Problem with QVpn and RV042
kszarlej94
Hi i have a RV042 vpn router. I want to connect to it through Quick VPN.
I made an account under "VPN Client Access" tab and activated it.
I Unblocked the WAN Requests. My port 500 isnt blocked. Ping requests are ok. When i try to connect from my Windows machine then for several seconds the field "status" in vpn summary under my account is "Active"(the quickvpn is veryfying network) and the I am getting a error "The remote gateway is not responding. Do you want to wait?" and the status in vpn summary is chaning to "offline".
LOGS:
Nov 15 03:13:06 2013     VPN Log     (qknips0) #17: responding to Quick Mode
Nov 15 03:13:06 2013     VPN Log     (qknips0) #17: [Tunnel Negotiation Info] Inbound SPI value = 97ad6623
Nov 15 03:13:06 2013     VPN Log     (qknips0) #17: [Tunnel Negotiation Info] Outbound SPI value = 35da922e
Nov 15 03:13:06 2013     VPN Log     (qknips0) #17: [Tunnel Negotiation Info] >>> Responder send Quick Mode 2nd packet
Nov 15 03:13:06 2013     VPN Log     (qknips0) #17: [Tunnel Negotiation Info] <<< Responder Received Quick Mode 3rd packet
Nov 15 03:13:06 2013     VPN Log     (qknips0) #17: [Tunnel Negotiation Info] Quick Mode Phase 2 SA Established, IPSec Tunnel Connected
Nov 15 03:13:06 2013     VPN Log     (qknips0) #17: IPsec SA established {ESP=>0x35da922e <0x97ad6623
Nov 15 03:16:57 2013     VPN Log     | NAT-T: new mapping my23701/23714)
Nov 15 03:16:57 2013     VPN Log     (qknips0) #17: ERROR: netlink response for Add SA esp.97ad6623@routerip included errno 22: Invalid argument
Nov 15 03:16:57 2013     VPN Log     (qknips0) #16: received Delete SA(0x35da922e) payload: deleting IPSEC State #17
Nov 15 03:16:57 2013     VPN Log     (qknips0) #17: deleting state (STATE_QUICK_R2)
Nov 15 03:16:58 2013     VPN Log     (qknips0) #16: deleting state (STATE_MAIN_R3)
Nov 15 03:16:58 2013     VPN Log     packet from myip:23714: Informational Exchange is for an unknown (expired?) SA
Nov 15 03:16:58 2013     VPN Log     (qknips0): deleting connection
Thanks in Advance, cheers
0 Replies 0
