ISDN redirecting IE problem
nick
Is there any way to get IOS to ignore the ISDN redirection number? I'm using a HDV-E1 on a 3600 and the phone switch its connected to is sending junk in the redirection IE and there seems no way to disable this.
Because dial-plan's use the redirecting number in place of the Called number when present, this is causing the call to fail.
Here is an Q931 debug: (calling number replaced by x's)
Nov 16 17:58:55.226: ISDN Se1/0:15: RX <- SETUP pd = 8 callref = 0x001F
Nov 16 17:58:55.226: Sending Complete
Nov 16 17:58:55.230: Bearer Capability i = 0x8090A3
Nov 16 17:58:55.230: Channel ID i = 0xA9839F
Nov 16 17:58:55.230: Calling Party Number i = 0x2180, 'xxxxxxxx', Plan:ISDN, Type:National
Nov 16 17:58:55.230: Called Party Number i = 0x85, '05511502000', Plan:Unknown, Type:Unknown
Nov 16 17:58:55.234: Low Layer Compat i = 0x8090A3
Nov 16 17:58:55.234: IE out of order or end of 'private' IEs --
Redirecting Number i = 0x0080, '370'
Nov 16 17:58:55.238: ISDN Se1/0:15: TX -> RELEASE_COMP pd = 8 callref = 0x801F
Nov 16 17:58:55.242: Cause i = 0x80E470 - Invalid information element contents
Many thanks,
Nick
Hello Nick,
not sure if this applies in your case, but there is a command:
no isdn outgoing ie redirecting-number
Check the command reference as well:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios123/123cgcr/dial_r/dia_i2g.htm#wp1190415
GP
