Problem With PRI
farhan.javed
Community Member
Dear All,
I have a 2811 router and I wud like to go for an PRI (ISDN) connectivity on that, however I want that PRI shud be terminated a Serial WIC-1T card using the V.35 interface..
Plz also tell me whether cisco 2811 support PRI or not.. ???
on Which card I or Module it will fixed up..
arvindchari
Level 5
Level 5
Hi Farhan
PRI is supported on the 2811
You can go for any one of the below modules
NM-1CE1T1-PRI 1-port Channelized E1/T1/ISDN-PRI network module
NM-2CE1T1-PRI 2-port Channelized E1/T1/ISDN-PRI network module
If you insist on a serial termination, you will have to use a TA which in most cases is recommended by your telecom service provider.
For serial connectivity you can use any one of the following:
Serial Connectivity Network Modules
NM-1HSSI 1-port High-Speed Serial Interface (HSSI) network module
NM-4A/S 4-port asynchronous/synchronous serial network module
NM-8A/S 8-port asynchronous/synchronous serial network module
NM-16A/S 16-port asynchronous/synchronous serial network nodule
NM-16A 16-port asynchronous serial network module
NM-32A 32-port asynchronous serial network module
The complete list is available on
http://www.cisco.com/en/US/products/ps5854/products_relevant_interfaces_and_modules.html
Now all you need to decide is how many ports do you need 🙂
Please rate posts that help.
Arvind
