Problem IPsec Tunnel on Cisco Catalyst 8200L
Dear all
        Please help to find solution for fixed, I replaced C2911 to C8200L using IPSec Tunnel but when I migrate all config.Result that all tunnel is up and IPsec up seem like normal. but some application was not stable.RDP can't use.
8 Replies 8
same reply window 512 but, are c8200L support QoS pre-classify ?
I don't sure , but i copy config from existing device, All Tunnel is up, How I solved this sitiation? What is command qos pre-classify?
interface Tunnel1802
description ### BR802 TOT-HQ-LAOS ###
bandwidth 5120
ip address 10.102.9.1 255.255.255.252
ip mtu 1400
ip tcp adjust-mss 1300
ip ospf 1 area 100
qos pre-classify
keepalive 10 5
tunnel source 10.69.8.254
tunnel destination 10.69.8.2
service-policy output QOS_KSBL_5M
interface Tunnel2802
description ### BR802 HGC-HQ-LAOS ###
bandwidth 5120
ip address 10.102.9.129 255.255.255.252
ip mtu 1400
ip ospf 1 area 100
qos pre-classify
keepalive 10 5
tunnel source 10.89.8.254
tunnel destination 10.89.8.2
@MHM Cisco World  Branch is c8200L before c2911 HQ,is ISR4451
@MHM Cisco World  Now , I rollback Branch Router to C2911 so  all aplication is normal. When i used C8200L ,It have a unstable some application.but all status ospf is normal, ipsec is up,all tunnel is normal. Do you think root cause in this case?
Please explain in more detail what you mean by unstable?
  • is the speed slow?
  • is the application losing connection? If yes, is it losing connection after a certain amount of time each time or is it random?
  • What type of application is this?
Something you could try is changing "ip mtu 1400" to "ip mtu 1360".  You also are limiting the bandwidth, test by removing the bandwidth command on the tunnel interface to see if performance improves.
Please remember to select a correct answer and rate helpful posts
@Marius Gunnerud  Now , I rollback Branch Router to C2911 so all aplication is normal. When i used C8200L ,It have a unstable some application.but all status ospf is normal, ipsec is up,all tunnel is normal. Do you think root cause in this case?
Here is config on Branch(C2911)
interface Tunnel1
description ### xx ###
bandwidth 5120
ip address 10.102.9.2 255.255.255.252
ip mtu 1400
ip flow ingress
ip flow egress
load-interval 30
qos pre-classify
keepalive 10 5
tunnel destination 10.69.8.254
interface Tunnel2
bandwidth 5120
ip address 10.102.9.130 255.255.255.252
ip mtu 1400
ip flow ingress
ip flow egress
load-interval 30
qos pre-classify
keepalive 10 5
tunnel destination 10.89.8.254
Here is COnfig on C8200l (rollback)
interface Tunnel1
bandwidth 5120
ip flow monitor MONITOR input
ip flow monitor MONITOR output
ip mtu 1400
load-interval 30
qos pre-classify
keepalive 10 5
interface Tunnel2
description ###xx ###
bandwidth 5120
ip mtu 1400
load-interval 30
qos pre-classify
keepalive 10 5
HQ
description ### Connect to Branch Tunnel 1###
bandwidth 5120
ip mtu 1400
ip ospf 1 area 100
qos pre-classify
keepalive 10 5
description ### Connect to Branch(TUNNEL2) ###
bandwidth 5120
ip mtu 1400
ip ospf 1 area 100
qos pre-classify
keepalive 10 5
@Marius Gunnerud  For your question
Application X cannot run some station.but try to repeat,can enter it.
Application X release the screen. the screen will show error or hang.
Web Y nornally run by IE11, temporary fixed by using Google Chrome.
Web Z cannot run all browser,but able to run by google chrome,by enter repeat.
