IPSEC client authentication problem
gizbri
Level 3
Level 3
ASA5520 8.2(4) Ipsec client VPN authenticating with LDAP to MS DC.
This has been up and working without issue for months. Suddenly we are getting the following message when some users attempt to login:
Apr 06 2011 15:33:02 Group = VPN, Username = jdoe, IP = x.x.x.x, Remote peer has failed user authentication -  check configured username and password
The username and password are proven good both in the MS network and when doing a AAA test on the ASA.
This is not happening to all users.
I did find some info about Kerberos and  checking this in the AD Account: Do not require kerberos pre-authentication
Modifing this did not help.
Any ideas?
7 Replies 7
tj.mitchell
Level 6
Level 6
Check the use for password about to expire. I have seen that a bug, if the password is about to expire it will fail the user authentication web though the AAA test works.
andamani
Could you please try the following:
test aaa authentication host < ip address of AAA server> .
Please paste the output of "sh run aaa" and "sh run tunnel-group "
hope this helps.
Anisha
P.S.: please mark this thread as answered if you feel your query is resolved. Do rate helpful posts.
t.j and Anisha - thnaks for the response.
t.j. - it doesnt appear we're hitting that bug
Anisha - test from ASA works fine.
What I am finding is the problem appears to be affecting certain hosts, not accounts. My account , for example, works fine on one PC , yet fails with the above error on another.
We have unistalled and re-installed the VPN client and it does not help.
Here is a log of a failing VPN client.
Cisco Systems VPN Client Version 5.0.07.0410
Copyright (C) 1998-2010 Cisco Systems, Inc. All Rights Reserved.
Client Type(s): Windows, WinNT
Running on: 5.1.2600 Service Pack 3
4      09:59:31.906  04/11/11  Sev=Info/6 CERT/0x63600026
Attempting to find a Certificate using Serial Hash.
5      09:59:32.031  04/11/11  Sev=Info/4 CM/0x63100002
Begin connection process
6      09:59:31.906  04/11/11  Sev=Info/6 CERT/0x63600027
Found a Certificate using Serial Hash.
7      09:59:32.046  04/11/11  Sev=Info/4 CM/0x63100004
Establish secure connection
8      09:59:31.921  04/11/11  Sev=Info/6 CERT/0x63600026
9      09:59:32.046  04/11/11  Sev=Info/4 CM/0x63100024
Attempt connection with server "X.X.X.X"
10     09:59:31.921  04/11/11  Sev=Info/6 CERT/0x63600027
11     09:59:32.046  04/11/11  Sev=Info/6 IKE/0x6300003B
Attempting to establish a connection with X.X.X.X.
12     09:59:31.921  04/11/11  Sev=Info/6 CERT/0x63600026
13     09:59:32.062  04/11/11  Sev=Info/6 CERT/0x63600026
14     09:59:31.937  04/11/11  Sev=Info/6 CERT/0x63600027
15     09:59:32.062  04/11/11  Sev=Info/6 CERT/0x63600027
16     09:59:32.031  04/11/11  Sev=Info/4 CERT/0x63600015
Cert ([email protected],cn=Test VPN,o=CCCCC) verification succeeded.
17     09:59:32.125  04/11/11  Sev=Info/4 CERT/0x63600015
18     09:59:32.125  04/11/11  Sev=Info/4 IKE/0x63000001
Starting IKE Phase 1 Negotiation
19     09:59:32.125  04/11/11  Sev=Info/4 IKE/0x63000013
SENDING >>> ISAKMP OAK MM (SA, VID(Xauth), VID(dpd), VID(Frag), VID(Nat-T), VID(Unity)) to X.X.X.X
20     09:59:32.203  04/11/11  Sev=Info/5 IKE/0x6300002F
Received ISAKMP packet: peer = X.X.X.X
21     09:59:32.203  04/11/11  Sev=Info/4 IKE/0x63000014
RECEIVING <<< ISAKMP OAK MM (SA, VID(Nat-T), VID(Frag)) from X.X.X.X
22     09:59:32.218  04/11/11  Sev=Info/5 IKE/0x63000001
Peer supports NAT-T
23     09:59:32.218  04/11/11  Sev=Info/5 IKE/0x63000001
Peer supports IKE fragmentation payloads
24     09:59:32.218  04/11/11  Sev=Info/6 IKE/0x63000001
IOS Vendor ID Contruction successful
25     09:59:32.218  04/11/11  Sev=Info/4 IKE/0x63000013
SENDING >>> ISAKMP OAK MM (KE, NON, NAT-D, NAT-D, VID(?), VID(Unity)) to X.X.X.X
26     09:59:32.250  04/11/11  Sev=Info/5 IKE/0x6300002F
27     09:59:32.250  04/11/11  Sev=Info/4 IKE/0x63000014
RECEIVING <<< ISAKMP OAK MM (KE, NON, CERT_REQ, VID(Unity), VID(Xauth), VID(?), VID(?), NAT-D, NAT-D) from X.X.X.X
28     09:59:32.250  04/11/11  Sev=Info/5 IKE/0x63000001
Peer is a Cisco-Unity compliant peer
29     09:59:32.250  04/11/11  Sev=Info/5 IKE/0x63000001
Peer supports XAUTH
30     09:59:32.250  04/11/11  Sev=Info/5 IKE/0x63000082
Received IOS Vendor ID with unknown capabilities flag 0x20000001
31     09:59:32.343  04/11/11  Sev=Info/6 CERT/0x63600034
Attempting to sign the hash for Windows XP or higher.
32     09:59:32.937  04/11/11  Sev=Info/6 CERT/0x63600035
Done with the hash signing with signature length of 256.
33     09:59:32.937  04/11/11  Sev=Info/4 IKE/0x63000013
SENDING >>> ISAKMP OAK MM *(ID, CERT, CERT_REQ, SIG, NOTIFY:STATUS_INITIAL_CONTACT) to X.X.X.X
34     09:59:32.937  04/11/11  Sev=Info/4 IKE/0x63000013
SENDING >>> ISAKMP OAK MM (FRAG) to X.X.X.X
35     09:59:32.937  04/11/11  Sev=Info/4 IKE/0x63000013
36     09:59:32.937  04/11/11  Sev=Info/4 IKE/0x63000013
37     09:59:32.937  04/11/11  Sev=Info/4 IKE/0x63000013
38     09:59:32.937  04/11/11  Sev=Info/4 IPSEC/0x63700008
IPSec driver successfully started
39     09:59:32.937  04/11/11  Sev=Info/4 IPSEC/0x63700014
Deleted all keys
40     09:59:33.328  04/11/11  Sev=Info/5 IKE/0x6300002F
41     09:59:33.328  04/11/11  Sev=Info/4 IKE/0x63000014
RECEIVING <<< ISAKMP OAK MM (FRAG) from X.X.X.X
42     09:59:33.328  04/11/11  Sev=Info/5 IKE/0x6300002F
43     09:59:33.328  04/11/11  Sev=Info/4 IKE/0x63000014
44     09:59:33.328  04/11/11  Sev=Info/5 IKE/0x6300002F
45     09:59:33.328  04/11/11  Sev=Info/4 IKE/0x63000014
46     09:59:33.328  04/11/11  Sev=Info/5 IKE/0x63000073
All fragments received.
47     09:59:33.328  04/11/11  Sev=Info/4 IKE/0x63000014
RECEIVING <<< ISAKMP OAK MM *(ID, CERT, SIG, VID(dpd)) from X.X.X.X
48     09:59:33.437  04/11/11  Sev=Info/4 CERT/0x63600015
Cert (cn=ASA5520colonie) verification succeeded.
49     09:59:33.437  04/11/11  Sev=Info/5 IKE/0x63000001
Peer supports DPD
50     09:59:33.437  04/11/11  Sev=Info/6 IKE/0x63000055
Sent a keepalive on the IPSec SA
51     09:59:33.437  04/11/11  Sev=Info/4 IKE/0x63000083
IKE Port in use - Local Port =  0x0554, Remote Port = 0x1194
52     09:59:33.453  04/11/11  Sev=Info/5 IKE/0x63000072
Automatic NAT Detection Status:
   Remote end is NOT behind a NAT device
   This   end IS behind a NAT device
53     09:59:33.453  04/11/11  Sev=Info/4 CM/0x6310000E
Established Phase 1 SA.  1 Crypto Active IKE SA, 0 User Authenticated IKE SA in the system
54     09:59:34.359  04/11/11  Sev=Info/5 IKE/0x6300002F
55     09:59:34.359  04/11/11  Sev=Info/4 IKE/0x63000014
RECEIVING <<< ISAKMP OAK TRANS *(HASH, ATTR) from X.X.X.X
56     09:59:34.359  04/11/11  Sev=Info/6 GUI/0x63B00012
Authentication request attributes is 6h.
57     09:59:34.359  04/11/11  Sev=Info/4 CM/0x63100015
Launch xAuth application
58     09:59:40.375  04/11/11  Sev=Info/4 CM/0x63100017
xAuth application returned
59     09:59:40.375  04/11/11  Sev=Info/4 IKE/0x63000013
SENDING >>> ISAKMP OAK TRANS *(HASH, ATTR) to X.X.X.X
60     09:59:40.437  04/11/11  Sev=Info/6 GUI/0x63B00012
61     09:59:40.421  04/11/11  Sev=Info/5 IKE/0x6300002F
62     09:59:40.421  04/11/11  Sev=Info/4 IKE/0x63000014
63     09:59:40.421  04/11/11  Sev=Info/4 CM/0x63100015
64     09:59:43.828  04/11/11  Sev=Info/6 IKE/0x63000055
65     09:59:47.109  04/11/11  Sev=Info/4 CM/0x63100017
66     09:59:47.109  04/11/11  Sev=Info/4 IKE/0x63000013
67     09:59:53.828  04/11/11  Sev=Info/6 IKE/0x63000055
68     10:00:03.828  04/11/11  Sev=Info/6 IKE/0x63000055
69     10:00:13.828  04/11/11  Sev=Info/6 IKE/0x63000055
70     10:00:17.468  04/11/11  Sev=Info/5 IKE/0x6300002F
71     10:00:17.468  04/11/11  Sev=Info/4 IKE/0x63000014
72     10:00:17.468  04/11/11  Sev=Info/6 GUI/0x63B00012
73     10:00:17.468  04/11/11  Sev=Info/4 CM/0x63100015
74     10:00:17.468  04/11/11  Sev=Warning/2 IKE/0xE300009B
Immature Navigation Termination due to error (Navigator:199)
75     10:00:23.828  04/11/11  Sev=Info/6 IKE/0x63000055
76     10:00:24.484  04/11/11  Sev=Info/4 CM/0x63100017
77     10:00:24.484  04/11/11  Sev=Info/4 IKE/0x63000013
78     10:00:24.531  04/11/11  Sev=Info/5 IKE/0x6300002F
79     10:00:24.531  04/11/11  Sev=Info/4 IKE/0x63000014
80     10:00:24.531  04/11/11  Sev=Info/4 IKE/0x63000013
81     10:00:24.531  04/11/11  Sev=Info/4 IKE/0x63000017
Marking IKE SA for deletion  (I_Cookie=8447269F65F34FAD R_Cookie=6A5B8C08EC8B2604) reason = DEL_REASON_WE_FAILED_AUTH
82     10:00:24.531  04/11/11  Sev=Info/4 IKE/0x63000013
SENDING >>> ISAKMP OAK INFO *(HASH, DEL) to X.X.X.X
83     10:00:25.328  04/11/11  Sev=Info/4 IKE/0x6300004B
Discarding IKE SA negotiation (I_Cookie=8447269F65F34FAD R_Cookie=6A5B8C08EC8B2604) reason = DEL_REASON_WE_FAILED_AUTH
84     10:00:25.328  04/11/11  Sev=Info/4 CM/0x63100014
Unable to establish Phase 1 SA with server "X.X.X.X" because of "DEL_REASON_WE_FAILED_AUTH"
85     10:00:25.328  04/11/11  Sev=Info/5 CM/0x63100025
Initializing CVPNDrv
86     10:00:25.343  04/11/11  Sev=Info/6 CM/0x63100046
Set tunnel established flag in registry to 0.
87     10:00:25.343  04/11/11  Sev=Info/4 IKE/0x63000001
IKE received signal to terminate VPN connection
88     10:00:25.343  04/11/11  Sev=Info/4 IPSEC/0x63700014
Deleted all keys
89     10:00:25.343  04/11/11  Sev=Info/4 IPSEC/0x63700014
Deleted all keys
90     10:00:25.343  04/11/11  Sev=Info/4 IPSEC/0x63700014
Deleted all keys
91     10:00:25.343  04/11/11  Sev=Info/4 IPSEC/0x6370000A
IPSec driver successfully stopped
hi,
You are right. The problem is not with the account.
The debugs clearly state the reason for delete is authentication failure.
could you please check that the password types is correct. i.e. no spaces are entered. Also are any of the other users able to connect to the client from this server?
please let me know the OS of the client.
Anisha
password is correct. I have a different laptop next to me and authentication works fine using the same account. This is affecting only a few users, all others are funtioning normally.
This seems to be a hardware issue. It looks like the laptop is entering "space" in between the alphabets of the password.
Could try using an extended keyboard and test?
If this still not works then, please try uninstall and re-install of the client from your laptop.
Hope this helps.
Anisha
Un-install , re-install fixed it
thanks
