06-10-2004 01:02 AM
i have cisco VPN client connecting VPN concentrator through firewall (using TCP 10000)
the PC inside VPN client LAN have problems when browsing to certain web sites. i.e
microsoft (windowsupdate)
im not sure, but it seems that it only allow one connection to these website.
below is the log. please advise
411 06/09/2004 13:36:34.850 SEV=4 IP/57 RPT=54
Packet from 10.48.16.87/0, to 216.239.115.131/0, should be handled by existing session!
628 06/09/2004 19:28:23.490 SEV=4 IP/57 RPT=140
Packet from 10.48.16.85/0, to 211.39.137.157/0, should be handled by existing session!
06-10-2004 01:54 AM
Can you post your configuration please, take out any sensitive information.
Jay
06-10-2004 02:21 AM
the VPN client site is using ADSL connection
|client|--|INTERNET|--|firewall|--|concentrator|
Im not sure which configuration do you want. its all web-base. thank you
06-10-2004 02:48 AM
Are you seeing the error message on the Firewall or Concentrator? Post your Firewall configuration.
Jay
06-10-2004 02:50 AM
i see the message on the Concentrator.
for firewall, i allow TCP port 10000
06-10-2004 10:09 PM
sorry. the message is at VPN hardware client. tq
06-11-2004 07:04 AM
Have you got split-tunnel enabled on your firewall for your crypto ACL? If not then enable this and let me know what happens.
Jay
06-13-2004 11:45 PM
This issue is caused by the MTU setting please adjust the MTU setting to 1452 on your VPN client and should defrag the packets correctly and will be able to browse all the websites
