India We are using Cisco ISR4431.having issue in importing CA Cert.
may272007
We are using Cisco ISR4431. we want to establish certificate based authentication IPsec tunnel with 3rdparty company. CA server is in 3rdparty infra. we don't have direct reachability to their server. We are doing exchange of certificates manually.
What we did so far I explaining.
3rdparty share their root, Issuing and immediate certificate with us. We installed root, Issuing and immediate certificate in our router successfully and generate CSR and share that CSR with 3rdparty. 3rdparty gave us certificate against that CSR but when we importing that certificate in our cisco router we are getting below error
%failed to parse or verify imported certificate
Can any one help what is the problem or how we can resolve this
5 Replies 5
@may272007 did you generate the CSR from the router itself? Using crypto pki enroll <TRUSTPOINT_NAME> then to import the signed CSR run crypto pki import <TRUSTPOINT_NAME> certificate?
may272007
@may272007 did you generate the CSR from the router itself? Using crypto pki enroll <TRUSTPOINT_NAME> then to import the signed CSR run crypto pki import <TRUSTPOINT_NAME> certificate?  Yes
Below are the steps we followed
ip domain-name abcxx.com
clock timezone IST 5 30
clock set 14:10:00 12 July 2023
conf t
crypto key generate rsa modulus 4096 general-keys
crypto pki trustpoint xxxxxxxxxx
chain-validation continue NokiaTunnelAP.go22.gpe.local
enrollment terminal
fqdn finlandpri.cisco.com
subject-name C = xx, ST = xx, L = xx, O = xx-SSE, OU = xx, CN =xx
revocation-check none
exit
crypto pki authenticate xxxxxxxxxx
pasted the root, issuing and immediate certificate here provided by 3rdparty
quit
Certificate has the following attributes:
        Fingerprint MD5: yyyyyyyyyyyyyyyyyyyyyyyyyyy
      Fingerprint SHA1: yyyyyyyyyyyyyyyyyyyyyyyyyyy
% Do you accept this certificate? [yes/no]: yes
Trustpoint CA certificate accepted.
% Certificate successfully imported
Do you accept this certificate?[yes/no] yes
crypto pki enroll xxxxxxxxx
include serial no in subject-name? no
include ip address in subject-name? no
display certificate request to terminal? [yes/no] yes
  ********* Here is  CSR*****************
Redisplay enrollment request? no
CSR copied and shared to 3rdparty and 3rdparty gave us certificate
then we tried to import certificate
#crypto pki import xxxxxxxxxx certificate
paste the copied certificate
quit
% Failed to parse or verify imported certificate
may272007
Can Any help to answer
Pavan Gundu
What do these debugs say when you try to import the signed certificate?
deb cry pki transactions
deb cry pki messages
