Problem with AnyConnect Secure Mobility Client Downloader.
Ciscotinkadm
I've configured our ASA 5510 8.4(3) for remote client VPN using AnyConnect SSL.
I enter the URL for the WebVPN portal, I click on the "Start AnyConnect" link and I get the following error:
"Cannot update AnyConnect Secure Mobility Client 3.0.5080 because the file server is not enabled on the secure gateway. A VPN connection cannot be established."
I'm including my runnig config as well as show version.  Just in case it may be a license issue.  Any help would be greatly appreciated.
------ Running Config -------
: Saved
ASA Version 8.4(3)
hostname XXXXXXXXXX
domain-name XXXXXXXXXX
enable password XXXXXXXXXX encrypted
passwd XXXXXXXXXX encrypted
names
interface Ethernet0/0
nameif phys_0
security-level 0
no ip address
interface Ethernet0/0.511
vlan 511
nameif mtl-web2
security-level 0
ip address 64.254.250.30 255.255.255.224
interface Ethernet0/1
no nameif
no security-level
no ip address
interface Ethernet0/1.513
vlan 513
nameif mtl-srv
security-level 100
ip address 192.168.13.253 255.255.255.0
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
shutdown
no nameif
no security-level
no ip address
management-only
boot system disk0:/asa843-k8.bin
ftp mode passive
dns domain-lookup mtl-srv
dns server-group DefaultDNS
name-server 192.168.13.195
name-server 192.168.13.210
domain-name tink.local
same-security-traffic permit inter-interface
object network NETWORK_OBJ_192.168.13.195
host 192.168.13.195
object network obj-192.168.18.0
subnet 192.168.18.0 255.255.255.224
object-group network mtl-srv-net
network-object 192.168.13.0 255.255.255.0
object-group network mtl-voix2-net
network-object 192.168.22.0 255.255.255.0
object-group network ad-hosts
network-object host 192.168.13.195
network-object host 192.168.13.210
object-group network vergo_servers
network-object host 192.168.97.51
object-group network 75-queen
network-object host 69.70.17.36
network-object host 64.254.250.2
network-object host 64.254.250.3
access-list acl_mtl-srv extended permit icmp any any
access-list acl_mtl-srv extended permit ip any any
access-list acl_mtl-srv extended permit udp any any
access-list acl_mtl-web2 extended permit icmp any any
access-list acl_mtl-xcon extended permit icmp any any
access-list acl_mtl-bur extended permit ip object-group mtl-bur-net any
access-list mtl-web2_cryptomap extended permit ip host 192.168.13.195 host 192.168.97.51
access-list mtl-web2 extended permit ip object-group 75-queen host 64.254.250.30
pager lines 24
logging enable
logging buffer-size 100000
logging console debugging
logging monitor debugging
logging buffered debugging
logging asdm debugging
logging class vpn asdm debugging
mtu phys_0 1500
mtu qmgt-inside 1500
mtu mtl-web2 1500
mtu pmgt-inside 1500
mtu mtl-srv 1500
mtu mtl-bur 1500
mtu mtl-xcon 1500
mtu mtl-voix2 1500
mtu management 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-647.bin
no asdm history enable
arp timeout 14400
nat (mtl-srv,mtl-web2) source static obj-192.168.13.0 obj-192.168.13.0 destination static obj-192.168.18.0 obj-192.168.18.0 no-proxy-arp
nat (mtl-srv,mtl-web2) source static NETWORK_OBJ_192.168.13.195 NETWORK_OBJ_192.168.13.195 destination static NETWORK_OBJ_192.168.97.51 NETWORK_OBJ_192.168.97.51
nat (mtl-srv,mtl-voix2) source static mtl-srv-net mtl-srv-net destination static mtl-voix2-net mtl-voix2-net no-proxy-arp route-lookup
nat (mtl-bur,mtl-web2) source dynamic mtl-bur-net interface
nat (mtl-srv,mtl-web2) source dynamic mtl-srv-net interface
nat (mtl-voix2,mtl-web2) source dynamic mtl-voix2-net interface
object network nat-webtest
nat (mtl-srv,mtl-web2) static 64.254.250.25
access-group acl_mtl-web2 in interface mtl-web2
access-group acl_mtl-srv in interface mtl-srv
access-group acl_mtl-xcon in interface mtl-xcon
route mtl-web2 0.0.0.0 0.0.0.0 64.254.250.1 1
route mtl-xcon 192.168.16.0 255.255.254.0 192.168.20.1 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
aaa-server LDAP_SRV_GRP protocol ldap
aaa-server LDAP_SRV_GRP (mtl-srv) host 192.168.13.195
ldap-base-dn dc=tink, dc=local
ldap-scope subtree
ldap-naming-attribute sAMAccountName
ldap-login-password *****
ldap-login-dn CN=svc_asa_vpn,OU=Comptes-Service,OU=Tink,DC=tink,DC=local
server-type microsoft
user-identity default-domain LOCAL
aaa authentication ssh console LOCAL
http server enable
http 192.168.13.0 255.255.255.0 mtl-srv
http 69.70.17.36 255.255.255.255 mtl-web2
no snmp-server location
no snmp-server contact
crypto ipsec ikev1 transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec ikev1 transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec ikev1 transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec ikev2 ipsec-proposal 3DES-SHA
protocol esp encryption 3des
protocol esp integrity sha-1
crypto ipsec ikev2 ipsec-proposal AES256
protocol esp encryption aes-256
protocol esp integrity sha-1 md5
crypto ipsec ikev2 ipsec-proposal AES192
protocol esp encryption aes-192
crypto ipsec ikev2 ipsec-proposal DES
protocol esp encryption des
crypto map mtl-web2_map 1 match address mtl-web2_cryptomap
crypto map mtl-web2_map 1 set peer 216.226.58.234
crypto map mtl-web2_map 1 set ikev1 transform-set ESP-3DES-SHA
crypto map mtl-web2_map interface mtl-web2
crypto ikev2 policy 1
encryption 3des
integrity sha
group 2
prf sha
lifetime seconds 43200
crypto ikev1 enable mtl-web2
crypto ikev1 policy 1
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh 69.70.17.32 255.255.255.248 mtl-web2
ssh 64.250.254.0 255.255.255.224 mtl-web2
ssh 0.0.0.0 0.0.0.0 mtl-srv
ssh 0.0.0.0 0.0.0.0 mtl-xcon
ssh 0.0.0.0 0.0.0.0 management
ssh timeout 15
console timeout 0
no vpn-addr-assign aaa
dhcprelay server 192.168.13.195 mtl-srv
dhcprelay enable mtl-voix2
dhcprelay timeout 60
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
port 8080
enable mtl-web2
anyconnect image disk0:/anyconnect-win-3.0.5080-k9.pkg 1
anyconnect profiles INFRA_CONNECTION_PROFILE disk0:/infraConnection.xml
anyconnect enable
tunnel-group-list enable
group-policy GroupPolicy_216.226.58.234 internal
group-policy GroupPolicy_216.226.58.234 attributes
vpn-tunnel-protocol ikev1
group-policy GROUP_POLICY_1 internal
group-policy GROUP_POLICY_1 attributes
dns-server value 192.168.13.195
dhcp-network-scope 192.168.18.0
vpn-tunnel-protocol ssl-client ssl-clientless
default-domain value tink.local
webvpn
  anyconnect profiles value INFRA_CONNECTION_PROFILE type user
  anyconnect ask enable default anyconnect
username root password WGfb6prWAtYhS8eE encrypted
tunnel-group 216.226.58.234 type ipsec-l2l
tunnel-group 216.226.58.234 general-attributes
default-group-policy GroupPolicy_216.226.58.234
tunnel-group 216.226.58.234 ipsec-attributes
ikev1 pre-shared-key *****
tunnel-group TUNNEL_GROUP_1 type remote-access
tunnel-group TUNNEL_GROUP_1 general-attributes
authentication-server-group LDAP_SRV_GRP
default-group-policy GROUP_POLICY_1
dhcp-server 192.168.13.195
tunnel-group TUNNEL_GROUP_1 webvpn-attributes
group-alias Group1 enable
class-map Voice
match access-list acl_mtl-voix2-voipqos
class-map inspection_default
match default-inspection-traffic
class-map Data
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect icmp
policy-map VoicePolicy
class Voice
  priority
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
call-home
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:271513aac834617dc8432069bbf42e33
: end
-------- Show version  ---------
Licensed features for this platform:
Maximum Physical Interfaces       : Unlimited      perpetual
Maximum VLANs                     : 100            perpetual
Inside Hosts                      : Unlimited      perpetual
Failover                          : Active/Active  perpetual
VPN-DES                           : Enabled        perpetual
VPN-3DES-AES                      : Enabled        perpetual
Security Contexts                 : 2              perpetual
GTP/GPRS                          : Disabled       perpetual
AnyConnect Premium Peers          : 25             perpetual
AnyConnect Essentials             : Disabled       perpetual
Other VPN Peers                   : 250            perpetual
Total VPN Peers                   : 250            perpetual
Shared License                    : Disabled       perpetual
AnyConnect for Mobile             : Disabled       perpetual
AnyConnect for Cisco VPN Phone    : Disabled       perpetual
Advanced Endpoint Assessment      : Disabled       perpetual
UC Phone Proxy Sessions           : 2              perpetual
Total UC Proxy Sessions           : 2              perpetual
Botnet Traffic Filter             : Disabled       perpetual
Intercompany Media Engine         : Disabled       perpetual
This platform has an ASA 5510 Security Plus license.
Regards.
0 Replies 0
