04-20-2010 01:45 AM
hi
i want to confgure Ezvpn and Site to Site VPN however the problem is that the EasyVpn that only would work the Site to Site is not Working at all
i have configure 1 crypto map for both of VPN with different tagges
i had execlude the traffice for NOT being natted to and when i remove the Ezvpn the site to site work fine
crypto isakmp policy 100
encr aes
hash md5
authentication pre-share
group 2
crypto isakmp policy 10000
encr aes 256
group 5
crypto isakmp key 123456 address (removed)
crypto isakmp client configuration group easyvpn
key easyvpn
domain ezvpn
pool easyvpn
acl easyvpn
save-password
split-dns cme
max-users 9
netmask 255.255.255.0
crypto ipsec transform-set vpn esp-aes 256 esp-sha-hmac
crypto dynamic-map easyvpn 10
set transform-set dmvpn
reverse-route
crypto map easyvpn local-address Dialer1
crypto map easyvpn client authentication list easyvpn
crypto map easyvpn isakmp authorization list easyvpn
crypto map easyvpn client configuration address respond
crypto map easyvpn 100 ipsec-isakmp dynamic easyvpn
crypto map easyvpn 1000 ipsec-isakmp
set peer (removed)
set transform-set vpn
match address site
interface Dialer1
ip address negotiated
ip mtu 1492
ip nat outside
ip virtual-reassembly
encapsulation ppp
dialer pool 1
ppp authentication chap pap callin
ppp chap hostname
ppp chap password
ppp pap sent-username
crypto map easyVPN
ip access-list extended DSL_ACCESSLIST
deny ip 100.0.0.0 0.0.0.255 101.1.1.0 0.0.0.255
deny ip 100.0.0.0 0.0.0.255 70.0.0.0 0.0.0.255
permit ip 100.0.0.0 0.0.0.255 any
deny ip any any
ip access-list extended easyvpn
permit ip 100.0.0.0 0.0.0.255 70.0.0.0 0.0.0.255
ip access-list extended site
permit ip 100.0.0.0 0.0.0.255 101.1.1.0 0.0.0.255
best regards
Solved! Go to Solution.
04-20-2010 03:37 AM
The crypto map sequence number for the static crypto map (site-to-site vpn) should be higher (ie: sequence number should be lower) than the ezvpn (dynamic crypto map).
In your case, you should configure as follows:
crypto map easyvpn 10 ipsec-isakmp
set peer (removed)
match address site
crypto map easyvpn 150 ipsec-isakmp dynamic easyvpn
Hope that resolves the issue.
04-20-2010 03:37 AM
set peer (removed)
match address site
04-20-2010 03:49 AM
Thanks alot it worked just fine
