Problem with overlapping subnets on 2 seperate L2L tunnels
martens72
I am going through an ASA audit, and have found Customer A and Customer B have the same subnet in use. The crypto maps permit correct "interesting" traffic for each L2L (Customer network A mapped to remote site A and Customer network B is mapped to remote site B), but I have a monitoring subnet in which I would like to monitor the remote ASA and servers on remote subnet.
I am attaching a diagram to illustrate better. I am not sure if I should be NAT'ing the subnets into the local ASA where the L2L terminates. I don't see how the ASA will know which tunnel to forward monitoring traffic either. If I have to NAT, then my concern would be Customer A being able to use their tunnel to connect to their other 3 tunnels without having to point them at the new NAT block.
Any ideas or thoughts would be appreciated.
you can use NAT to solve your overlapping issue.
Check the following link:
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a0080b37d0b.shtml
