Multi-site L2L VPN routing issue
who
Hi:
I have been built L2L VPN for 3 sites (Site A <--> Site B <--> Site C). It works fine for a while. But, sometimes I cannot connect from site A to site C. But, I can reconnect once when I restart the Site A firewall. Both Site A and Site C connect to Site B are excellent. Please see configuration below for more ifnormation. Thanks for any suggestion!
Site A
ASA Version 8.4(3)
hostname jtfw-lex
enable password Yr4Jr0JzJxYTTQQu encrypted
passwd GCdiui.2NH7n52DU encrypted
names
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
ip address 172.29.88.254 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address 173.190.234.138 255.255.255.248
ftp mode passive
object network obj_any
subnet 0.0.0.0 0.0.0.0
object service RDP
service tcp source eq 3389
object service SMTP
service tcp source eq smtp
object service PPTP
service tcp source eq pptp
object service JT_WWW
service tcp source eq www
object service JT_HTTPS
service tcp source eq https
object network jt-dc01
host 172.29.88.151
object network WAN_jt-dc01
host 10.8.8.3
object network obj_lex
subnet 172.29.88.0 255.255.255.0
description Lexinton office network
object network obj_HQ
subnet 172.29.8.0 255.255.255.0
description Jollytech HQ network
object network obj_colo
subnet 172.29.168.0 255.255.255.0
description Jollytech colo network
access-list inside_access_in extended permit icmp any any
access-list inside_access_in extended deny tcp any any eq netbios-ssn inactive
access-list inside_access_in extended deny tcp any eq netbios-ssn any inactive
access-list inside_access_in extended deny udp any eq 139 any inactive
access-list inside_access_in extended deny udp any any eq 139 inactive
access-list inside_access_in extended deny tcp any any eq 135 inactive
access-list inside_access_in extended deny tcp any eq 135 any inactive
access-list inside_access_in extended deny udp any eq 135 any inactive
access-list inside_access_in extended deny udp any any eq 135 inactive
access-list inside_access_in extended deny tcp any any eq 1591
access-list inside_access_in extended deny tcp any eq 1591 any
access-list inside_access_in extended deny udp any eq 1591 any
access-list inside_access_in extended deny udp any any eq 1591
access-list inside_access_in extended deny tcp any any eq 1214
access-list inside_access_in extended deny tcp any eq 1214 any
access-list inside_access_in extended deny udp any eq 1214 any
access-list inside_access_in extended deny udp any any eq 1214
access-list inside_access_in extended permit ip any any
access-list outside_access_in extended permit icmp any any
access-list outside_access_in extended permit tcp any host 10.8.8.3 eq smtp
access-list outside_access_in extended permit tcp any host 10.8.8.3 eq pptp
access-list outside_access_in extended permit tcp any host 10.8.8.3 eq www
access-list outside_access_in extended permit tcp any host 10.8.8.3 eq https
access-list outside_access_in extended permit tcp any host 10.8.8.3 eq 3389
access-list outside_access_in extended permit ip any any
access-list inside_access_out extended permit icmp any any
access-list outside_cryptomap extended permit ip 172.29.88.0 255.255.255.0 object obj_HQ
access-list outside_cryptomap extended permit ip object obj_lex object obj_colo
access-list VPN_Tunnel_user standard permit 172.29.88.0 255.255.255.0
access-list VPN_Tunnel_user standard permit 172.29.8.0 255.255.255.0
access-list VPN_Tunnel_user standard permit 172.29.168.0 255.255.255.0
access-list VPN_Tunnel_user standard permit 192.168.88.0 255.255.255.0
pager lines 24
logging enable
logging asdm informational
logging host inside 172.29.88.30
mtu inside 1500
mtu outside 1500
ip local pool jolly_lex_DHCP 192.168.88.100-192.168.88.120 mask 255.255.255.0
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
nat (inside,outside) source static jt-dc01 WAN_jt-dc01 service RDP RDP
nat (inside,outside) source static jt-dc01 WAN_jt-dc01 service JT_WWW JT_WWW
nat (inside,outside) source static obj_lex obj_lex destination static obj_HQ obj_HQ route-lookup
nat (inside,outside) source static obj_lex obj_lex destination static obj_colo obj_colo route-lookup
nat (inside,outside) dynamic interface
access-group inside_access_in in interface inside
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 173.190.234.137 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
http server enable
http 172.29.88.0 255.255.255.0 inside
snmp-server host inside 172.29.88.30 community ***** version 2c
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
crypto ipsec ikev1 transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec ikev1 transform-set Remote_VPN_set esp-3des esp-md5-hmac
crypto ipsec ikev2 ipsec-proposal DES
protocol esp encryption des
protocol esp integrity sha-1 md5
crypto ipsec ikev2 ipsec-proposal 3DES
protocol esp encryption 3des
crypto ipsec ikev2 ipsec-proposal AES
protocol esp encryption aes
crypto ipsec ikev2 ipsec-proposal AES192
protocol esp encryption aes-192
crypto ipsec ikev2 ipsec-proposal AES256
protocol esp encryption aes-256
crypto map outside_map 1 match address outside_cryptomap
crypto map outside_map 1 set pfs
crypto map outside_map 1 set peer 173.164.111.140
crypto map outside_map 1 set ikev1 transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_map 1 set ikev2 ipsec-proposal DES 3DES AES AES192 AES256
crypto map outside_map interface outside
crypto ikev2 policy 1
encryption aes-256
integrity sha
group 5 2
prf sha
lifetime seconds 86400
crypto ikev2 policy 10
encryption aes-192
integrity sha
group 5 2
prf sha
crypto ikev2 policy 20
encryption aes
integrity sha
group 5 2
prf sha
crypto ikev2 policy 30
encryption 3des
integrity sha
group 5 2
prf sha
crypto ikev2 policy 40
encryption des
integrity sha
group 5 2
prf sha
crypto ikev2 enable outside
crypto ikev1 enable outside
crypto ikev1 policy 10
authentication crack
encryption aes-256
hash sha
group 2
lifetime 86400
crypto ikev1 policy 20
authentication rsa-sig
encryption aes-256
hash sha
group 2
lifetime 86400
crypto ikev1 policy 30
authentication pre-share
encryption aes-256
hash sha
group 2
lifetime 86400
crypto ikev1 policy 40
encryption aes-192
hash sha
group 2
lifetime 86400
crypto ikev1 policy 50
encryption aes-192
hash sha
group 2
lifetime 86400
crypto ikev1 policy 60
encryption aes-192
hash sha
group 2
lifetime 86400
crypto ikev1 policy 70
encryption aes
hash sha
group 2
lifetime 86400
crypto ikev1 policy 80
encryption aes
hash sha
group 2
lifetime 86400
crypto ikev1 policy 90
encryption aes
hash sha
group 2
lifetime 86400
crypto ikev1 policy 100
encryption 3des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 110
encryption 3des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 120
encryption 3des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 130
encryption des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 140
encryption des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 150
encryption des
hash sha
group 2
lifetime 86400
telnet 172.29.88.0 255.255.255.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 172.29.88.50-172.29.88.100 inside
dhcpd dns 172.29.8.3 166.102.165.11 interface inside
dhcpd domain jollytech.local interface inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics port
threat-detection statistics protocol
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
group-policy GroupPolicy_173.164.111.140 internal
group-policy GroupPolicy_173.164.111.140 attributes
vpn-tunnel-protocol ikev1 ikev2 l2tp-ipsec
username who password JOYSoaqW4x32VHKB encrypted
tunnel-group 173.164.111.140 type ipsec-l2l
tunnel-group 173.164.111.140 general-attributes
default-group-policy GroupPolicy_173.164.111.140
tunnel-group 173.164.111.140 ipsec-attributes
ikev1 pre-shared-key *****
ikev2 remote-authentication pre-shared-key *****
ikev2 remote-authentication certificate
ikev2 local-authentication pre-shared-key *****
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
  inspect pptp
  inspect ftp
  inspect netbios
  inspect icmp
service-policy global_policy global
smtp-server 172.29.8.3
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:ad903070f970660dc4cc357a8f80bd1c
: end
Site B:
: Saved
ASA Version 8.4(4)1
hostname jtfw-hq
domain-name jollytech.com
names
 speed 100
 speed 100
interface Vlan1
 nameif inside
 security-level 100
 ip address 172.29.8.254 255.255.255.0
interface Vlan2
 nameif outside
 security-level 0
 ip address 173.164.111.140 255.255.255.248
ftp mode passive
clock timezone GMT 0
dns server-group DefaultDNS
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object service RDP
object network orange
 host 172.29.8.151
object network WAN_173_164_111_138
 host 173.164.111.138
object service SMTP
object service PPTP
 description Lexington office network
object network guava
 host 172.29.8.3
object network obj_HQVPN
 subnet 192.168.8.0 255.255.255.0
object network jt-fn68zv1
 host 172.29.8.71
object service JT_FTP
 service tcp source eq ftp
object network Avocado
 host 172.29.8.18
object service JT_SIP
 service tcp source eq sip
object service JT_5000
 service tcp source eq 5000
object service JT_5090
 service tcp source eq 5090
access-list VPN_Tunnel_User standard permit 172.29.8.0 255.255.255.0
access-list VPN_Tunnel_User standard permit 192.168.8.0 255.255.255.0
access-list inside_access_in extended permit tcp any any eq www
access-list inside_access_in extended permit tcp any eq www any
access-list outside_access_in extended permit tcp any host 173.164.111.138 eq 3389
access-list outside_access_in extended permit tcp any host 173.164.111.138 eq smtp
access-list outside_access_in extended permit tcp any host 173.164.111.138 eq pptp
access-list outside_access_in extended permit tcp any host 173.164.111.138 eq www
access-list outside_access_in extended permit tcp any host 173.164.111.138 eq https
access-list outside_access_in extended permit tcp any host 173.164.111.140 eq sip
access-list outside_access_in extended permit tcp any host 173.164.111.140 eq 5090
access-list outside_access_in extended permit tcp any host 173.164.111.140 eq 5000
access-list inside_access_out extended permit ip any any
access-list outside_cryptomap extended permit ip 172.29.8.0 255.255.255.0 172.29.88.0 255.255.255.0
access-list outside_cryptomap extended permit ip object obj_colo object obj_lex
access-list inside_in extended permit icmp any any
access-list inside_in extended permit ip any any
access-list inside_in extended permit udp any any eq isakmp
access-list inside_in extended permit udp any eq isakmp any
access-list inside_in extended permit tcp any any
access-list outside_cryptomap_1 extended permit ip object obj_HQ object obj_colo
access-list outside_cryptomap_1 extended permit ip object obj_lex object obj_colo
pager lines 24
logging enable
logging timestamp
logging trap informational
logging from-address jtfw-hq@jollytech.com
logging host inside 172.29.8.89
mtu inside 1500
mtu outside 1500
ip local pool Jolly_HQVPN_DHCP 192.168.8.100-192.168.8.150 mask 255.255.255.0
asdm history enable
arp timeout 14400
nat (inside,outside) source static orange interface service RDP RDP
nat (inside,outside) source static guava WAN_173_164_111_138 service JT_WWW JT_WWW
nat (inside,outside) source static guava WAN_173_164_111_138 service JT_HTTPS JT_HTTPS
nat (inside,outside) source static guava WAN_173_164_111_138 service RDP RDP
nat (inside,outside) source static guava WAN_173_164_111_138 service SMTP SMTP
nat (inside,outside) source static guava WAN_173_164_111_138 service PPTP PPTP
nat (inside,outside) source static jt-fn68zv1 interface service JT_FTP JT_FTP
nat (inside,outside) source static Avocado interface service JT_SIP JT_SIP
nat (any,outside) source static Avocado interface service JT_5090 JT_5090
nat (any,outside) source static Avocado interface service JT_5000 JT_5000
nat (inside,outside) source static obj_HQ obj_HQ destination static obj_colo obj_colo route-lookup
nat (inside,outside) source static obj_HQ obj_HQ destination static obj_lex obj_lex route-lookup
nat (outside,outside) source static obj_colo obj_colo destination static obj_lex obj_lex route-lookup
nat (outside,outside) source static obj_lex obj_lex destination static obj_colo obj_colo route-lookup
nat (inside,outside) source static obj_HQ obj_HQ destination static obj_HQVPN obj_HQVPN
route outside 0.0.0.0 0.0.0.0 173.164.111.142 1
timeout conn 10:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
aaa-server Guava protocol nt
aaa-server Guava (inside) host 172.29.8.3
 timeout 15
 nt-auth-domain-controller guava
user-identity inactive-user-timer minutes 360
http server enable
http 172.29.8.0 255.255.255.0 inside
snmp-server host inside 172.29.8.89 community ***** version 2c
crypto ipsec ikev1 transform-set Remote_VPN_Set esp-3des esp-md5-hmac
crypto dynamic-map outside_dyn_map 20 set ikev1 transform-set Remote_VPN_Set
crypto dynamic-map outside_dyn_map 20 set reverse-route
crypto map outside_map 1 set peer 173.190.234.138
crypto map outside_map 2 match address outside_cryptomap_1
crypto map outside_map 2 set pfs
crypto map outside_map 2 set peer 198.111.239.218
crypto map outside_map 2 set ikev1 transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_map 2 set ikev2 ipsec-proposal DES 3DES AES AES192 AES256
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map
 encryption aes-256
 integrity sha
 group 5 2
 prf sha
 encryption aes-192
 integrity sha
 group 5 2
 prf sha
 encryption aes
 integrity sha
 group 5 2
 prf sha
 encryption 3des
 integrity sha
 group 5 2
 prf sha
 encryption des
 integrity sha
 group 5 2
 prf sha
 encryption aes-256
 hash sha
 group 2
 lifetime 86400
 encryption aes-256
 hash sha
 group 2
 lifetime 86400
 encryption aes-256
 hash sha
 group 2
 lifetime 86400
 encryption aes-192
 hash sha
 group 2
 lifetime 86400
 encryption aes-192
 hash sha
 group 2
 lifetime 86400
 encryption aes-192
 hash sha
 group 2
 lifetime 86400
 encryption aes
 hash sha
 group 2
 lifetime 86400
 encryption aes
 hash sha
 group 2
 lifetime 86400
 encryption aes
 hash sha
 group 2
 lifetime 86400
 encryption 3des
 hash sha
 group 2
 lifetime 86400
 encryption 3des
 hash sha
 group 2
 lifetime 86400
 encryption 3des
 hash sha
 group 2
 lifetime 86400
 encryption des
 hash sha
 group 2
 lifetime 86400
 encryption des
 hash sha
 group 2
 lifetime 86400
 encryption des
 hash sha
 group 2
 lifetime 86400
telnet 172.29.8.0 255.255.255.0 inside
telnet timeout 5
ssh timeout 5
ssh key-exchange group dh-group1-sha1
console timeout 0
dhcpd auto_config outside vpnclient-wins-override
dhcprelay server 172.29.8.3 inside
threat-detection statistics tcp-intercept rate-interval 30 burst-rate 400 average-rate 200
webvpn
 enable outside
group-policy Jolleytech_VPN internal
group-policy Jolleytech_VPN attributes
 dns-server value 172.29.8.3
 split-tunnel-policy tunnelspecified
 split-tunnel-network-list value VPN_Tunnel_User
 default-domain value jollytech.local
group-policy GroupPolicy_10.8.8.1 internal
group-policy GroupPolicy_10.8.8.1 attributes
username who password eicyrfJBrqOaxQvS encrypted
tunnel-group jollytech type remote-access
tunnel-group jollytech general-attributes
 address-pool Jolly_HQVPN_DHCP
 authentication-server-group Guava
 default-group-policy Jolleytech_VPN
tunnel-group jollytech ipsec-attributes
tunnel-group 198.111.239.218 type ipsec-l2l
tunnel-group 198.111.239.218 general-attributes
 default-group-policy GroupPolicy_10.8.8.1
tunnel-group 198.111.239.218 ipsec-attributes
tunnel-group 173.190.234.138 type ipsec-l2l
tunnel-group 173.190.234.138 general-attributes
tunnel-group 173.190.234.138 ipsec-attributes
  inspect pptp
  inspect ftp
  inspect netbios
  inspect http
  inspect icmp
 class class-default
  user-statistics accounting
hpm topN enable
Cryptochecksum:8dd2069c8484cd43617a27072c31a92e
: end
Site C:
ASA Version 8.4(3)
hostname jtfw-colo
names
interface Vlan1
nameif inside
security-level 100
ip address 172.29.168.254 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address 198.111.239.218 255.255.255.248
ftp mode passive
object service RDP
object service JT_SMTP
object service PPTP
host 172.29.8.3
description Jollytech HQ VPN Network
object network WAN_198_111_239_220
host 198.111.239.220
host 172.29.168.3
object network jt-exch2010
host 172.29.168.25
object network RC_jt-r610
host 172.29.168.8
object network WAN_198_111_239_221
host 198.111.239.221
object network jt-sp2010
host 172.29.168.9
access-list outside_access_in extended permit tcp any object WAN_198_111_239_220 eq 3389
access-list outside_access_in extended permit tcp any object WAN_198_111_239_220 eq www
access-list outside_access_in extended permit tcp any object WAN_198_111_239_220 eq https
access-list outside_access_in extended permit tcp any object WAN_198_111_239_221 eq www
access-list outside_access_in extended permit tcp any object WAN_198_111_239_221 eq https
access-list outside_access_in extended permit tcp any object WAN_198_111_239_221 eq 3389
access-list outside_access_in extended permit tcp any object WAN_198_111_239_221 eq smtp
access-list outside_cryptomap extended permit ip object obj_colo object obj_HQ
pager lines 24
logging enable
logging from-address jtfw-colo@jollytech.com
logging recipient-address who@jollytech.com level errors
logging host inside 172.29.168.89
mtu inside 1500
mtu outside 1500
ip local pool Jolly_coloVPN_DHCP 192.168.168.100-192.168.168.110 mask 255.255.255.0
asdm history enable
arp timeout 14400
nat (inside,outside) source static RC_jt-r610 interface service JT_WWW JT_WWW
nat (inside,outside) source static RC_jt-r610 interface service JT_HTTPS JT_HTTPS
nat (inside,outside) source static jt-sp2010 WAN_198_111_239_220 service JT_HTTPS JT_HTTPS
nat (inside,outside) source static jt-sp2010 WAN_198_111_239_220 service JT_WWW JT_WWW
nat (inside,outside) source static jt-sp2010 WAN_198_111_239_220 service RDP RDP
nat (inside,outside) source static jt-exch2010 WAN_198_111_239_221 service RDP RDP
nat (inside,outside) source static jt-exch2010 WAN_198_111_239_221 service JT_WWW JT_WWW
nat (inside,outside) source static jt-exch2010 WAN_198_111_239_221 service JT_HTTPS JT_HTTPS
nat (inside,outside) source static jt-exch2010 WAN_198_111_239_221 service JT_SMTP JT_SMTP
nat (inside,outside) source static obj_colo obj_colo destination static obj_HQ obj_HQ route-lookup
nat (inside,outside) source static obj_colo obj_colo destination static obj_lex obj_lex route-lookup
route outside 0.0.0.0 0.0.0.0 198.111.239.217 1
http server enable
http 172.29.168.0 255.255.255.0 inside
snmp-server host inside 172.29.168.89 community ***** version 2c
snmp-server location HE Fremont Colo
snmp-server contact who@jollytech.com
crypto ipsec ikev1 transform-set Remote_vpn_set esp-3des esp-md5-hmac
crypto map outside_map 1 set ikev2 ipsec-proposal AES256 AES192 AES 3DES DES
encryption aes-256
integrity sha
group 5 2
prf sha
encryption aes-192
integrity sha
group 5 2
prf sha
encryption aes
integrity sha
group 5 2
prf sha
encryption 3des
integrity sha
group 5 2
prf sha
encryption des
integrity sha
group 5 2
prf sha
encryption 3des
hash sha
group 2
lifetime 43200
encryption aes-256
hash sha
group 2
lifetime 86400
encryption aes-256
hash sha
group 2
lifetime 86400
encryption aes-256
hash sha
group 2
lifetime 86400
encryption aes-192
hash sha
group 2
lifetime 86400
encryption aes-192
hash sha
group 2
lifetime 86400
encryption aes-192
hash sha
group 2
lifetime 86400
encryption aes
hash sha
group 2
lifetime 86400
encryption aes
hash sha
group 2
lifetime 86400
encryption aes
hash sha
group 2
lifetime 86400
encryption 3des
hash sha
group 2
lifetime 86400
encryption 3des
hash sha
group 2
lifetime 86400
encryption 3des
hash sha
group 2
lifetime 86400
encryption des
hash sha
group 2
lifetime 86400
encryption des
hash sha
group 2
lifetime 86400
encryption des
hash sha
group 2
lifetime 86400
telnet 172.29.168.0 255.255.255.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
webvpn
enable outside
  inspect pptp
  inspect ftp
  inspect netbios
  inspect icmp
Cryptochecksum:6438e01e896c07c1280a7c5b27455c09
: end
asdm history enable
Andrew Phirsov
Level 7
Level 7
It works fine for a while. But, we always have little issue
What's that little issue?))
Sorry! I was not made clear description of the issue. I have problem to connect Site A to Site C. Sometimes work, sometimes donot. I tried reboot the Site A firewall once, and it works fine after. But, I try the same thing today. It does not help.
Anyone else could help!
Any Expert could contribute his experiance?
One update, I post similar issue few weeks ago. One of expert suggest to add
It works fine for a few weeks.
Does anyone could point other possible issues?
