Problem with certificate based authentication using external CA
zoltan.banai
Community Member
I'm setting up webvpn with certificate based authentication.
The authentication works fine when the internal ASA CA server is used as a trustpoint.
However when adding an external CA cert as a trustpoint and using the coresponding client certs for authentication it fails with the following debug message (full debul log attached):
CRYPTO_PKI: Found a suitable authenticated trustpoint ASA Self_Root.
CRYPTO_PKI(make trustedCerts list)
CERT-C: I pkixpath.c(1147) : Error #72eh
CRYPTO_PKI:check_key_usage: ExtendedKeyUsage OID = 1.3.6.1.5.5.7.3.2
CRYPTO_PKI:check_key_usage:Key Usage check OK
CRYPTO_PKI: Certificate validation: Failed, status: 1838. Attempting to retrieve revocation status if necessary
CRYPTO_PKI: PKI Verify Certificate Check Cert Revocation unknown error 1838
CRYPTO_PKI: PKI Verify Certificate error. No trust point found.
revocation-check none and ignore-ssl-keyusage are set to make sure those are not causing further problems during debuging.
Can someone help determing the reason for the cert not being accepted.
Impellent
Community Member
Zoltan,
I have this exact same problem. Did you ever find a resolution?
-Adrian Wilson
For the benefit of anyone finding this, in my case this problem was resolved by reimporting my internal CA's Cert into the ASA.
I suspect I had inadvertently imported an expired CA Cert into the ASA and this rather un-informative error 1838 is trying to tell you this.
