IPSec phase 2 problem
mailaglady2
Level 5
Level 5
Hi All
I'm experiencing an issue that i don't understand from the debug isakmp & ipsec output.
my topology us as follows, only two router (R1 [ASR1006] & R2 [ISRG2-3900]) connected point to point. I'm trying to get IPSec to work on both routers but it keeps on failing. I must also configure DMVPN but for now to get the few sites up and running, i decided to start with IPSec then later I will change to DMVPN but my configs are working well on these 2 devices.
Attached are my configs for both devices, I'm trying to get this configuration working in the lab environment. if I can get a working config for DMVPN that would be of highly assistance. I have searched for config guidelines and examples but they not working for me.
Your assistance would be greatly appreciated.
Problem was with the inclusion of AH, AH is currently giving problems. When I used ESP only, IPSec worked well.
Kind regards
Mpho
Julio Carvajal
So you are using static Virtual tunnel interfaces and you are trying to setup a IPSEC tunnel.
Here are the things to make this work:
ASR side
crypto ipsec transform-set gabbage ah-sha-hmac esp-3des
*** No mode tunnel****
interface Tunnel10
tunnel mode ipsec ipv4
Cisco 3900 side
Interface tunnel 10
Please give it a try and let me know.
Any other question..Sure...Just remember to rate all of the forum answers.
Julio
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
It's still not working..
I wish I could get the current working deployed configuration for the ASR, I trust that my configuration is correct.
I think the issue is on the ASR, I have used the configuration on the 7200 router and it's working 100%. I will change the image on the ASR and check the results, I have also attached running config for the 7200 and the results of the tunnel. I only added tun11 on the 3900 with the same config and it's also working as expected.
Kinf regards
Mpho
Message was edited by: Mpho Maila
Kind regards
Mpho
