ipsec proxy-id problem
Nirav Thaker
Visitor
I am trying to create a site-to-site l2l vpn and  phase 1 completes fine but when validating the proxy-id in phase 2, the id is not being set correctly.
here is the config:
access-list ssatunnel extended permit ip 10.1.10.0 255.255.255.0 x.x.x.32 255.255.255.224
crypto ipsec security-association lifetime seconds 3600
crypto map ssa 1 match address ssatunnel
crypto map ssa 1 set pfs
crypto map ssa 1 set connection-type originate-only
crypto map ssa 1 set peer peerip
crypto map ssa 1 set ikev1 transform-set ssa
crypto map ssa 1 set security-association lifetime seconds 3600
crypto map ssa interface outside
crypto isakmp identity address
crypto ikev1 enable outside
crypto ikev1 policy 1
authentication pre-share
encryption aes-256
hash sha
group 2
lifetime 28800
tunnel-group peerip type ipsec-l2l
tunnel-group peerip ipsec-attributes
ikev1 pre-shared-key *****
it keeps useing the the peer-ip and my public ip for the proxy-id.  this faild the check on the remote side so phase 2 fails.
is there something i am missing.
olpeleri
Can you remove crypto map ssa 1 set connection-type originate-only
It's supposed to work only with an  ASA peer configured as receive-only or bidirectional
Cheers
8 Replies 8
olpeleri
Cheers
when i do that, it does not seem to initiate the connection.  the other side is a juniper, and it is not set to initiate the connection.
As long the interesting traffic reaches the ASA, it will start. Are you sure the traffic is routed to your ASA?
It will never work with initiate-only with Juniper.
Cheers,
Varinder Singh
Nirav,
Can you confirm with settings on Juniper to match pfs with group 2 as well as crypto access list?
You need to take debug level of 255 to see what Juniper is presenting for phase 2 cookies.
Take debug crypto isakmp 255 & debug crypto ipsec 255.
Can you also confirm on Juniper that they have configured address as ID and not hostname? Cisco uses IP adddress to negotiate the tunnel.
crypto map ssa 1 set connection-type originate-only command is to be used in scenario where you want to force ASA to initiate only. I would doubt that should be a problem.
Hope that helps
Varinder
Regards, Varinder P.S. Please mark this post as 'Answered' if you find the above information helpful so that it brings goodness to other community users
this is the error message from the juniper
2013-04-25 11:15:43
info
IKE 192.168.2.221 Phase 2 msg ID 67bd2a80: Negotiations have failed.
2013-04-25 11:15:43
info
Rejected an IKE packet on ethernet1/3 from 192.168.2.221:500 to 10.10.10.18:500with cookies e2bea3abcac4b367 and 5b81debf2f1f2970 because The peer sent a proxy ID that did not match the one in the SA config.
2013-04-25 11:15:43
info
IKE 192.168.2.221 Phase 2: No policy exists for the proxy ID received: local ID (10.10.10.18/255.255.255.255, 0, 0) remote ID (192.168.2.221/255.255.255.255, 0, 0).
2013-04-25 11:15:43
info
IKE 192.168..221 Phase 2 msg ID 67bd2a80: Responded to the peer's first message.
2013-04-25 11:15:43
info
IKE 192.168.2.221 Phase 1: Completed Main mode negotiations with a 28800-second lifetime.
Yep expected with initiate-only, we negotiate proxy-id's for the peer public IP in order to securise some messages between the 2 ASA's
From the command reference guide:
http://www.cisco.com/en/US/docs/security/asa/asa91/command/reference/c8.html#wp2477607
The crypto map set connection-type command  specifies the connection types for the backup LAN-to-LAN feature. It  allows multiple backup peers to be specified at one end of the  connection.
This feature works only between the following platforms:
•Two Cisco ASA 5500 series
•A Cisco ASA 5500 series and a Cisco VPN 3000 concentrator
•A Cisco ASA 5500 series and a security appliance running Cisco PIX security appliance software Version 7.0, or higher
Varinder Singh
This is quiet strange that Juniper is seeing the proxy ID as
, 0, 0) remote ID (
but you have configured
10.1.10.0 255.255.255.0 x.x.x.32 255.255.255.224 on ASA
Though 192.168.2.221 does not come in range 192.168.2.32/27. Can you match the crypto access list on both ends?
Also what do you see in debugs on ASA?
Varinder
sorry, didnt clean up the ips correctly  before posting.
i got it to work, thanks olpeleri.  taking out the originate-only option and trying to send traffic to the server started the vpn and it all worked.
thanks for all the help
Nirav
