problem with lifetime parameter on ipsec
amenash123
Level 2
Level 2
hi
when i do show crypto session detail command i get this following massage:
Interface: FastEthernet0/1
Session status: UP-ACTIVE
Peer: 172.30.102.101/500 fvrf: (none) ivrf: (none)
Phase1_id: 172.30.102.101
Desc: (none)
IKE SA: local 172.30.102.102/500 remote 172.30.102.101/500 Active
Capabilities:D connid:84 lifetime:23:55:29
IPSEC FLOW: permit ip 172.30.102.100/255.255.255.252 172.30.102.100/255.255.25
5.252
Active SAs: 2, origin: crypto map
Inbound: #pkts dec'ed 16 drop 0 life (KB/Sec) 4477653/3329
Outbound: #pkts enc'ed 16 drop 4 life (KB/Sec) 4477653/3329
That mean i have a lifetime with as appear in the example : 23:55:29, and after that time the the ipsec is getting down.
how can i disable this life time,that the ipsec(crypto)work allways.
thanks.
jsteffensen
Level 5
Level 5
The IPSEC SA lifetime is a fixed configured parameter that cannot be left out. If you have configured IPSEC correct, and you always have interresting IPSEC traffic (traffic that matches your Crypto ACL) the SA will re-establish the tunnel automatically.
A smaller SA lifetime provides more security because this changes your "connection-keys" more often. But again shortes SA life time provides more overhead to manage the connection.
Be aware that you have 2 lifetime settings:
1 for IKE - Key exchange Phase 1
crypto isakmp policy xxx
lifetime
Default = 24 hours (i believe)
2 for the IPSEC tunnel itselves.
crypto map xxxxx
set security-association lifetime
Default = 1 hour (i believe)
Post your config, and we might help you find your problem.
Geetings
Jarle
