IPSEC Failover between Cisco and FortiGate with static routing
Hassan Hameed
Due to live environment I cant use routing protocol between my current hub and one spoke because of EIGRP and DMVPN globally so I have created IPSEC between Cisco router and FortiGate firewall. Now I am using static routing between both sites. But now I need to create second VPN between same devices for HA and redundancy but I can point route toward single tunnel interface at both ends so how can I manage my failover on multiple ISP links.
Thanks and best regards.
 Take a look in IPSLA.  this might help.
Yes that can be helpful. I'll Test and update you.
Thank you
