04-02-2006 04:29 AM
hi,
I have customer, he is having 10 branch offices.
From 10 branches employees will connect to main office occassionally using ISDN BRI connection.
In central office how to configure PRI interface of the router for these connecions.
skrao
04-02-2006 10:30 AM
Skrao,
Can you give us the equipment your going to be doing this on. It's fairly similar across the board but here are a couple of links to look at, the first one should be your best bet second two are for follow up.
http://www.cisco.com/en/US/tech/tk801/tk379/technologies_configuration_example09186a0080093ffd.shtml
http://www.cisco.com/en/US/tech/tk801/tk379/tech_configuration_examples_list.html
http://www.cisco.com/en/US/products/sw/iosswrel/ps1834/products_feature_guide09186a00800800b0.html
Basically PRI define your isdn switchtype configure your controller then the serial interface with the isdn switchtype and isdn-voice data.
That first link should give you everything you need.
Patrick
Log in to Community
