Problem with VPN using PAT
fembsen
Hi all,
I am working on a site-to-site VPN but I can't get it to work properly. My VPN-endpoint is a PIX515 running OS version 6.3(3) (upgrading to 7 is no option because memory is not sufficient) and the other endpoint is a CheckPoint firewall. The company that I have to make the VPN with requires me to use only one IP address as source so all my outgoing traffic has to be NAT'ted to one single address (PAT to IP address 10.1.1.10, see below).
The config looks something like this:
object-group network dest-servers
network-object 172.16.1.10 255.255.255.255
network-object 172.16.1.11 255.255.255.255
network-object 172.16.1.12 255.255.255.255
network-object 172.16.1.13 255.255.255.255
network-object 172.16.1.14 255.255.255.255
access-list 110 permit ip host 10.1.1.10 object-group dest-servers
access-list vpn-nat permit ip 192.168.1.0 255.255.255.0 object-group dest-servers
global (outside) 1 10.1.1.10
nat (inside) 1 access-list vpn-nat 0 0
sysopt connection permit-ipsec
sysopt ipsec pl-compatible
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto map vpn-tunnel 10 ipsec-isakmp
crypto map vpn-tunnel 10 match address 110
crypto map vpn-tunnel 10 set peer x.x.x.x
crypto map vpn-tunnel 10 set transform-set ESP-3DES-MD5
crypto map vpn-tunnel interface outside
isakmp enable outside
isakmp key 12345678 address x.x.x.x netmask 255.255.255.255
isakmp identity address
isakmp nat-traversal 20
isakmp policy 30 authentication pre-share
isakmp policy 30 encryption 3des
isakmp policy 30 hash md5
isakmp policy 30 group 2
isakmp policy 30 lifetime 86400
No when I try to connect from my PC (192.168.1.100) on the inside to one of the destination addresses (for example 172.16.1.10) the tunnel comes up and I see packets going out and returning ('sh ipsec sa'). Also a an xlate is created for my inside address to the PAT address 10.1.1.10 and in the logs I see that the PIX is translating the returning VPN traffic with destination address 10.1.1.10 (with the correct portrange) back to my inside address 192.168.1.100 (log message 'Building outbound connection for ....', the 'Building outbound' worried me but the documentation states that this is because the session was initiated from inside so it should be right).
Now the problem: Return traffic isn't passing the inside interface. So the tunnel is created and looks ok but when I make, for example, a RDP connection it times out because the PIX doesn't send traffic to my PC.
Can anyone help me?
Best regards,
Frank
tstanik
Level 9
Level 9
Check if you have configured ACL properly for the traffic through the firewall. Configure command "access-list inbound permit rdp any host x.x.x.x".
Thnx for the reply.
I have configured access-lists but that didn't help. Also in the logs of the PIX i don't see any drops of packets.
Any other ideas?
Regards, Frank
