IPSec Problem
Ivan Kurguzov
Community Member
Hello.
There is the following structure:
192.168.34.0/23 <=> TMG <= IPSEC => ASA5510 9.0 (3) <=> 10.0.0.0/24 & 192.168.0.0/23.
Terminal server is located in subnet 10.0.0.0/24 and is being used by RDP users which are in 192.168.34.0/23 subnet. Users began receiving complaints that the session is often interrupted. I looked into the log of my Cisco, and found the following messages:
   713061     Group = X.X.20.138, IP = X.X.20.138, Rejecting IPSec tunnel: no matching crypto map entry for remote proxy X.X.20.138/255.255.255.255/0/0 local proxy 10.0.0.0/255.255.255.0/0/0 on interface OUTSIDE1
   713902      Group = X.X.20.138, IP = X.X.20.138, QM FSM error (P2 struct &0xacfa1fd0, mess id 0x1)!
   713902      Group = X.X.20.138, IP = X.X.20.138, Removing peer from correlator table failed, no match!
Cisco ASA configuration:
object network 192168340
 subnet 192.168.34.0 255.255.254.0
object network 10000
 subnet 10.0.0.0 255.255.255.0
object network 19216800
 subnet 192.168.0.0 255.255.254.0
object-group network DM_INLINE_NETWORK_4
 network-object object 10000
 network-object object 19216800
crypto map OUTSIDE1_map 22 match address OUTSIDE1_cryptomap_21
crypto map OUTSIDE1_map 22 set pfs
crypto map OUTSIDE1_map 22 set peer X.X.20.138
crypto map OUTSIDE1_map 22 set ikev1 transform-set ESP-DES-MD5
tunnel-group X.X.20.138 type ipsec-l2l
tunnel-group X.X.20.138 general-attributes
 default-group-policy GroupPolicy_X.X.20.138
tunnel-group X.X.20.138 ipsec-attributes
 ikev1 pre-shared-key *****
 isakmp keepalive disable
 ikev2 remote-authentication pre-shared-key *****
 ikev2 local-authentication pre-shared-key *****
group-policy GroupPolicy_X.X.20.138 internal
group-policy GroupPolicy_X.X.20.138 attributes
 vpn-tunnel-protocol ikev1
TMG configuration:
Local Tunnel Endpoint: X.X.20.138
Remote Tunnel Endpoint: X.X.147.246
IKE Phase I Parameters:
    Mode: Main mode
    Encryption: DES
    Integrity: MD5
    Diffie-Hellman group: Group 2 (1024 bit)
    Authentication Method: Pre-shared secret
    Security Association Lifetime: 86400 seconds
IKE Phase II Parameters:
    Mode: ESP tunnel mode
    Encryption: DES
    Integrity: MD5
    Perfect Forward Secrecy: ON.
    Time Rekeying: ON
    Security Association Lifetime: 28800 seconds
    Kbyte Rekeying: ON
    Rekey After Sending: 4608000 Kbytes
Remote Network '' IP Subnets:
    Subnet = 10.0.0.0/255.255.255.0
    Subnet = 192.168.0.0/255.255.254.0
Local Network 'Internal' IP Subnets:
    Subnet = 192.168.34.0/255.255.254.0
Routable Local IP Addresses:
What could cause the problem?
Ivan Kurguzov
Community Member
Up
