I have a pix 501 version 6.3(5) which I am using to establish 2 lan to lan vpns and provide remote access to vpn clients. This arrangement was working fine until we moved offices and changed our IP address. The far ends were changed as was the pix.
It now seems that the PIX won't initiate an ipsec connection. Remote access is fine and one of the lan to lan vpns comes up once it is initiated by the far end.
Debug shows no activity on the second vpn at all. Have I missed a setting to enable initiation. I have tried this with the old configuration and changing the external address and also with a fresh setup. Both with the same result.
Any help appreciated.
