Does anyone know if it is possible to set up an Anyconnect tunnel such that it uses Machine Authentication (from a cert) as well as querying a RADIUS server for the primary authentication with RSA SecurID used a the Secondary method?
Essentially want to tie down connections to domain registered devices in addition to the use of AAA and 2FA
TIA
