PPP encapsulation problem
tkachuk.ivan
Community Member
Dear all,
I have two 2801 routers with the 12.4(1c) IOS..
I have two VWIC2-1MFT-T1/E1 cards terminated on HWIC 1 slot..
I need establish E1 link between the routers to transmit IP packets through it..
I am not able to configure the PRI on that..
It takes all the commands required for PRI enabling but for D-channel one I configure the encap as PPP my channel goes down..
I am forwarding following outputs ..
Plz Help.
Router A (network side)
network-clock-participate wic 1
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
no ip dhcp use vrf connected
isdn switch-type primary-net5
controller E1 0/1/0
clock source internal
pri-group timeslots 1-31
interface FastEthernet0/0
ip address 192.168.16.131 255.255.255.0
speed auto
full-duplex
no cdp enable
no mop enabled
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
no cdp enable
interface Serial0/1/0:15
no ip address
(encapsulation ppp) // here's the problem
dialer pool-member 1
isdn protocol-emulate network
no fair-queue
interface Dialer0
dialer pool 1
dialer string 310000
dialer-group 1
ip classless
ip http server
access-list 105 permit icmp any any
dialer-list 1 protocol ip permit
control-plane
disable-eadi
Router B (user side)
no mmi pvc
ip subnet-zero
ip cef
controller E1 0/1/0
ip address 192.168.20.1 255.255.255.0
speed auto
full-duplex
no mop enabled
no ip address
shutdown
duplex auto
speed auto
no ip address
(encapsulation ppp)
interface Dialer0
ip address 192.168.1.2 255.255.255.0
dialer pool 1
dialer string 210000
dialer-group 1
ip classless
ip http server
control-plane
disable-eadi
once I configure s0/1/0:15 as encap PPP
plz note the following output
Cisco1#sh isdn sta
Global ISDN Switchtype = primary-net5
ISDN Serial0/1/0:15 interface
******* Network side configuration *******
dsl 0, interface ISDN Switchtype = primary-net5
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0xFFFF7FFF
Number of L2 Discards = 0, L2 Session ID = 28
Total Allocated ISDN CCBs = 0
debug isdn q921 output:
*Sep 7 15:46:15.791: ISDN Se0/1/0:15 Q921: L2_EstablishDataLink: sending SABME
*Sep 7 15:46:15.791: ISDN Se0/1/0:15 Q921: Net TX -> SABMEp sapi=0 tei=0
*Sep 7 15:46:16.791: ISDN Se0/1/0:15 Q921: Net TX -> SABMEp sapi=0 tei=0
*Sep 7 15:46:17.791: ISDN Se0/1/0:15 Q921: Net TX -> SABMEp sapi=0 tei=0
*Sep 7 15:46:18.791: ISDN Se0/1/0:15 Q921: Net TX -> SABMEp sapi=0 tei=0
*Sep 7 15:46:24.791: ISDN Se0/1/0:15 Q921: L2_EstablishDataLink: sending SABME
*Sep 7 15:46:24.791: ISDN Se0/1/0:15 Q921: Net TX -> SABMEp sapi=0 tei=0
one i remove PPP encap...
It shows Multiple_Frame_Established..
Cud any bode plz tell me how to solve this problem with encapsulation
Urgently needed the answer...
7 Replies 7
drobel
Level 2
Level 2
I did not try such a thing before, but if you are using a dialer, you can not change the layer 2 encapsulation, because it is not a leased line, rather it is a normal pri, with lapd. You can not communicate with the teleco's equipent with ppp.
KInd regards,
Bela
lgijssel
Level 11
Level 11
Probably you have the wrong modules. When you want to set up a point-point connection, you will need the VWIC-xMFT-G703.
Leo
Thanks to all for replies.
But now I don't know what to do at all.
I just need to transmit the data (IP packets) from router A to router B through E1 PRI link with dial-out and dial-in procedures. Any suggestions for that?
And can use HDLC encap on the Serial and Dialer interfaces in this case? Ith that possible, or not?
Thanks In Advance
try the following changes to your configurations:
Router A
controller E1 0/1/0
--> clock source line primary
no ip address
-->encapsulation ppp)
no fair-queue
interface Dialer0
--> encapsulation ppp
dialer pool 1
dialer-group 1
--> ip route 0.0.0.0 0.0.0.0 Dialer0
Router B
controller E1 0/1/0
no ip address
interface Dialer0
dialer pool 1
dialer-group 1
I assume there is a Telco in between your routers, are do you have them configured in a back-to-back setup ?
GNT
Hello
Thank you for your suggestions, however our routers haven't the comand "clock source line primary". They have only:
Cisco1(config-controller)#clock source line ?
bits Bits Clocking
independent Independent Source
Hello Ivan,
try 'clock source line' and see if you get it to work. The idea is to have the provider take care of the clocking, which is typically, if not always, the case...
GNT
Unfortunately, that doesn't work. I tried different ways - line protocol is up only with HDLC encap.
As for a Telco between routers, we have our own Digital Automatic Switching Center, that will be connected between routers. The topology:
LAN1---Cisco1---DASC---Cico2---LAN2
The're no problem with DASC. At present moment, routers are connected directly with each other.
It's interesting to note, that if I configure Controller E1 with 'Channel-group' command, all works perfectly, as with DASC, as without it. I can set encap HDLC or PPP for Serial int - that doesn't matter, files are transmited from LAN1 to LAN2 succesfully.
In any case, thank you everybody. Hope, I'll solve this trouble in the future.
