Problem with ISDN on c2600.
I see a very strange problem with our ISDN slot on c2600 and can't somehow explain it.
If I connect a normal ISDN phone the line is working perfectly but if I connect  ISDN port on our router then ISDN status shows:
#sh isdn status
Global ISDN Switchtype = basic-net3
ISDN BRI1/0 interface
        dsl 0, interface ISDN Switchtype = basic-net3
    Layer 1 Status:
        DEACTIVATED
    Layer 2 Status:
        Layer 2 NOT Activated
    Layer 3 Status:
        0 Active Layer 3 Call(s)
    Active dsl 0 CCBs = 0
    The Free Channel Mask:  0x80000003
    Total Allocated ISDN CCBs = 0
and I can't start a connection, I've tried with help of "isdn test call", it shows an error like "no B chanel available"
If I make an incoming call to the telephone number of that ISDN line then the status of the line changes to "MULTIPLE_FRAME_ESTABLISHED" and I can use the line just normal for Dialer connections.
After some period of time (sometime is hours, sometimes is only a minutes) the Line status  goes again to "DEACTIVATED" and Dialer connection doen't work until I place an incoming call.
The ISDN  Hardware is:
BRI S/T - 2186 WAN daughter card
        Hardware revision 1.3           Board revision A0
        Serial number     19923810      Part number    800-01833-03
        FRU Part Number   WIC-1B-S/T=
BRI configuration:
interface BRI1/0
description isdn-backup
no ip address
encapsulation ppp
dialer pool-member 3
isdn switch-type basic-net3
isdn point-to-point-setup
isdn outgoing display-ie
no cdp enable
router version is 2600-advipservicesk9-mz.124-2.T.bin
I can see the same problem on two different locations, where we use this type of hardware.
Please give some advise. may there is a kind of "keepalive" for BRI interfaces?
15 Replies 15
jefffisher
Here is an old config from when I did a lot of ISDN work. It is on a 2600 series router. Never had any issues. I used 800 series routers to connect back to the 2600.
! Last configuration change at 09:24:49 cst Tue Dec 4 2001
! NVRAM config last updated at 09:24:51 cst Tue Dec 4 2001
version 11.2
service timestamps debug uptime
service timestamps log datetime msec localtime show-timezone
no service udp-small-servers
no service tcp-small-servers
hostname sci-aus
ip subnet-zero
ip name-server 172.16.20.20
isdn switch-type basic-ni1
clock timezone cst -6
clock summer-time cdt recurring
interface Ethernet0
ip address 207.200.40.193 255.255.255.224
interface Ethernet1
ip address 172.16.20.2 255.255.255.128
interface Virtual-Template1
no ip address
no ip mroute-cache
interface Serial0
description To ONR
ip address 207.200.54.6 255.255.255.252
interface Serial1
no ip address
shutdown
interface BRI0
description To Manchaca Village Vet
no ip address
encapsulation ppp
no ip mroute-cache
bandwidth 64
isdn spid1 51291611180101 9161118
isdn spid2 51291611190101 6161119
dialer rotary-group 0
no fair-queue
compress stac
no cdp enable
interface BRI1
no ip address
shutdown
interface BRI2
no ip address
shutdown
interface BRI3
no ip address
shutdown
interface Dialer0
ip address 172.16.20.237 255.255.255.252
encapsulation ppp
no ip mroute-cache
dialer in-band
dialer idle-timeout 900
dialer hold-queue 10
dialer load-threshold 2 either
dialer-group 1
no fair-queue
compress stac
no cdp enable
ppp negotiation-timeout 300
ppp authentication chap
ppp chap hostname sci-vet
ppp chap password 7 010213054802565E
ppp multilink
router rip
version 2
redistribute connected
network 172.16.0.0
network 207.200.40.0
ip classless
ip route 0.0.0.0 0.0.0.0 207.200.54.5
dialer-list 1 protocol ip permit
line con 0
line aux 0
line vty 0 4
login
end
