IPSec Tunnel Up but no system to system communication ?
usmansa1
Hi There !,
I need help for IPSec tunnel. Currently, I am working on a small task to create remote access between my laptop and office router, in order to access the office LAN network. IPSec tunnel is working fine but the LAN to LAN communication is not working ok (I am unable to access any LAN network in my office). Although I am able to ping the LAN Gateway which is configured on the same router, I am not able to access the server connected to the router on the same interface. On the server side, there is a default gateway which is 192.168.1.1 and I have ping the server IP (192.168.1.137) with loopback address which wasn't from the same subnet and its working fine. Can someone help me out? My Configurations details are mentioned below.
HR-1#show running-config
Building configuration...
Current configuration : 3789 bytes
! Last configuration change at 08:26:23 ACST Thu Feb 28 2019 by user34
version 15.2
service password-encryption
hostname HR-1
boot-start-marker
boot-end-marker
ip cef
ip dhcp excluded-address 192.168.1.1 192.168.1.199
ip dhcp excluded-address 192.168.1.299 192.168.1.254
ip dhcp pool Server_Form
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 8.8.8.8 8.8.4.4
option 66 ascii ......
lease infinite
ip domain name HR-1.com.bh
no ipv6 cef
crypto isakmp policy 10
encr 3des
authentication pre-share
group 2
crypto isakmp keepalive 30 20 periodic
crypto isakmp client configuration group HomeVPN
key XXXXXXXX
pool vpn-client
acl 108
crypto isakmp profile vpnclient
match identity group HomeVPN
client authentication list userauthen
isakmp authorization list groupauthor
client configuration address respond
virtual-template 1
crypto ipsec transform-set myset3 esp-3des esp-md5-hmac
mode tunnel
crypto ipsec profile HomeVPN
set transform-set myset3
set isakmp-profile vpnclient
interface Loopback100
ip address 10.192.168.1 255.255.255.0
interface GigabitEthernet0/0
description -----WAN LINK ----
ip address 37.131.254.1 255.255.255.252
ip access-group InternetOut out
ip nat outside
ip flow ingress
ip tcp adjust-mss 1200
media-type rj45
speed auto
duplex full
no negotiation auto
interface GigabitEthernet0/1
description ------Connection Server Form --------
ip nat inside
ip flow ingress
media-type rj45
speed auto
duplex full
no negotiation auto
interface Virtual-Template1 type tunnel
ip unnumbered GigabitEthernet0/1
no ip redirects
ip nat inside
ip flow ingress
ip tcp adjust-mss 1280
tunnel mode ipsec ipv4
tunnel protection ipsec profile HomeVPN
ip local pool vpn-client 10.10.10.10 10.10.10.20
ip nat inside source list NAT interface GigabitEthernet0/0 overload
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 37.131.254.1
ip route 10.10.10.0 255.255.255.0 Null0
ip access-list extended InternetOut
permit ip host 37.131.94.35 any
permit ip host 10.10.10.17 any
permit ip any any reflect Internet timeout 300
ip access-list extended NAT
permit ip 192.168.1.0 0.0.0.255 any
access-list 108 permit ip 192.168.1.0 0.0.0.255 10.10.10.0 0.0.0.255
snmp-server community public RO
control-plane
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
transport input all
end
HR-1#
You nat ACL doesn't exempt vpn to lan traffic should be.
You need to deny traffic betwee 10 subnet and 192 subnet before natting 192
to any.
**** Please remember to rate useful posts
Bro can you please specify the mistake.in configuration
I changed the access list NAT as per below but it still doesn't work.
deny ip 10.10.10.0 0.0.0.255 any
permit ip 192.168.254.0 0.0.0.255 any
I think I got you. I changed the configurations on my NAT list.
deny ip host 192.168.1.137 10.10.10.0 0.0.0.255
deny ip host 192.168.1.136 10.10.10.0 0.0.0.255
But still, it doesn't work, can you please help.
