Low throughput with ipsec in LAN
ruagstefan
Hello everybody
I've a problem with a ipsec connection between a ASA 5505 and the Cisco VPN client 5.
There are many tcp dup ack and lost segments wich indicate the out-of-order segments as i think.
This will obviously slow down the througput dramaticaly to aprox. 1 - 2 Mbit/s.
The attached file is a test TCP stream made with jperf from the vpn client (81.1.10.11, virtual vpn adapter) to the asa over a 100MBit LAN captured on the server side (192.168.101.190)
Thanks for any help.
0 Replies 0
