Problem setting up remote access VPN alongside Site-to-Site VPNs
iweb_tech
I'm having issues setting up a remote access VPN alongside four site-to-site VPNs. All site-to-site works perfectly and only phase1 of the remote access tunnel is able to complete sucessfully.
i have tried setting the remote access VPN using both the CLI and the ASDM wizard. I'm thinking the site-to-site tunnels are interferring with the remote access VPN.
Here is the "debug crypto isakmp 7" log:
Nov 11 15:01:37 [IKEv1]: IP = 108.163.152.8, IKE_DECODE RECEIVED Message (msgid=0) with payloads : HDR + SA (1) + VENDOR (13) + VENDOR (13) + VENDOR (13) + VENDOR (13) + NONE (0) total length : 312
Nov 11 15:01:37 [IKEv1 DEBUG]: IP = 108.163.152.8, processing SA payload
Nov 11 15:01:37 [IKEv1 DEBUG]: IP = 108.163.152.8, Oakley proposal is acceptable
Nov 11 15:01:37 [IKEv1 DEBUG]: IP = 108.163.152.8, processing VID payload
Nov 11 15:01:37 [IKEv1 DEBUG]: IP = 108.163.152.8, Received Fragmentation VID
Nov 11 15:01:37 [IKEv1 DEBUG]: IP = 108.163.152.8, Received NAT-Traversal ver 02 VID
Nov 11 15:01:37 [IKEv1 DEBUG]: IP = 108.163.152.8, processing IKE SA payload
Nov 11 15:01:37 [IKEv1 DEBUG]: IP = 108.163.152.8, IKE SA Proposal # 1, Transform # 2 acceptable  Matches global IKE entry # 4
Nov 11 15:01:37 [IKEv1 DEBUG]: IP = 108.163.152.8, constructing ISAKMP SA payload
Nov 11 15:01:37 [IKEv1 DEBUG]: IP = 108.163.152.8, constructing NAT-Traversal VID ver 02 payload
Nov 11 15:01:37 [IKEv1 DEBUG]: IP = 108.163.152.8, constructing Fragmentation VID + extended capabilities payload
Nov 11 15:01:37 [IKEv1]: IP = 108.163.152.8, IKE_DECODE SENDING Message (msgid=0) with payloads : HDR + SA (1) + VENDOR (13) + VENDOR (13) + NONE (0) total length : 124
Nov 11 15:01:37 [IKEv1]: IP = 108.163.152.8, IKE_DECODE RECEIVED Message (msgid=0) with payloads : HDR + KE (4) + NONCE (10) + NAT-D (130) + NAT-D (130) + NONE (0) total length : 232
Nov 11 15:01:37 [IKEv1 DEBUG]: IP = 108.163.152.8, processing ke payload
Nov 11 15:01:37 [IKEv1 DEBUG]: IP = 108.163.152.8, processing ISA_KE payload
Nov 11 15:01:37 [IKEv1 DEBUG]: IP = 108.163.152.8, processing nonce payload
Nov 11 15:01:37 [IKEv1 DEBUG]: IP = 108.163.152.8, processing NAT-Discovery payload
Nov 11 15:01:37 [IKEv1 DEBUG]: IP = 108.163.152.8, computing NAT Discovery hash
Nov 11 15:01:37 [IKEv1 DEBUG]: IP = 108.163.152.8, constructing ke payload
Nov 11 15:01:37 [IKEv1 DEBUG]: IP = 108.163.152.8, constructing nonce payload
Nov 11 15:01:37 [IKEv1 DEBUG]: IP = 108.163.152.8, constructing Cisco Unity VID payload
Nov 11 15:01:37 [IKEv1 DEBUG]: IP = 108.163.152.8, constructing xauth V6 VID payload
Nov 11 15:01:37 [IKEv1 DEBUG]: IP = 108.163.152.8, Send IOS VID
Nov 11 15:01:37 [IKEv1 DEBUG]: IP = 108.163.152.8, Constructing ASA spoofing IOS Vendor ID payload (version: 1.0.0, capabilities: 20000001)
Nov 11 15:01:37 [IKEv1 DEBUG]: IP = 108.163.152.8, constructing VID payload
Nov 11 15:01:37 [IKEv1 DEBUG]: IP = 108.163.152.8, Send Altiga/Cisco VPN3000/Cisco ASA GW VID
Nov 11 15:01:37 [IKEv1 DEBUG]: IP = 108.163.152.8, constructing NAT-Discovery payload
Nov 11 15:01:37 [IKEv1]: IP = 108.163.152.8, Connection landed on tunnel_group DefaultRAGroup
Nov 11 15:01:37 [IKEv1 DEBUG]: Group = DefaultRAGroup, IP = 108.163.152.8, Generating keys for Responder...
Nov 11 15:01:37 [IKEv1]: IP = 108.163.152.8, IKE_DECODE SENDING Message (msgid=0) with payloads : HDR + KE (4) + NONCE (10) + VENDOR (13) + VENDOR (13) + VENDOR (13) + VENDOR (13) + NAT-D (130) + NAT-D (130) + NONE (0) total length : 304
Nov 11 15:01:37 [IKEv1]: IP = 108.163.152.8, IKE_DECODE RECEIVED Message (msgid=0) with payloads : HDR + ID (5) + HASH (8) + NONE (0) total length : 67
Nov 11 15:01:37 [IKEv1 DEBUG]: Group = DefaultRAGroup, IP = 108.163.152.8, processing ID payload
Nov 11 15:01:37 [IKEv1 DEBUG]: Group = DefaultRAGroup, IP = 108.163.152.8, processing hash payload
Nov 11 15:01:37 [IKEv1 DEBUG]: Group = DefaultRAGroup, IP = 108.163.152.8, Computing hash for ISAKMP
Nov 11 15:01:37 [IKEv1]: Group = DefaultRAGroup, IP = 108.163.152.8, Automatic NAT Detection Status:     Remote end   IS   behind a NAT device     This   end is NOT behind a NAT device
Nov 11 15:01:37 [IKEv1 DEBUG]: Group = DefaultRAGroup, IP = 108.163.152.8, constructing ID payload
Nov 11 15:01:37 [IKEv1 DEBUG]: Group = DefaultRAGroup, IP = 108.163.152.8, constructing hash payload
Nov 11 15:01:37 [IKEv1 DEBUG]: Group = DefaultRAGroup, IP = 108.163.152.8, constructing dpd vid payload
Nov 11 15:01:37 [IKEv1]: IP = 108.163.152.8, IKE_DECODE SENDING Message (msgid=0) with payloads : HDR + ID (5) + HASH (8) + VENDOR (13) + NONE (0) total length : 84
Nov 11 15:01:37 [IKEv1]: Group = DefaultRAGroup, IP = 108.163.152.8, PHASE 1 COMPLETED
Nov 11 15:01:37 [IKEv1]: IP = 108.163.152.8, Keep-alive type for this connection: None
Nov 11 15:01:37 [IKEv1]: IP = 108.163.152.8, Keep-alives configured on but peer does not support keep-alives (type = None)
Nov 11 15:01:37 [IKEv1 DEBUG]: Group = DefaultRAGroup, IP = 108.163.152.8, Starting P1 rekey timer: 21600 seconds.
Nov 11 15:01:37 [IKEv1]: IP = 108.163.152.8, IKE_DECODE RECEIVED Message (msgid=95fd42c0) with payloads : HDR + HASH (8) + SA (1) + NONCE (10) + ID (5) + ID (5) + NAT-OA (131) + NONE (0) total length : 299
Nov 11 15:01:37 [IKEv1 DEBUG]: Group = DefaultRAGroup, IP = 108.163.152.8, processing SA payload
Nov 11 15:01:37 [IKEv1 DEBUG]: Group = DefaultRAGroup, IP = 108.163.152.8, processing nonce payload
Nov 11 15:01:37 [IKEv1]: Group = DefaultRAGroup, IP = 108.163.152.8, Received remote Proxy Host FQDN in ID Payload:  Host Name: test-vm  Address 0.0.0.0, Protocol 17, Port 1701
Nov 11 15:01:37 [IKEv1]: Group = DefaultRAGroup, IP = 108.163.152.8, Received local Proxy Host data in ID Payload:  Address 70.38.31.202, Protocol 17, Port 1701
Nov 11 15:01:37 [IKEv1]: Group = DefaultRAGroup, IP = 108.163.152.8, L2TP/IPSec session detected.
Nov 11 15:01:37 [IKEv1 DEBUG]: Group = DefaultRAGroup, IP = 108.163.152.8, processing NAT-Original-Address payload
Nov 11 15:01:37 [IKEv1]: Group = DefaultRAGroup, IP = 108.163.152.8, QM IsRekeyed old sa not found by addr
Nov 11 15:01:37 [IKEv1]: Group = DefaultRAGroup, IP = 108.163.152.8, Static Crypto Map check, checking map = outside_map, seq = 1...
Nov 11 15:01:37 [IKEv1]: Group = DefaultRAGroup, IP = 108.163.152.8, Static Crypto Map check, map = outside_map, seq = 1, ACL does not match proxy IDs src:0.0.0.0 dst:70.38.31.202
Nov 11 15:01:37 [IKEv1]: Group = DefaultRAGroup, IP = 108.163.152.8, Static Crypto Map check, checking map = outside_map, seq = 2...
Nov 11 15:01:37 [IKEv1]: Group = DefaultRAGroup, IP = 108.163.152.8, Static Crypto Map check, map = outside_map, seq = 2, ACL does not match proxy IDs src:0.0.0.0 dst:70.38.31.202
Nov 11 15:01:37 [IKEv1]: Group = DefaultRAGroup, IP = 108.163.152.8, Static Crypto Map check, checking map = outside_map, seq = 3...
Nov 11 15:01:37 [IKEv1]: Group = DefaultRAGroup, IP = 108.163.152.8, Static Crypto Map check, map = outside_map, seq = 3, ACL does not match proxy IDs src:0.0.0.0 dst:70.38.31.202
Nov 11 15:01:37 [IKEv1]: Group = DefaultRAGroup, IP = 108.163.152.8, Static Crypto Map check, checking map = outside_map, seq = 4...
Nov 11 15:01:37 [IKEv1]: Group = DefaultRAGroup, IP = 108.163.152.8, Static Crypto Map check, map = outside_map, seq = 4, ACL does not match proxy IDs src:0.0.0.0 dst:70.38.31.202
Nov 11 15:01:37 [IKEv1]: Group = DefaultRAGroup, IP = 108.163.152.8, Rejecting IPSec tunnel: no matching crypto map entry for remote proxy 0.0.0.0/0.0.0.0/17/0 local proxy 70.38.31.202/255.255.255.255/17/1701 on interface outside
Nov 11 15:01:37 [IKEv1 DEBUG]: Group = DefaultRAGroup, IP = 108.163.152.8, sending notify message
Nov 11 15:01:37 [IKEv1 DEBUG]: Group = DefaultRAGroup, IP = 108.163.152.8, constructing blank hash payload
Nov 11 15:01:37 [IKEv1 DEBUG]: Group = DefaultRAGroup, IP = 108.163.152.8, constructing qm hash payload
Nov 11 15:01:37 [IKEv1]: IP = 108.163.152.8, IKE_DECODE SENDING Message (msgid=4c11ba7e) with payloads : HDR + HASH (8) + NOTIFY (11) + NONE (0) total length : 352
Nov 11 15:01:37 [IKEv1]: Group = DefaultRAGroup, IP = 108.163.152.8, QM FSM error (P2 struct &0xca511100, mess id 0x95fd42c0)!
Nov 11 15:01:37 [IKEv1 DEBUG]: Group = DefaultRAGroup, IP = 108.163.152.8, IKE QM Responder FSM error history (struct &0xca511100)  <state>, <event>:  QM_DONE, EV_ERROR-->QM_BLD_MSG2, EV_NEGO_SA-->QM_BLD_MSG2, EV_IS_REKEY-->QM_BLD_MSG2, EV_CONFIRM_SA-->QM_BLD_MSG2, EV_PROC_MSG-->QM_BLD_MSG2, EV_HASH_OK-->QM_BLD_MSG2, NullEvent-->QM_BLD_MSG2, EV_COMP_HASH
Nov 11 15:01:37 [IKEv1 DEBUG]: Group = DefaultRAGroup, IP = 108.163.152.8, sending delete/delete with reason message
Nov 11 15:01:37 [IKEv1]: Group = DefaultRAGroup, IP = 108.163.152.8, Removing peer from correlator table failed, no match!
Nov 11 15:01:37 [IKEv1 DEBUG]: Group = DefaultRAGroup, IP = 108.163.152.8, IKE SA MM:17d9a7b1 rcv'd Terminate: state MM_ACTIVE  flags 0x00000042, refcnt 1, tuncnt 0
Nov 11 15:01:37 [IKEv1 DEBUG]: Group = DefaultRAGroup, IP = 108.163.152.8, IKE SA MM:17d9a7b1 terminating:  flags 0x01000002, refcnt 0, tuncnt 0
Nov 11 15:01:37 [IKEv1 DEBUG]: Group = DefaultRAGroup, IP = 108.163.152.8, constructing IKE delete payload
Nov 11 15:01:37 [IKEv1]: IP = 108.163.152.8, IKE_DECODE SENDING Message (msgid=b1206c64) with payloads : HDR + HASH (8) + DELETE (12) + NONE (0) total length : 80
Nov 11 15:01:37 [IKEv1]: Group = DefaultRAGroup, IP = 108.163.152.8, Session is being torn down. Reason: crypto map policy not found
Nov 11 15:01:38 [IKEv1]: IP = 108.163.152.8, Received encrypted packet with no matching SA, dropping
Nov 11 15:01:40 [IKEv1]: IP = 108.163.152.8, Received encrypted packet with no matching SA, dropping
Nov 11 15:01:44 [IKEv1]: IP = 108.163.152.8, Received encrypted packet with no matching SA, dropping
show running-configuration
cl-t129-05ih# sh run
: Saved
ASA Version 8.3(1)
hostname cl-t129-05ih
domain-name privatedns.com
enable password y1Bc0g0AYjBIerBD encrypted
passwd y1Bc0g0AYjBIerBD encrypted
no names
interface Vlan1
nameif outside
security-level 0
ip address 70.38.31.202 255.255.255.224
interface Vlan2
nameif inside
security-level 100
ip address 10.2.28.1 255.255.255.0
interface Vlan999
nameif dmz
security-level 50
ip address 70.38.15.249 255.255.255.248
interface Ethernet0/0
speed 100
duplex full
interface Ethernet0/1
switchport access vlan 2
interface Ethernet0/2
interface Ethernet0/3
switchport access vlan 999
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
boot system disk0:/asa831-k8.bin
ftp mode passive
clock timezone AST -4
clock summer-time ADT recurring
dns domain-lookup outside
dns domain-lookup inside
dns server-group DefaultDNS
name-server 209.172.41.202
name-server 209.172.41.200
object network obj-10.2.28.0
subnet 10.2.28.0 255.255.255.0
object network obj-192.168.111.0
subnet 192.168.111.0 255.255.255.0
object network obj-192.168.1.76
host 192.168.1.76
object network obj-10.2.28.10
host 10.2.28.10
object network RosenSC1
subnet 172.16.0.0 255.240.0.0
object network obj-10.2.28.11
host 10.2.28.11
object network obj-10.2.28.12
host 10.2.28.12
object network obj-10.2.28.13
host 10.2.28.13
object network obj-10.2.28.14
host 10.2.28.14
object network obj-10.2.28.15
host 10.2.28.15
object network obj_any
subnet 0.0.0.0 0.0.0.0
object network NETWORK_OBJ_10.2.28.0_24
object network NETWORK_OBJ_192.168.111.0_24
object network NETWORK_OBJ_172.16.0.0_12
object network obj-10.2.28.20
host 10.2.28.20
object network obj-10.2.28.21
host 10.2.28.21
object network obj-10.2.28.22
host 10.2.28.22
object network obj-10.2.28.23
host 10.2.28.23
object network obj-10.2.28.30
host 10.2.28.30
object network obj-10.2.28.31
host 10.2.28.31
object network obj-10.2.28.32
host 10.2.28.32
object network obj-10.2.28.33
host 10.2.28.33
object network dmz-subnet
subnet 192.168.2.0 255.255.255.0
object network db-dmz-wan
host 70.38.15.248
object network webserver
host 192.168.2.30
object network webserver-static-nat
host 192.168.2.30
object network WashingtonSq
host 192.168.1.14
object network obj-10.2.28.24
host 10.2.28.24
object network obj-10.2.28.25
host 10.2.28.25
object network NETWORK_OBJ_70.38.15.248_29
subnet 70.38.15.248 255.255.255.248
object network NETWORK_OBJ_71.13.156.64_27
subnet 71.13.156.64 255.255.255.224
object network NETWORK_OBJ_10.10.10.0_24
subnet 10.10.10.0 255.255.255.0
object network NETWORK_OBJ_10.2.28.128_25
subnet 10.2.28.128 255.255.255.128
object network NETWORK_OBJ_10.2.28.224_27
subnet 10.2.28.224 255.255.255.224
object network NETWORK_OBJ_10.2.29.0_24
subnet 10.2.29.0 255.255.255.0
object-group service www_srv tcp
description ssl
port-object eq ftp
port-object eq ssh
port-object eq www
port-object eq https
port-object eq 3389
port-object eq smtp
port-object eq pop3
port-object eq 8443
object-group network www_servers_1
network-object host 10.2.28.10
network-object host 10.2.28.11
network-object host 10.2.28.12
network-object host 10.2.28.13
network-object host 10.2.28.14
network-object host 10.2.28.15
network-object host 10.2.28.20
network-object host 10.2.28.21
network-object host 10.2.28.22
network-object host 10.2.28.23
network-object host 10.2.28.30
network-object host 10.2.28.31
network-object host 10.2.28.32
network-object host 10.2.28.33
network-object host 10.2.28.24
network-object host 10.2.28.25
access-list outside_1_cryptomap extended permit ip 10.2.28.0 255.255.255.0 192.168.111.0 255.255.255.0
access-list outside_2_cryptomap extended permit ip 10.2.28.0 255.255.255.0 172.16.0.0 255.240.0.0
access-list inside_nat0_outbound extended permit ip 10.2.28.0 255.255.255.0 192.168.111.0 255.255.255.0
access-list inside_nat0_outbound extended permit ip 10.2.28.0 255.255.255.0 object RosenSC1
access-list inside_nat0_outbound extended permit ip 10.2.28.0 255.255.255.0 host 192.168.2.76
access-list inside_nat0_outbound extended permit ip host 10.2.28.10 host 192.168.2.76
access-list outside_in extended permit ip 108.163.152.0 255.255.254.0 any
access-list outside_in extended permit ip host 209.172.41.160 any
access-list outside_in remark From RT #6150450 : continuously tries to log into port 3389 (rdp).
access-list outside_in extended deny ip host 112.216.31.116 any
access-list outside_in extended deny ip host 72.46.134.18 any
access-list outside_in extended permit tcp any object-group www_servers_1 object-group www_srv
access-list outside_in extended permit icmp host 209.172.32.36 any
access-list outside_in extended permit tcp host 173.252.62.122 any eq 1433
access-list outside_in extended permit ip 10.2.28.0 255.255.255.0 any
access-list outside_3_cryptomap extended permit ip 10.2.28.0 255.255.255.0 object WashingtonSq
access-list outside_4_cryptomap extended permit ip 70.38.15.248 255.255.255.248 71.13.156.64 255.255.255.224
pager lines 24
logging enable
logging asdm informational
mtu outside 1500
mtu inside 1500
mtu dmz 1500
ip local pool vpn-pool2 10.2.29.100-10.2.29.200 mask 255.255.255.0
ip verify reverse-path interface outside
ip verify reverse-path interface inside
no failover
icmp unreachable rate-limit 1 burst-size 1
icmp permit host 209.172.41.160 echo outside
icmp permit host 209.172.32.36 echo outside
asdm image disk0:/asdm-711-52.bin
no asdm history enable
arp timeout 14400
nat (inside,outside) source static NETWORK_OBJ_10.2.28.0_24 NETWORK_OBJ_10.2.28.0_24 destination static NETWORK_OBJ_192.168.111.0_24 NETWORK_OBJ_192.168.111.0_24
nat (inside,outside) source static NETWORK_OBJ_10.2.28.0_24 NETWORK_OBJ_10.2.28.0_24 destination static NETWORK_OBJ_172.16.0.0_12 NETWORK_OBJ_172.16.0.0_12
nat (inside,outside) source static NETWORK_OBJ_10.2.28.0_24 NETWORK_OBJ_10.2.28.0_24 destination static WashingtonSq WashingtonSq
nat (dmz,outside) source static NETWORK_OBJ_70.38.15.248_29 NETWORK_OBJ_70.38.15.248_29 destination static NETWORK_OBJ_71.13.156.64_27 NETWORK_OBJ_71.13.156.64_27
nat (inside,outside) source static any any destination static NETWORK_OBJ_10.2.29.0_24 NETWORK_OBJ_10.2.29.0_24
nat (inside,outside) dynamic interface
nat (inside,outside) static 70.38.40.177
nat (inside,outside) static 70.38.40.178
nat (inside,outside) static 70.38.40.179
nat (inside,outside) static 70.38.40.180
nat (inside,outside) static 174.142.209.104
nat (inside,outside) static 174.142.209.105
nat (inside,outside) static 174.142.209.106
nat (inside,outside) static 174.142.209.107
nat (inside,outside) static 70.38.40.181
nat (inside,outside) static 70.38.40.182
access-group outside_in in interface outside
route outside 0.0.0.0 0.0.0.0 70.38.31.193 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 0.0.0.0 0.0.0.0 outside
http 0.0.0.0 0.0.0.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
sysopt noproxyarp outside
sysopt noproxyarp inside
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-AES-128-SHA-TRANS esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-SHA-TRANS mode transport
crypto ipsec transform-set ESP-AES-128-MD5-TRANS esp-aes esp-md5-hmac
crypto ipsec transform-set ESP-AES-128-MD5-TRANS mode transport
crypto ipsec transform-set ESP-AES-192-SHA-TRANS esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-SHA-TRANS mode transport
crypto ipsec transform-set ESP-AES-192-MD5-TRANS esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-MD5-TRANS mode transport
crypto ipsec transform-set ESP-AES-256-SHA-TRANS esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-256-SHA-TRANS mode transport
crypto ipsec transform-set ESP-AES-256-MD5-TRANS esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-MD5-TRANS mode transport
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-3DES-SHA-TRANS esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-SHA-TRANS mode transport
crypto ipsec transform-set ESP-3DES-MD5-TRANS esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5-TRANS mode transport
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA-TRANS esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-SHA-TRANS mode transport
crypto ipsec transform-set ESP-DES-MD5-TRANS esp-des esp-md5-hmac
crypto ipsec transform-set ESP-DES-MD5-TRANS mode transport
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs group1
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set transform-set ESP-AES-128-SHA ESP-AES-192-SHA ESP-AES-256-SHA ESP-3DES-SHA ESP-DES-SHA ESP-AES-128-SHA-TRANS ESP-AES-192-SHA-TRANS ESP-AES-256-SHA-TRANS ESP-3DES-SHA-TRANS ESP-DES-SHA-TRANS
crypto map outside_map 1 match address outside_1_cryptomap
crypto map outside_map 1 set pfs group1
crypto map outside_map 1 set peer 173.252.62.122
crypto map outside_map 1 set transform-set ESP-3DES-SHA
crypto map outside_map 2 match address outside_2_cryptomap
crypto map outside_map 2 set pfs group1
crypto map outside_map 2 set peer 216.246.172.4
crypto map outside_map 2 set transform-set ESP-3DES-SHA
crypto map outside_map 3 match address outside_3_cryptomap
crypto map outside_map 3 set peer 206.71.243.34
crypto map outside_map 3 set transform-set ESP-3DES-SHA
crypto map outside_map 4 match address outside_4_cryptomap
crypto map outside_map 4 set peer 71.13.156.125
crypto map outside_map 4 set transform-set ESP-3DES-SHA
crypto map outside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 1
lifetime 86400
crypto isakmp policy 30
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp nat-traversal 10
telnet timeout 5
ssh 0.0.0.0 0.0.0.0 outside
ssh 0.0.0.0 0.0.0.0 inside
ssh timeout 5
ssh version 2
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
ntp server 209.172.41.202 source outside prefer
webvpn
group-policy DefaultRAGroup internal
group-policy DefaultRAGroup attributes
dns-server value 209.172.41.202 209.172.41.200
vpn-tunnel-protocol l2tp-ipsec
default-domain value privatedns.com
username someuser1 password some-encrypted-password nt-encrypted privilege 0
username someuser1 attributes
vpn-group-policy DefaultRAGroup
username someuser2 password some-encrypted-password nt-encrypted privilege 0
username someuser2 attributes
username someuser3 password OIfCCniUgohBqJyX encrypted privilege 15
tunnel-group DefaultL2LGroup ipsec-attributes
isakmp keepalive threshold 20 retry 2
tunnel-group DefaultRAGroup general-attributes
address-pool vpn-pool2
default-group-policy DefaultRAGroup
tunnel-group DefaultRAGroup ipsec-attributes
pre-shared-key *****
tunnel-group DefaultRAGroup ppp-attributes
no authentication chap
authentication ms-chap-v2
tunnel-group 173.252.62.122 type ipsec-l2l
tunnel-group 173.252.62.122 ipsec-attributes
tunnel-group 216.246.172.4 type ipsec-l2l
tunnel-group 216.246.172.4 ipsec-attributes
tunnel-group 206.71.243.34 type ipsec-l2l
tunnel-group 206.71.243.34 ipsec-attributes
tunnel-group 71.13.156.125 type ipsec-l2l
tunnel-group 71.13.156.125 ipsec-attributes
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect netbios
  inspect sunrpc
  inspect sip
  inspect xdmcp
  inspect dns
service-policy global_policy global
prompt hostname context
call-home
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:8bd5d82c383dcd8a248eb6e60061852e
: end
show version
cl-t129-05ih# sh vers
Cisco Adaptive Security Appliance Software Version 8.3(1)
Device Manager Version 7.1(1)52
This platform has an ASA 5505 Security Plus license.
I have been banging my head on the wall for a few days trying to figure this out.
Thanks in advance for any idea you may have.
davrojas
Level 3
Level 3
Hello iweb_tech,
I see the debug states:
And based on your show run:
So if it is :
Wildcard Mask: 0.0.0.7
First Address: 70.38.15.248
Last Address: 70.38.15.255
Or
Wildcard Mask>: 255.255.255.248 same as saying    any.any.any. [248-255]
It seems like neither way does this address 70.38.31.202 seem to fit, can you confirm?
-daVid
This 70.38.31.202 IP and outside_4_cryptomap ACL is used for one of the Site-to-Site VPN. This IP is the peer IP and 70.38.15.248/29 is the "local subnet". We are doing the site-to-site using publicly routable IP addresses so this is why it looks a bit uncommon
Basically, this site-to-site should not interfere with the remote access vpn but it seems like it is...
anyone have any other idea?
Thanks!
The configuration itself seems fine though the thing that causes problems for me personally is the fact that this seems to be supposed to use L2TP/IPsec which I have never used.
The configuration guide seems to suggest that your configuration is pretty much done by the book so I don't really know what the problem is.
It does say it doesnt match anything configured on your firewall
Have you considered using the Cisco VPN Client software (or some 3rd party IPsec VPN Client software) to connect to the ASA?
- Jouni
