Need help setting up site-to-site VPN between two ASA 5505's
jjeffries4021
We have been pulling our hair outtrying to solve this. Below is the running configs for both Sites. We have always used Junipers prior to this. It does not appear that the tunnel is getting created. Any help would be greatly appreciated
Basic
Network A: (Dallas)
10.180.1.0 / 24
Network B: (Georgia)
10.180.2.0 /24
Running Config on Dallas ASA
: Saved
ASA Version 8.4(4)1
hostname ACH-DALLAS
enable password baW0bWk3Oyn6cZhc encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
ip address 10.180.1.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address 71.123.179.111 255.255.255.0
ftp mode passive
clock timezone CST -6
clock summer-time CDT recurring
dns domain-lookup inside
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object network obj_any
subnet 0.0.0.0 0.0.0.0
object network Route
object network Outside
host 71.123.179.111
object network Server
host 10.180.1.3
object service FTP
service tcp source range ftp-data ftp destination range ftp-data ftp
description FTP
object network FTP_Server
host 10.180.1.3
description FTP Server
object network Site-A-Dallas-Subnet
subnet 10.180.1.0 255.255.255.0
description Dallas
object network Site-B-Georgia-Firewall
host 173.227.90.194
description Georgia Firewall
object network Site-B-Georgia-Subnet
subnet 10.180.2.0 255.255.255.0
description Georgia
object network Georgia
object network Dallas
object-group service DM_INLINE_TCP_1 tcp
port-object eq ftp
port-object eq ftp-data
access-list inside_access_in extended permit ip any any
access-list outside_access_in extended permit ip any any
access-list outside_access_in extended permit tcp any object FTP_Server object-group DM_INLINE_TCP_1
access-list outside_1_cryptomap extended permit ip object Georgia object Dallas
access-list outside_cryptomap extended permit ip object Dallas object Georgia
pager lines 24
logging enable
logging asdm debugging
mtu inside 1500
mtu outside 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
nat (inside,outside) source static Dallas Dallas destination static Georgia Georgia no-proxy-arp route-lookup
nat (inside,outside) static interface service tcp ftp ftp
nat (inside,outside) after-auto source static any interface destination static obj_any obj_any
nat (inside,outside) after-auto source static any interface service FTP FTP
access-group inside_access_in in interface inside
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 71.123.179.1 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
http server enable
http 10.180.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
crypto ipsec ikev1 transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec ikev2 ipsec-proposal DES
protocol esp encryption des
protocol esp integrity sha-1 md5
crypto ipsec ikev2 ipsec-proposal 3DES
protocol esp encryption 3des
crypto ipsec ikev2 ipsec-proposal AES
protocol esp encryption aes
crypto ipsec ikev2 ipsec-proposal AES192
protocol esp encryption aes-192
crypto ipsec ikev2 ipsec-proposal AES256
protocol esp encryption aes-256
crypto ipsec security-association replay window-size 1024
crypto map outside_map 1 match address outside_cryptomap
crypto map outside_map 1 set pfs
crypto map outside_map 1 set peer 173.227.90.194
crypto map outside_map 1 set ikev1 phase1-mode aggressive
crypto map outside_map 1 set ikev1 transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_map 1 set ikev2 ipsec-proposal DES 3DES AES AES192 AES256
crypto map outside_map 1 set ikev2 pre-shared-key *****
crypto map outside_map interface outside
crypto ca trustpoint _SmartCallHome_ServerCA
crl configure
crypto ikev2 policy 1
encryption aes-256
integrity sha
group 5 2
prf sha
lifetime seconds 86400
crypto ikev2 policy 10
encryption aes-192
integrity sha
group 5 2
prf sha
crypto ikev2 policy 20
encryption aes
integrity sha
group 5 2
prf sha
crypto ikev2 policy 30
encryption 3des
integrity sha
group 5 2
prf sha
crypto ikev2 policy 40
encryption des
integrity sha
group 5 2
prf sha
crypto ikev2 enable outside
crypto ikev1 enable outside
crypto ikev1 policy 20
authentication rsa-sig
encryption aes-256
hash sha
group 2
lifetime 86400
crypto ikev1 policy 30
authentication pre-share
encryption aes-256
hash sha
group 2
lifetime 86400
crypto ikev1 policy 40
authentication crack
encryption aes-192
hash sha
group 2
lifetime 86400
crypto ikev1 policy 50
encryption aes-192
hash sha
group 2
lifetime 86400
crypto ikev1 policy 60
encryption aes-192
hash sha
group 2
lifetime 86400
crypto ikev1 policy 70
encryption aes
hash sha
group 2
lifetime 86400
crypto ikev1 policy 80
encryption aes
hash sha
group 2
lifetime 86400
crypto ikev1 policy 90
encryption aes
hash sha
group 2
lifetime 86400
crypto ikev1 policy 100
encryption 3des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 110
encryption 3des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 130
encryption des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 140
encryption des
hash sha
group 2
lifetime 86400
crypto ikev1 policy 150
encryption des
hash sha
group 2
lifetime 86400
telnet 10.180.1.0 255.255.255.0 inside
telnet timeout 5
ssh timeout 5
ssh key-exchange group dh-group1-sha1
console timeout 0
dhcpd auto_config outside
dhcpd address 10.180.1.51-10.180.1.254 inside
dhcpd dns 68.237.112.12 68.238.96.12 interface inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics host
threat-detection statistics port
threat-detection statistics protocol
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
ntp server 64.147.116.229 source outside prefer
webvpn
group-policy GroupPolicy_173.227.90.194 internal
group-policy GroupPolicy_173.227.90.194 attributes
vpn-tunnel-protocol ikev1 ikev2
tunnel-group 173.227.90.194 type ipsec-l2l
tunnel-group 173.227.90.194 general-attributes
default-group-policy GroupPolicy_173.227.90.194
tunnel-group 173.227.90.194 ipsec-attributes
ikev1 pre-shared-key *****
ikev2 remote-authentication pre-shared-key *****
ikev2 local-authentication pre-shared-key *****
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
prompt hostname context
call-home reporting anonymous
Cryptochecksum:8f338f323a8f642808bd20965b793291
: end
Running Config on Georgia ASA
: Saved
ASA Version 8.4(4)1
hostname ACHGeorgia
enable password 8Ry2YjIyt7RRXU24 encrypted
names
interface Vlan1
nameif inside
security-level 100
ip address 10.180.2.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address 173.227.90.194 255.255.255.224
ftp mode passive
dns domain-lookup outside
dns server-group DefaultDNS
name-server 216.136.95.2
name-server 64.132.94.250
object network Site-A-Dallas-Firewall
host 71.123.179.111
description Dallas Firewall
description Dallas
description Georgia
access-list outside_1_cryptomap extended permit ip object Dallas object Georgia
access-list outside_cryptomap extended permit ip object Georgia object Dallas
pager lines 24
logging enable
mtu inside 1500
mtu outside 1500
no failover
arp timeout 14400
nat (inside,outside) source static any interface destination static obj_any any
nat (any,outside) source dynamic any interface
nat (inside,outside) source static Georgia Georgia destination static Dallas Dallas no-proxy-arp route-lookup
route outside 0.0.0.0 0.0.0.0 173.227.90.193 1
http server enable
http 10.180.2.0 255.255.255.0 inside
crypto map outside_map 1 set peer 71.123.179.111
crypto map outside_map 1 set ikev2 ipsec-proposal AES256 AES192 AES 3DES DES
crl configure
crypto ca certificate chain _SmartCallHome_ServerCA
certificate ca 6ecc7aa5a7032009b8cebcf4e952d491
    308205ec 308204d4 a0030201 0202106e cc7aa5a7 032009b8 cebcf4e9 52d49130
    0d06092a 864886f7 0d010105 05003081 ca310b30 09060355 04061302 55533117
    30150603 55040a13 0e566572 69536967 6e2c2049 6e632e31 1f301d06 0355040b
    13165665 72695369 676e2054 72757374 204e6574 776f726b 313a3038 06035504
    0b133128 63292032 30303620 56657269 5369676e 2c20496e 632e202d 20466f72
    20617574 686f7269 7a656420 75736520 6f6e6c79 31453043 06035504 03133c56
    65726953 69676e20 436c6173 73203320 5075626c 69632050 72696d61 72792043
    65727469 66696361 74696f6e 20417574 686f7269 7479202d 20473530 1e170d31
    30303230 38303030 3030305a 170d3230 30323037 32333539 35395a30 81b5310b
    30090603 55040613 02555331 17301506 0355040a 130e5665 72695369 676e2c20
    496e632e 311f301d 06035504 0b131656 65726953 69676e20 54727573 74204e65
    74776f72 6b313b30 39060355 040b1332 5465726d 73206f66 20757365 20617420
    68747470 733a2f2f 7777772e 76657269 7369676e 2e636f6d 2f727061 20286329
    3130312f 302d0603 55040313 26566572 69536967 6e20436c 61737320 33205365
    63757265 20536572 76657220 4341202d 20473330 82012230 0d06092a 864886f7
    0d010101 05000382 010f0030 82010a02 82010100 b187841f c20c45f5 bcab2597
    a7ada23e 9cbaf6c1 39b88bca c2ac56c6 e5bb658e 444f4dce 6fed094a d4af4e10
    9c688b2e 957b899b 13cae234 34c1f35b f3497b62 83488174 d188786c 0253f9bc
    7f432657 5833833b 330a17b0 d04e9124 ad867d64 12dc744a 34a11d0a ea961d0b
    15fca34b 3bce6388 d0f82d0c 948610ca b69a3dca eb379c00 48358629 5078e845
    63cd1941 4ff595ec 7b98d4c4 71b350be 28b38fa0 b9539cf5 ca2c23a9 fd1406e8
    18b49ae8 3c6e81fd e4cd3536 b351d369 ec12ba56 6e6f9b57 c58b14e7 0ec79ced
    4a546ac9 4dc5bf11 b1ae1c67 81cb4455 33997f24 9b3f5345 7f861af3 3cfa6d7f
    81f5b84a d3f58537 1cb5a6d0 09e4187b 384efa0f 02030100 01a38201 df308201
    db303406 082b0601 05050701 01042830 26302406 082b0601 05050730 01861868
    7474703a 2f2f6f63 73702e76 65726973 69676e2e 636f6d30 12060355 1d130101
    ff040830 060101ff 02010030 70060355 1d200469 30673065 060b6086 480186f8
    45010717 03305630 2806082b 06010505 07020116 1c687474 70733a2f 2f777777
    2e766572 69736967 6e2e636f 6d2f6370 73302a06 082b0601 05050702 02301e1a
    1c687474 70733a2f 2f777777 2e766572 69736967 6e2e636f 6d2f7270 61303406
    03551d1f 042d302b 3029a027 a0258623 68747470 3a2f2f63 726c2e76 65726973
    69676e2e 636f6d2f 70636133 2d67352e 63726c30 0e060355 1d0f0101 ff040403
    02010630 6d06082b 06010505 07010c04 61305fa1 5da05b30 59305730 55160969
    6d616765 2f676966 3021301f 30070605 2b0e0302 1a04148f e5d31a86 ac8d8e6b
    c3cf806a d448182c 7b192e30 25162368 7474703a 2f2f6c6f 676f2e76 65726973
    69676e2e 636f6d2f 76736c6f 676f2e67 69663028 0603551d 11042130 1fa41d30
    1b311930 17060355 04031310 56657269 5369676e 4d504b49 2d322d36 301d0603
    551d0e04 1604140d 445c1653 44c1827e 1d20ab25 f40163d8 be79a530 1f060355
    1d230418 30168014 7fd365a7 c2ddecbb f03009f3 4339fa02 af333133 300d0609
    2a864886 f70d0101 05050003 82010100 0c8324ef ddc30cd9 589cfe36 b6eb8a80
    4bd1a3f7 9df3cc53 ef829ea3 a1e697c1 589d756c e01d1b4c fad1c12d 05c0ea6e
    b2227055 d9203340 3307c265 83fa8f43 379bea0e 9a6c70ee f69c803b d937f47a
    6decd018 7d494aca 99c71928 a2bed877 24f78526 866d8705 404167d1 273aeddc
    481d22cd 0b0b8bbc f4b17bfd b499a8e9 762ae11a 2d876e74 d388dd1e 22c6df16
    b62b8214 0a945cf2 50ecafce ff62370d ad65d306 4153ed02 14c8b558 28a1ace0
    5becb37f 954afb03 c8ad26db e6667812 4ad99f42 fbe198e6 42839b8f 8f6724e8
    6119b5dd cdb50b26 058ec36e c4c875b8 46cfe218 065ea9ae a8819a47 16de0c28
    6c2527b9 deb78458 c61f381e a4c4cb66
  quit
encryption aes-256
integrity sha
group 5 2
prf sha
encryption aes-192
integrity sha
group 5 2
prf sha
encryption aes
integrity sha
group 5 2
prf sha
encryption 3des
integrity sha
group 5 2
prf sha
encryption des
integrity sha
group 5 2
prf sha
encryption aes-256
hash sha
group 2
lifetime 86400
encryption aes-256
hash sha
group 2
lifetime 86400
encryption aes-192
hash sha
group 2
lifetime 86400
encryption aes-192
hash sha
group 2
lifetime 86400
encryption aes-192
hash sha
group 2
lifetime 86400
encryption aes
hash sha
group 2
lifetime 86400
encryption aes
hash sha
group 2
lifetime 86400
encryption aes
hash sha
group 2
lifetime 86400
encryption 3des
hash sha
group 2
lifetime 86400
encryption 3des
hash sha
group 2
lifetime 86400
encryption des
hash sha
group 2
lifetime 86400
encryption des
hash sha
group 2
lifetime 86400
encryption des
hash sha
group 2
lifetime 86400
telnet 10.180.2.0 255.255.255.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 10.180.2.51-10.180.2.254 inside
dhcpd dns 216.136.95.2 64.132.94.250 interface inside
dhcpd enable inside
dhcpd dns 216.136.95.2 64.132.94.250 interface outside
no threat-detection basic-threat
webvpn
group-policy GroupPolicy_71.123.179.111 internal
group-policy GroupPolicy_71.123.179.111 attributes
tunnel-group 71.123.179.111 type ipsec-l2l
tunnel-group 71.123.179.111 general-attributes
default-group-policy GroupPolicy_71.123.179.111
tunnel-group 71.123.179.111 ipsec-attributes
class-map inspection_default
match default-inspection-traffic
parameters
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect icmp
service-policy global_policy global
Cryptochecksum:8bf23063c95795ec4cd59cc0e051097f
: end
5 Replies 5
BRANDON BAILEY
The public IP address at both sites is the same.
Sorry. Pasted same config twice. Just updated discussion with config from both sites, Thanks for your time
BRANDON BAILEY
Did you capture any logs or un some debug commands? example: debug crypto ikev1 or ikev2 and debug crypto ipsec
I am fairly new to cisco. I dont have a direct terminal connection. I ran the debug command above and through the GUI I saved these two log files. When I started logging I sent a ping packet to the other side. I can see that the Dallas location attempted to create a tunnel. When I did the same thing from Georgia it did not appear to even attempt to create a tunnel. The other thing I am seeing is that on the Georgia ASA under monitoring->VPN->Sessions there is no status to the right. On the Dallas side I see that there is 1 inactive tunnel. Any suggestions
Log file from Dallas:
6|Jan 23 2013|13:43:28|106015|209.221.63.27|143|71.123.179.111|2347|Deny TCP (no connection) from 209.221.63.27/143 to 71.123.179.111/2347 flags FIN ACK  on interface outside
6|Jan 23 2013|13:43:28|302014|209.221.63.27|143|10.180.1.55|2347|Teardown TCP connection 37396 for outside:209.221.63.27/143 to inside:10.180.1.55/2347 duration 0:00:04 bytes 1603 TCP FINs
6|Jan 23 2013|13:43:28|302013|10.180.1.55|2348|209.221.63.27|143|Built outbound TCP connection 37398 for outside:209.221.63.27/143 (209.221.63.27/143) to inside:10.180.1.55/2348 (71.123.179.111/2348)
7|Jan 23 2013|13:43:26|752008|||||Duplicate entry already in Tunnel Manager
6|Jan 23 2013|13:43:24|302013|10.180.1.55|2347|209.221.63.27|143|Built outbound TCP connection 37396 for outside:209.221.63.27/143 (209.221.63.27/143) to inside:10.180.1.55/2347 (71.123.179.111/2347)
6|Jan 23 2013|13:43:22|302013|10.180.1.55|2346|209.221.63.27|143|Built outbound TCP connection 37395 for outside:209.221.63.27/143 (209.221.63.27/143) to inside:10.180.1.55/2346 (71.123.179.111/2346)
7|Jan 23 2013|13:43:21|752008|||||Duplicate entry already in Tunnel Manager
6|Jan 23 2013|13:43:21|302014|209.221.62.17|80|10.180.1.58|2982|Teardown TCP connection 37393 for outside:209.221.62.17/80 to inside:10.180.1.58/2982 duration 0:00:00 bytes 1387 TCP FINs
6|Jan 23 2013|13:43:21|302013|10.180.1.58|2982|209.221.62.17|80|Built outbound TCP connection 37393 for outside:209.221.62.17/80 (209.221.62.17/80) to inside:10.180.1.58/2982 (71.123.179.111/2982)
6|Jan 23 2013|13:43:18|302014|209.221.62.17|80|10.180.1.58|2981|Teardown TCP connection 37392 for outside:209.221.62.17/80 to inside:10.180.1.58/2981 duration 0:00:00 bytes 668 TCP FINs
6|Jan 23 2013|13:43:17|302013|10.180.1.58|2981|209.221.62.17|80|Built outbound TCP connection 37392 for outside:209.221.62.17/80 (209.221.62.17/80) to inside:10.180.1.58/2981 (71.123.179.111/2981)
7|Jan 23 2013|13:43:16|752008|||||Duplicate entry already in Tunnel Manager
6|Jan 23 2013|13:43:14|302014|209.221.62.17|80|10.180.1.58|2978|Teardown TCP connection 37390 for outside:209.221.62.17/80 to inside:10.180.1.58/2978 duration 0:00:02 bytes 59217 TCP FINs
6|Jan 23 2013|13:43:12|302013|10.180.1.58|2978|209.221.62.17|80|Built outbound TCP connection 37390 for outside:209.221.62.17/80 (209.221.62.17/80) to inside:10.180.1.58/2978 (71.123.179.111/2978)
7|Jan 23 2013|13:43:12|752008|||||Duplicate entry already in Tunnel Manager
6|Jan 23 2013|13:43:07|302014|209.221.63.27|143|10.180.1.55|2328|Teardown TCP connection 37129 for outside:209.221.63.27/143 to inside:10.180.1.55/2328 duration 0:10:40 bytes 17496 TCP FINs
6|Jan 23 2013|13:43:04|302014|209.221.62.17|80|10.180.1.58|2977|Teardown TCP connection 37388 for outside:209.221.62.17/80 to inside:10.180.1.58/2977 duration 0:00:01 bytes 28170 TCP FINs
6|Jan 23 2013|13:43:02|302013|10.180.1.58|2977|209.221.62.17|80|Built outbound TCP connection 37388 for outside:209.221.62.17/80 (209.221.62.17/80) to inside:10.180.1.58/2977 (71.123.179.111/2977)
6|Jan 23 2013|13:43:01|302014|209.221.62.17|80|10.180.1.58|2976|Teardown TCP connection 37387 for outside:209.221.62.17/80 to inside:10.180.1.58/2976 duration 0:00:00 bytes 668 TCP FINs
6|Jan 23 2013|13:43:01|302013|10.180.1.58|2976|209.221.62.17|80|Built outbound TCP connection 37387 for outside:209.221.62.17/80 (209.221.62.17/80) to inside:10.180.1.58/2976 (71.123.179.111/2976)
7|Jan 23 2013|13:43:00|609002|64.74.126.6||||Teardown local-host outside:64.74.126.6 duration 1:12:35
7|Jan 23 2013|13:42:58|710005|10.180.1.58|3266|71.123.179.111|52698|UDP request discarded from 10.180.1.58/3266 to inside:71.123.179.111/52698
7|Jan 23 2013|13:42:52|609002|118.2.120.3||||Teardown local-host outside:118.2.120.3 duration 0:10:26
7|Jan 23 2013|13:42:50|609002|74.125.227.101||||Teardown local-host outside:74.125.227.101 duration 1:20:36
7|Jan 23 2013|13:42:49|752008|||||Duplicate entry already in Tunnel Manager
7|Jan 23 2013|13:42:46|609002|64.74.103.184||||Teardown local-host outside:64.74.103.184 duration 0:12:34
6|Jan 23 2013|13:42:46|302014|23.66.230.74|80|10.180.1.55|2320|Teardown TCP connection 37080 for outside:23.66.230.74/80 to inside:10.180.1.55/2320 duration 0:13:01 bytes 2591 FIN Timeout
7|Jan 23 2013|13:42:44|752008|||||Duplicate entry already in Tunnel Manager
7|Jan 23 2013|13:42:39|752008|||||Duplicate entry already in Tunnel Manager
7|Jan 23 2013|13:42:38|609002|74.125.227.130||||Teardown local-host outside:74.125.227.130 duration 1:12:35
7|Jan 23 2013|13:42:38|609002|74.125.227.73||||Teardown local-host outside:74.125.227.73 duration 1:12:35
6|Jan 23 2013|13:42:35|302015|71.123.179.111|500|173.227.90.194|500|Built outbound UDP connection 37383 for outside:173.227.90.194/500 (173.227.90.194/500) to identity:71.123.179.111/500 (71.123.179.111/500)
5|Jan 23 2013|13:42:34|750001|||||Local:71.123.179.111:500 Remote:173.227.90.194:500 Username:Unknown Received request to establish an IPsec tunnel; local traffic selector = Address Range: 10.180.1.3-10.180.1.3 Protocol: 0 Port Range: 0-65535; remote traffic selector = Address Range: 10.180.2.1-10.180.2.1 Protocol: 0 Port Range: 0-65535
5|Jan 23 2013|13:42:34|752003|||||Tunnel Manager dispatching a KEY_ACQUIRE message to IKEv2.  Map Tag = outside_map.  Map Sequence Number = 1.
7|Jan 23 2013|13:42:34|609001|10.180.2.1||||Built local-host outside:10.180.2.1
7|Jan 23 2013|13:42:32|609002|192.150.19.49||||Teardown local-host outside:192.150.19.49 duration 1:52:40
7|Jan 23 2013|13:42:32|609002|10.180.2.1||||Teardown local-host outside:10.180.2.1 duration 0:10:42
7|Jan 23 2013|13:42:32|609002|98.138.47.63||||Teardown local-host outside:98.138.47.63 duration 1:52:41
7|Jan 23 2013|13:42:29|609002|184.84.130.70||||Teardown local-host outside:184.84.130.70 duration 1:12:35
Log file from Georgia:
7|Jan 23 2013|13:47:49|609002|10.180.1.1||||Teardown local-host outside:10.180.1.1 duration 0:00:02
6|Jan 23 2013|13:47:49|302021|10.180.1.1|0|10.180.2.2|1|Teardown ICMP connection for faddr 10.180.1.1/0 gaddr 173.227.90.194/1 laddr 10.180.2.2/1
6|Jan 23 2013|13:47:47|302020|10.180.2.2|1|10.180.1.1|0|Built outbound ICMP connection for faddr 10.180.1.1/0 gaddr 173.227.90.194/1 laddr 10.180.2.2/1
7|Jan 23 2013|13:47:47|609001|10.180.1.1||||Built local-host outside:10.180.1.1
7|Jan 23 2013|13:47:44|609002|10.180.1.1||||Teardown local-host outside:10.180.1.1 duration 0:00:02
6|Jan 23 2013|13:47:44|302021|10.180.1.1|0|10.180.2.2|1|Teardown ICMP connection for faddr 10.180.1.1/0 gaddr 173.227.90.194/1 laddr 10.180.2.2/1
6|Jan 23 2013|13:47:42|302020|10.180.2.2|1|10.180.1.1|0|Built outbound ICMP connection for faddr 10.180.1.1/0 gaddr 173.227.90.194/1 laddr 10.180.2.2/1
7|Jan 23 2013|13:47:42|609001|10.180.1.1||||Built local-host outside:10.180.1.1
7|Jan 23 2013|13:47:40|609002|10.180.1.1||||Teardown local-host outside:10.180.1.1 duration 0:00:02
6|Jan 23 2013|13:47:40|302021|10.180.1.1|0|10.180.2.2|1|Teardown ICMP connection for faddr 10.180.1.1/0 gaddr 173.227.90.194/1 laddr 10.180.2.2/1
6|Jan 23 2013|13:47:38|302020|10.180.2.2|1|10.180.1.1|0|Built outbound ICMP connection for faddr 10.180.1.1/0 gaddr 173.227.90.194/1 laddr 10.180.2.2/1
7|Jan 23 2013|13:47:38|609001|10.180.1.1||||Built local-host outside:10.180.1.1
7|Jan 23 2013|13:47:30|609002|10.180.1.1||||Teardown local-host outside:10.180.1.1 duration 0:00:02
6|Jan 23 2013|13:47:30|302021|10.180.1.1|0|10.180.2.2|1|Teardown ICMP connection for faddr 10.180.1.1/0 gaddr 173.227.90.194/1 laddr 10.180.2.2/1
6|Jan 23 2013|13:47:28|302020|10.180.2.2|1|10.180.1.1|0|Built outbound ICMP connection for faddr 10.180.1.1/0 gaddr 173.227.90.194/1 laddr 10.180.2.2/1
7|Jan 23 2013|13:47:28|609001|10.180.1.1||||Built local-host outside:10.180.1.1
7|Jan 23 2013|13:47:25|609002|10.180.1.1||||Teardown local-host outside:10.180.1.1 duration 0:00:02
6|Jan 23 2013|13:47:25|302021|10.180.1.1|0|10.180.2.2|1|Teardown ICMP connection for faddr 10.180.1.1/0 gaddr 173.227.90.194/1 laddr 10.180.2.2/1
6|Jan 23 2013|13:47:23|302020|10.180.2.2|1|10.180.1.1|0|Built outbound ICMP connection for faddr 10.180.1.1/0 gaddr 173.227.90.194/1 laddr 10.180.2.2/1
7|Jan 23 2013|13:47:23|609001|10.180.1.1||||Built local-host outside:10.180.1.1
7|Jan 23 2013|13:47:20|609002|10.180.1.1||||Teardown local-host outside:10.180.1.1 duration 0:00:02
6|Jan 23 2013|13:47:20|302021|10.180.1.1|0|10.180.2.2|1|Teardown ICMP connection for faddr 10.180.1.1/0 gaddr 173.227.90.194/1 laddr 10.180.2.2/1
6|Jan 23 2013|13:47:18|302020|10.180.2.2|1|10.180.1.1|0|Built outbound ICMP connection for faddr 10.180.1.1/0 gaddr 173.227.90.194/1 laddr 10.180.2.2/1
7|Jan 23 2013|13:47:18|609001|10.180.1.1||||Built local-host outside:10.180.1.1
7|Jan 23 2013|13:47:16|609002|10.180.1.1||||Teardown local-host outside:10.180.1.1 duration 0:00:02
6|Jan 23 2013|13:47:16|302021|10.180.1.1|0|10.180.2.2|1|Teardown ICMP connection for faddr 10.180.1.1/0 gaddr 173.227.90.194/1 laddr 10.180.2.2/1
6|Jan 23 2013|13:47:14|302020|10.180.2.2|1|10.180.1.1|0|Built outbound ICMP connection for faddr 10.180.1.1/0 gaddr 173.227.90.194/1 laddr 10.180.2.2/1
7|Jan 23 2013|13:47:14|609001|10.180.1.1||||Built local-host outside:10.180.1.1
eortiz
Were you able to get this resolved?  I'm running into a similar issue where none of my tunnels are coming up on my secondary ISP.  A debug shows "Duplicate entry already in Tunnel Manager".  Currently running 8.4.5 on my units.  Thanks.
