Problem with Easy VPN on Cisco 892
dcsystemautocom
Hello im currently trying to set up an easy VPN server for client - server mode using Cisco Configuration Profesional on the company cisco 892 router.
The problem is, that when i set up the virtual template to be unnumbered to Vlan1 i cant connect to the VPN from cisco client at all.
If on the other hand i set the virtual template to GigabitEthernet0 (internet facing interface) i can connect, but i cannot access any lan resourcess.
I dont have much experience with IOS so i think im making some basic mistakes, heres my running conf, if someone could provide me with help on how to properly configure it i would be greatefull.
Regards.
Building configuration...
Current configuration : 21785 bytes
! Last configuration change at 14:34:21 PCTime Fri Feb 7 2014 by admin
version 15.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname router1
boot-start-marker
boot-end-marker
aqm-register-fnf
security authentication failure rate 3 log
security passwords min-length 6
logging buffered 51200
logging console critical
enable secret 5 xxxxxxxxxxxxxxxxxxxxxxx
aaa new-model
aaa authentication login default local
aaa authentication login ciscocp_vpn_xauth_ml_1 local
aaa authorization exec default local
aaa authorization network ciscocp_vpn_group_ml_1 local
aaa session-id common
clock timezone PCTime 1 0
clock summer-time PCTime date Mar 30 2003 2:00 Oct 26 2003 3:00
crypto pki trustpoint TP-self-signed-1451413265
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1451413265
revocation-check none
rsakeypair TP-self-signed-1451413265
crypto pki certificate chain TP-self-signed-1451413265
certificate self-signed 01
  3082023F 308201A8 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31343531 34313332 3635301E 170D3133 31323237 31333236
  31345A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 34353134
  31333236 3530819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100A553 73F62F4C 6ACF41FC F13097BD 6F2E619D 8E8768FE 9793A630 139AFB17
  8CD0D5DF CEE1CC84 5FB4E877 73A22A84 7E35E490 0D8B3D4D B3A1B6F5 ECAF19EE
  62178A14 9B590C6D 6C5DDF02 117772A8 5845D34A 1766E628 CE8779B6 01E24117
  8DE20143 BABCCC17 F7AFCA78 5EE21F20 3DC957FD F75A4E8A E264D93A D41AB029
  4EF70203 010001A3 67306530 0F060355 1D130101 FF040530 030101FF 30120603
  551D1104 0B300982 07726F75 74657231 301F0603 551D2304 18301680 146257F1
  390A8469 645C3F07 EB21E186 4575C826 55301D06 03551D0E 04160414 6257F139
  0A846964 5C3F07EB 21E18645 75C82655 300D0609 2A864886 F70D0101 04050003
  8181005D 5F038D8C E76C9762 6672B8AA 15FE248D 15F14AD0 875CC3D1 BECDF754
  8BB46400 07A8B5FF DB23495E 6C7A73DA 5B614A68 CC69D2A1 1EB06BC5 C6B18FF1
  9246F5B2 490E5DA5 5C049B07 41CE2A45 97DB981E 7C1F7BE1 0A92665D 4FE3F0D6
  01F7E059 5BEE39AA E26255A7 9574BD65 32F9EA10 831186D8 6FD85DE9 5FCD9706 55CBA2
      quit
no ip source-route
ip dhcp excluded-address 192.168.0.1 192.168.0.171
ip dhcp excluded-address 192.168.0.200 192.168.0.254
ip dhcp pool ccp-pool1
import all
network 192.168.0.0 255.255.255.0
dns-server 194.204.159.1 194.204.152.34
default-router 192.168.0.1
no ip bootp server
ip name-server 194.204.159.1
ip name-server 194.204.152.34
ip cef
no ipv6 cef
archive
log config
  hidekeys
username yyyyy privilege 15 secret 5 yyyyyyyyyyyyyyyyyyyyyyyyyyyyy
username xxxxx privilege 15 secret 5 yyyyyyyyyyyyyyyyyyyyyyyyyyyyy
redundancy
no cdp run
ip tcp synwait-time 10
ip ssh time-out 60
ip ssh authentication-retries 2
class-map type inspect imap match-any ccp-app-imap
match invalid-command
class-map type inspect match-any ccp-cls-protocol-p2p
class-map type inspect match-all sdm-nat--1
match access-group 101
class-map type inspect match-all sdm-nat--2
match access-group 102
class-map type inspect ymsgr match-any ccp-app-yahoo-otherservices
match service any
class-map type inspect msnmsgr match-any ccp-app-msn-otherservices
match service any
class-map type inspect match-any ccp-h323nxg-inspect
match protocol h323-nxg
class-map type inspect match-any ccp-cls-icmp-access
match protocol icmp
match protocol tcp
match protocol udp
class-map type inspect match-any ccp-cls-protocol-im
match protocol ymsgr yahoo-servers
match protocol msnmsgr msn-servers
match protocol aol aol-servers
class-map type inspect aol match-any ccp-app-aol-otherservices
match service any
class-map type inspect match-all ccp-protocol-pop3
match protocol pop3
class-map type inspect match-any ccp-h225ras-inspect
match protocol h225ras
class-map type inspect match-all ccp-Stam2
match access-group name Stam2_Klient
class-map type inspect match-any ccp-h323annexe-inspect
match protocol h323-annexe
class-map type inspect match-any ccp-cls-insp-traffic
match protocol dns
match protocol ftp
match protocol https
match protocol icmp
match protocol imap
match protocol pop3
match protocol netshow
match protocol shell
match protocol realmedia
match protocol rtsp
match protocol smtp
match protocol sql-net
match protocol streamworks
match protocol tftp
match protocol vdolive
match protocol tcp
match protocol udp
class-map type inspect pop3 match-any ccp-app-pop3
class-map type inspect match-any ccp-h323-inspect
match protocol h323
match service text-chat
class-map type inspect match-all ccp-invalid-src
match access-group 100
class-map type inspect http match-any ccp-app-httpmethods
match request method bcopy
match request method bdelete
match request method bmove
match request method bpropfind
match request method bproppatch
match request method connect
match request method copy
match request method delete
match request method edit
match request method getattribute
match request method getattributenames
match request method getproperties
match request method index
match request method lock
match request method mkcol
match request method mkdir
match request method move
match request method notify
match request method options
match request method poll
match request method propfind
match request method proppatch
match request method put
match request method revadd
match request method revlabel
match request method revlog
match request method revnum
match request method save
match request method search
match request method setattribute
match request method startrev
match request method stoprev
match request method subscribe
match request method trace
match request method unedit
match request method unlock
match request method unsubscribe
class-map type inspect match-any ccp-sip-inspect
match protocol sip
class-map type inspect http match-any ccp-http-blockparam
match request port-misuse im
match request port-misuse p2p
match req-resp protocol-violation
class-map type inspect match-all ccp-protocol-imap
match protocol imap
class-map type inspect match-all ccp-protocol-http
match protocol http
class-map type inspect http match-any ccp-http-allowparam
match request port-misuse tunneling
class-map type inspect match-all ccp-insp-traffic
match class-map ccp-cls-insp-traffic
class-map type inspect match-all ccp-protocol-p2p
match class-map ccp-cls-protocol-p2p
match class-map ccp-cls-protocol-im
class-map type inspect match-all ccp-icmp-access
match class-map ccp-cls-icmp-access
policy-map type inspect imap ccp-action-imap
class type inspect imap ccp-app-imap
  log
policy-map type inspect pop3 ccp-action-pop3
class type inspect pop3 ccp-app-pop3
  log
policy-map type inspect im ccp-action-app-im
class type inspect aol ccp-app-aol
  log
  allow
class type inspect msnmsgr ccp-app-msn
  log
  allow
class type inspect ymsgr ccp-app-yahoo
  log
  allow
class type inspect aol ccp-app-aol-otherservices
  log
  reset
class type inspect msnmsgr ccp-app-msn-otherservices
  log
  reset
class type inspect ymsgr ccp-app-yahoo-otherservices
  log
  reset
policy-map type inspect ccp-inspect
class type inspect ccp-invalid-src
  drop log
class type inspect ccp-protocol-http
  inspect
class type inspect ccp-protocol-imap
  inspect
  service-policy imap ccp-action-imap
class type inspect ccp-protocol-pop3
  inspect
  service-policy pop3 ccp-action-pop3
class type inspect ccp-protocol-p2p
  inspect
  inspect
  service-policy im ccp-action-app-im
class type inspect ccp-insp-traffic
  inspect
class type inspect ccp-sip-inspect
  inspect
class type inspect ccp-h323-inspect
  inspect
class type inspect ccp-h323annexe-inspect
  inspect
class type inspect ccp-h225ras-inspect
  inspect
class type inspect ccp-h323nxg-inspect
  inspect
class type inspect ccp-skinny-inspect
  inspect
class class-default
  drop
policy-map type inspect sdm-pol-NATOutsideToInside-1
class type inspect ccp-cls-sdm-pol-NATOutsideToInside-1-2
  inspect
class type inspect ccp-cls-sdm-pol-NATOutsideToInside-1-1
  inspect
class type inspect sdm-nat--1
  inspect
class type inspect sdm-nat--2
  inspect
class type inspect sdm-nat-user-protocol--1-1
  inspect
class class-default
  drop
policy-map type inspect ccp-permit
class class-default
  drop
policy-map type inspect http ccp-action-app-http
class type inspect http ccp-http-blockparam
  log
  reset
class type inspect http ccp-app-httpmethods
  log
  reset
class type inspect http ccp-http-allowparam
  log
  allow
policy-map type inspect p2p ccp-action-app-p2p
policy-map type inspect ccp-permit-icmpreply
class type inspect ccp-icmp-access
  inspect
class class-default
  pass
zone security out-zone
zone security in-zone
zone-pair security ccp-zp-self-out source self destination out-zone
service-policy type inspect ccp-permit-icmpreply
zone-pair security sdm-zp-NATOutsideToInside-1 source out-zone destination in-zone
service-policy type inspect sdm-pol-NATOutsideToInside-1
zone-pair security ccp-zp-in-out source in-zone destination out-zone
service-policy type inspect ccp-inspect
zone-pair security ccp-zp-out-self source out-zone destination self
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp client configuration group yyyyyy
key xxxxxxxxxxxxxx
dns 192.168.0.1
pool SDM_POOL_1
include-local-lan
max-users 5
netmask 255.255.255.0
crypto isakmp profile ciscocp-ike-profile-1
   match identity group yyyyyy
   client authentication list ciscocp_vpn_xauth_ml_1
   isakmp authorization list ciscocp_vpn_group_ml_1
   client configuration address respond
   virtual-template 1
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
mode tunnel
crypto ipsec profile CiscoCP_Profile1
set security-association idle-time 86400
set transform-set ESP-3DES-SHA
set isakmp-profile ciscocp-ike-profile-1
interface BRI0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
encapsulation hdlc
shutdown
isdn termination multidrop
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface FastEthernet4
no ip address
interface FastEthernet5
no ip address
interface FastEthernet6
no ip address
interface FastEthernet7
no ip address
interface FastEthernet8
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
duplex auto
speed auto
interface Virtual-Template1 type tunnel
ip unnumbered Vlan1
tunnel mode ipsec ipv4
tunnel protection ipsec profile CiscoCP_Profile1
interface GigabitEthernet0
description $ES_WAN$$FW_OUTSIDE$
ip address xxxxxxxxxxx 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
ip virtual-reassembly in
zone-member security out-zone
duplex auto
speed auto
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-FE 1$$ES_LAN$$FW_INSIDE$
ip address 192.168.0.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
zone-member security in-zone
ip tcp adjust-mss 1452
ip local pool SDM_POOL_1 10.10.10.0 10.10.10.5
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface GigabitEthernet0 overload
ip sla auto discovery
logging trap debugging
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 192.168.0.0 0.0.0.255
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
banner exec ^C
Have you ruled out that ZFW could be blocking the traffic?  are you in a position where you can remove the zone-pair from the Gig0 and Vlan1 interfaces and test?
Please remember to rate and select a correct answer
Please remember to select a correct answer and rate helpful posts
As we are outside of buisness hours ill try to remove the zone pairs from those interfaces tommorow, i did try to assign the Virtual Template interface to the inside zone earlier, but it did not help.
dcsystemautocom
Removing the zone pairs didnt work so i tried to reconfigure the router.
After reconfiguring the router from scratch without the zone based firewall i get same results, i can connect with the VPN client but cant ping or access any lan resources.
