Problem accessing port 3389 for RDC
info
I want to connect from the ouside to one PC in my VLAN3. The target PC is 192.168.3.175.
Here is details on my access-list 103:
Extended IP access list 103
10 permit udp any any eq bootps
20 permit udp any any eq bootpc
30 permit udp any eq bootps any
40 permit udp any eq bootpc any
50 permit ip 192.168.3.0 0.0.0.255 192.168.3.0 0.0.0.255 (48 matches)
60 permit ip 192.168.3.0 0.0.0.255 host 192.168.2.175
70 permit tcp any host 192.168.3.175 eq 3389
80 permit tcp any 192.168.3.0 0.0.0.255 eq 5900
90 deny ip 192.168.3.0 0.0.0.255 192.168.0.0 0.0.255.255
100 permit ip any any (85 matches)
110 permit tcp any any eq 3389
120 permit tcp any any eq 5900
Here is my ip nat inside:
ip nat inside source static tcp 192.168.3.175 3389 interface Vlan1 3389
Without the IP nat inside command, Remote Desktop Connection tell "unreachable" within 2 seconds. When I enter IP nat command again, it take 30 seconds to tell me it's unreachable.
No firewall in the PC and the connection is working from another PC in the lan.
Any ideas?
Thanks.
Collin Clark
Do you have ip nat inside and outside on the correct interfaces?
try and add the keyword 'extendable' to your NAT statement, and see if that makes a difference:
ip nat inside source static tcp 192.168.3.175 3389 interface Vlan1 3389 extendable
GNT
I'm not familiar with the ip nat outside...
Error is reported when I add "extendable" (^ on the e).
I'll attach my show run with this post. Note that the PC is located at 192.168.3.175 (member of vlan3 that is using access-list 103). I also tried to add port 5900 (for realVNC test) and it's not working either.
The outside IP is a static one: 207.253.66.210.
Thank you so much; I can't find anything.
