Problem loading AIM-VPN/HPII on C3745
sharan
I tried latest mainline and T train with no success.  Getting the following errors on two identical 3745 routers with 2 identical AIM modules:
on 12.3
*Mar  1 00:01:07.419: %VPN_HW-1-INITFAIL: Slot 1: No ACK for command.., 0x80000000(50000 ms)
*Mar  1 00:01:07.419: %VPN_HW-1-INITFAIL: Slot 1: Making mini_omq failed: 00180010
*Mar  1 00:01:07.419: %VPN_HW-1-INITFAIL: Slot 1: microcode download failure
on 12.4
*Mar  1 00:01:09.995: %VPN_HW-1-INITFAIL: Slot 1: No ACK for command.., 0x80000000(50000 ms)
*Mar  1 00:01:09.995: %VPN_HW-1-INITFAIL: Slot 1: Making mini_omq failed: 00180010After mbox fail:
*Mar  1 00:01:09.995: register base address is: 3A800000
*Mar  1 00:01:09.995: versionid = 00140002
Any suggestions would be appreciated.
AIM Module in slot: 1
        Hardware Revision        : 1.0
        Top Assy. Part Number    : 800-18028-01
        Board Revision           : C0
        Deviation Number         : 0-0
        Fab Version              : 03
        PCB Serial Number        : FOC08101AN8
        RMA Test History         : 00
        RMA Number               : 0-0-0-0
        RMA History              : 00
        Product (FRU) Number     : AIM-VPN/HPII
        Version Identifier       : v01
        EEPROM format version 4
        EEPROM contents (hex):
          0x00: 04 FF 40 03 0B 41 01 00 C0 46 03 20 00 46 6C 01
PAVEL SHEVELEV
Check DRAM, I met this problem if memory modules have different capacity.
PAVEL SHEVELEV
olpeleri
Bad news: Hardware is end of support since 2012. See the URL below.
http://www.cisco.com/en/US/prod/collateral/routers/ps282/prod_end-of-life_notice0900aecd80444877.html
You should not try any new software on such kind of ancient device.... Most likely the support has been removed on latest code.
Cheers,
sharan
Forgot about this posting, it's been a year.  I can confirm mismatching memory caused the issue for me as well, I should have posted a reply back then, sorry.
As far as out of support, yes, I think we all know this.  My car is from 2005, it's also out of support, I probably should replace that as well ;-/.
