Problem with Anyconnect 4.7 and management tunnel
mabrill
hello,
the management tunnel is working well on our system.
If I add the fix from microsoft  to disable IPv6 on all nontunnel interfaces (some other reason I need to use this fix) (https://support.microsoft.com/en-us/help/929852/guidance-for-configuring-ipv6-in-windows-for-advanced-users) I get the following error:
Date : 02/21/2019
Time : 10:44:35
Type : Error
Source : acvpnagent
Description : Function: CCvcConfig::validateMgmtTunParameters
File: vpnconfig.cpp
Line: 3641
Block-all IPv6 is not supported for management tunnel
Date : 02/21/2019
Time : 10:44:35
Type : Error
Source : acvpnagent
Description : Function: CCvcConfig::setConfig
File: vpnconfig.cpp
Line: 1736
Invoked Function: CCvcConfig::validateMgmtTunParameters
Return Code: -33095617 (0xFE07003F)
Description: CVCCONFIG_ERROR_INVALID_MGMT_TUN_CONFIG
So, does that mean disable ipv6 in Windows is not supported ?
(the client bypass protocol is enabled in GP)
Thanks!
0 Replies 0
