IPSec Site-to-Site vpn configuration help..-- isakmp not tuning up
raghubevara
Hi All ,
Need Help in ipsec config ,
IASKMP is not up and no traffic in ipsec , Please help, thanks
Below is my config.
toplogy
Site A >> Cloud >>> Site B (eigrp configured)
 able to ping both sides VPN'ed traffice but unable to see isakmp peers and ipsec trafffic
Site A Config :
crypto isakmp policy 100
encr 3des
authentication pre-share
group 2
crypto isakmp key Cisco@123 address 90.0.0.2
crypto ipsec transform-set TS ah-md5-hmac esp-des
crypto map ipsec1 100 ipsec-isakmp
set peer 90.0.0.2
set security-association lifetime seconds 36000
set transform-set TS
match address 101
interface Tunnel1
ip address 172.168.0.2 255.255.0.0
tunnel source Serial0
tunnel destination 90.0.0.2
interface FastEthernet0
ip address 10.0.0.1 255.0.0.0
speed auto
interface Serial0
ip address 50.0.0.1 255.0.0.0
crypto map ipsec1
router eigrp 100
network 10.0.0.0
network 50.0.0.0
network 172.168.0.0
auto-summary
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 90.0.0.2
no ip http server
no ip http secure-server
access-list 101 permit ip 10.0.0.0 0.255.255.255 192.168.0.0 0.0.0.255
Site B Config :
encr 3des
group 2
crypto isakmp key Cisco@123 address 50.0.0.1
crypto map ipsec 100 ipsec-isakmp
set peer 50.0.0.1
match address 101
interface Tunnel1
ip address 172.168.0.1 255.255.0.0
tunnel destination 50.0.0.1
ip address 192.168.0.1 255.255.255.0
speed auto
interface Serial0
ip address 90.0.0.2 255.0.0.0
crypto map ipsec
router eigrp 100
network 90.0.0.0
network 172.168.0.0
network 192.168.0.0
auto-summary
ip route 0.0.0.0 0.0.0.0 50.0.0.1
no ip http server
access-list 101 permit ip 192.168.0.0 0.0.0.255 10.0.0.0 0.255.255.255
Site A output :
SiteA#ping 192.168.0.3 source serial 0
Sending 5, 100-byte ICMP Echos to 192.168.0.3, timeout is 2 seconds:
Packet sent with a source address of 50.0.0.1
Success rate is 100 percent (5/5), round-trip min/avg/max = 56/76/132 ms
SiteA#sh crypto isakmp sa
dst src state conn-id slot status
SiteA#sh crypto ipsec sa
interface: Serial0
Crypto map tag: ipsec1, local addr 50.0.0.1
protected vrf: (none)
local ident (addr/mask/prot/port): (10.0.0.0/255.0.0.0/0/0)
remote ident (addr/mask/prot/port): (192.168.0.0/255.255.255.0/0/0)
current_peer 90.0.0.2 port 500
PERMIT, flags={origin_is_acl,}
#pkts encaps: 0, #pkts encrypt: 0, #pkts digest: 0
#pkts decaps: 0, #pkts decrypt: 0, #pkts verify: 0
#pkts compressed: 0, #pkts decompressed: 0
#pkts not compressed: 0, #pkts compr. failed: 0
#pkts not decompressed: 0, #pkts decompress failed: 0
#send errors 0, #recv errors 0
local crypto endpt.: 50.0.0.1, remote crypto endpt.: 90.0.0.2
path mtu 1500, ip mtu 1500, ip mtu idb Serial0
current outbound spi: 0x0(0)
inbound esp sas:
inbound ah sas:
inbound pcp sas:
outbound esp sas:
outbound ah sas:
outbound pcp sas:
SiteA#sh crypto session
Crypto session current status
Interface: Serial0
Session status: DOWN
Peer: 90.0.0.2 port 500
IPSEC FLOW: permit ip 10.0.0.0/255.0.0.0 192.168.0.0/255.255.255.0
Active SAs: 0, origin: crypto map
Site B out put :
SiteB#ping 10.0.0.2 source se 0
Sending 5, 100-byte ICMP Echos to 10.0.0.2, timeout is 2 seconds:
Packet sent with a source address of 90.0.0.2
Success rate is 100 percent (5/5), round-trip min/avg/max = 64/92/128 ms
SiteB#sh crypto isakmp sa
SiteB#sh crypto ipsec sa
interface: Serial0
Crypto map tag: ipsec, local addr 90.0.0.2
local ident (addr/mask/prot/port): (192.168.0.0/255.255.255.0/0/0)
remote ident (addr/mask/prot/port): (10.0.0.0/255.0.0.0/0/0)
current_peer 50.0.0.1 port 500
local crypto endpt.: 90.0.0.2, remote crypto endpt.: 50.0.0.1
inbound esp sas:
inbound ah sas:
inbound pcp sas:
outbound esp sas:
outbound ah sas:
outbound pcp sas:
Do you have nat configured? Is all local traffic being natted by the outside interface?
If so, you need to ensure traffic destined to the remote network is not natted, add a deny rule at the top of the ACL (above the permit rule).
If that is not the case, please enable debugs - debug crypto isakmp and upload the output here for review.
