsv1 medium
ssl cipher tlsv1.1 medium
ssl cipher tlsv1.2 high
ssl cipher dtlsv1 medium
ssl cipher dtlsv1.2 high
> show ssl
Accept connections using SSLv3 or greater and negotiate to TLSv1 or greater
Start connections using TLSv1 and negotiate to TLSv1 or greater
SSL DH Group: group14 (2048-bit modulus, FIPS)
SSL ECDH Group: group19 (256-bit EC)
 I have also looked at the API and it doesn't seem possible.
Device is running version 7.0.5.
I can see https://quickview.cloudapps.cisco.com/quickview/bug/CSCvs23509 but not access the related bug details.
If you set the SSL/TLS setting properly in the referenced section, they will apply to the public-facing webvpn/AnyConnect/remote access VPN interfaces. That covers the data interfaces listening for connections to the device. You can run an nmap scan with the enum ciphers option against it to validate.
To change the on-box (management) TLS cipher support is not possible via the GUI. I have found in working with a customer that we can go into the expert mode and modify the web server properties to remove the ciphers you don't want. I wrote up doing that for FMC here:
https://community.cisco.com/t5/network-security/disable-weak-cipher-and-tls-on-cisco-firepower-management-center/td-p/4079053
For FTD devices, the httpsd.conf file is in /ngfw/etc/httpd. I confirmed in my lab that the procedure also works to reduce the ciphers presented via the management interface on an FDM locally -managed FTD device.
10 Replies 10
Sheraz.Salim
Have look at this link HERE it more from FMC but you will get an idea how to configure in FDM
please do not forget to rate.
Thank you for this. I did come across this already and cannot see the ability to do this in FDM or the cli. The ssl settings in the FDM only apply to the anyconnect, and do not seem to apply to the webvpn.
use flexconfig in FDM
Marvin Rhoads
Check under Device > System Settings > SSL Settings. This was added for FDM in version 7.0.
https://www.cisco.com/c/en/us/td/docs/security/secure-firewall/roadmap/device-manager-new-features-by-release.html
Device Manager SSL cipher settings for remote access VPN.
You can define the TLS versions and encryption ciphers to use for remote access VPN connections in device manager. Previously, you needed to use the threat defense API to configure SSL settings.
We added the following pages: Objects > SSL Ciphers; Device > System Settings > SSL Settings.
mjsu
Thanks, but when you configure those settings (device > system settings > ssl settings) it says they apply to remote access VPN connections only. This does seem to work for anyconnect VPN connections and I had this configured already but the 'show ssl' result is the same as in above snippet. When someone is auditing and scans the IP they still see TLS 1.0, 1.1 are available.
I did read somewhere that the ssl commands are blacklisted from flexconfig so am slightly wary of trying this and currently not in position to test on a spare system. It seems odd that disabling these is not a common task.
mjsu
I looked again at the SSL/TLS setting and found my error, the security level was set to High. My understanding of this security level setting was lacking. Setting this to All has applied to the interface and nmap is now showing only TLSv1.2. I will try the expert mode fix for management.
Thank you for your assistance and patience.
the SSL/TLS level is different than TLSv
there are many cipher in FW and it class to ALL LOW MEDIUM and HIGH
ALL contain all Cipher
and other Class each one remove some of Cipher
mjsu
Hmm. When I had this set to High, nmap showed TLSv1.0, 1.1, and 1.2. I changed it to ALL and now nmap only shows TLSv1.2
