MTU problem with IPsec tunnel
Hi all,
I have three tunnel interfaces, one main and two backup. MTU and MSS on all tunnel interfaces I have configured (Cisco 3825):
ip mtu 1400
ip tcp adjust-mss 1340
When 1st tunnel interface is up I have internet connnection, but when I shutdown 1st interface it shows this message and I lose internet:
*Jul 17 08:59:03.270: CRYPTO_ENGINE: locally-sourced pkt w/DF bit set is too big,ip->tl=1380, mtu=1342
When I shutdown 2nd interface, it also shows that message and no inetrnet connection.
What to do?
Well, to get to the bottom the issue, we would need the show-tech of the device. If not the complete one then just the show-version and details of show interface and VPN relevant configuration.
Possibly you can try the following and check if the issue gets resolved.
Configure "crypto ipsec df-bit clear" and re-configure
"tunnel-path-mtu-discovery".
Also, configure "ip mtu 1400" under the tunnel interfaces: int tun X ip mtu 1400
crypto ipsec df-bit [clear | set | copy]
Example:
Router(config)# crypto ipsec df-hit set
Sets the DF bit for the encapsulating header in tunnel mode for all interfaces.
*   The clear keyword clears the DF bit in the outer IP header, and the router may
fragment the packet to add the IP Security (IPSec) encapsulation.
*   The set keyword sets the DF bit in the outer IP header, however, the router may
fragment the packet if the original packet had the DF bit cleared.
*   The copy keyword has the router look in the original packet for the outer DF bit
setting. The copy keyword is the default setting.
Abhishek Purohit
CCIE-S- 35269
Regards, Abhishek Purohit CCIE-S- 35269
