Problems with Flex VPN hub and spoke
emurray
I am doing a lab with FLEX VPN before configuring any production and this is my first Flex VPN but is not coming up.
I ran show monitor event-trace errors all, returning Flex VPN SA ID:0 SESSION ID:0 Failed to initiate sa. On the hub the errors is 500 Negotiation aborted due to ERROR: Failed to authenticate the IKE SA
I have check the  keys and they are the same. Here is my config
Hub
interface Loopback1
ip address 172.16.1.254 255.255.255.255
crypto ikev2 keyring IKEV2_KEYRING
peer SPOKE_ROUTERS
address 0.0.0.0 0.0.0.0
pre-shared key local CISCO
pre-shared key remote CISCO
aaa new-model
aaa authorization network FLEXVPN_LOCAL local
crypto ikev2 name-mangler group_author_name_mangler
fqdn domain
crypto ikev2 authorization policy IKEV2_AUTHORIZATION
route set interface
route set access-list FLEXVPN_ROUTES
ip access-list standard FLEXVPN_ROUTES
permit any
crypto ikev2 profile IKEV2_PROFILE
match identity remote IKEV2_PROFILE domain example.com
identity local fqdn hq.example.com
authentication local pre-share key CISCO
authentication remote pre-share key CISCO
aaa authorization group psk list group_author_list name-mangler group_author_
name_mangler
virtual-template 1 mode auto
interface Virtual-Template1 type tunnel
ip unnumbered Loopback1
tunnel protection ipsec profile IKEV2_PROFILE
Spoke 1
Spoke
peer R8
address 18.1.1..8
pre-shared-key local CISCO
pre-shared-key remote CISCO
aaa new-model
route set interface
permit host 2.2.2.2
match identity remote fqdn hq.example.com
identity local fqdn spk1.example.com
keyring local IKEV2_KEYRING
crypto ipsec profile IPSEC_PROFILE
set ikev2-profile IKEV2_PROFILE
interface Tunnel 0
ip address 172.16.1.1 255.255.255.0
tunnel source GigabitEthernet 0/0
tunnel destination 18.1.1.1.8
tunnel protection ipsec profile IPSEC_PROFILE
@emurray the extracted value from the name mangler is "example.com", you need an authorisation policy called "example.com". Change the existing policy IKEV2_AUTHORIZATION to example.com or don't use the name mangler.
14 Replies 14
@emurray the keys are in different case, which will matter. Please double check. Unless you've just incorrectlyedited for this post?
Hub
crypto ikev2 profile default
 authentication local pre-share key cisco
authentication remote pre-share key cisco
Spoke 1
Spoke
If there is still an issue enable the IKEv2 debugs and provide the full output for review.
It was an incorrect edit for the post. I will do debug when I get home and post it here.
tunnel mode ipsec ipv4 <<- add this under the virtual template AND spoke tunnel.
and in Spoke use local and remote key CISCO(or cisco, it must match with hub).
Thanks A Lot
MHM
the default tunnel mode is gre and does not explictly appear in the running configuration. So by changing the tunnel mode to ipsec of the virtual-template on the hub will mean a mismatch as the spoke would still be gre.
It seems that the error has to do with the Policy. Here are the debug messages
*Nov 11 20:21:44.113: IKEv2-INTERNAL:IKEv2 local AAA author request for 'example.com'
*Nov 11 20:21:44.114: IKEv2-INTERNAL:IKEv2 local AAA - policy 'example.com' does not exist.
*Nov 11 20:21:44.122: IKEv2-INTERNAL:IKEv2 authorization error 4
match identity remote fqdn domain example.com
This must use in hub side.
Add it and check again.
Thanks A Lot
MHM
The identity of the hub is hub.example.com and that is the one that I am referencing on the spoke, but the domain identity is example.com which is what I am referencing on the hub to accept any connexions from that domain
Hub
name_mangler
Spoke
Use this in hub ikev2 profile.
I did and I am now receiving
IKEv2-INTERNAL:Construct Notify Payload: AUTHENTICATION_FAILED
Still this issue not solved ?
If not
Did you use fqdn domain...'as we suggest? If yes
Use below in hub ikev2 profile
aaa authorization group psk list FLEXVPN_LOCAL  IKEV2_AUTHORIZATION
I finally solved by removing and applying the keyring. @Rob Ingram  change with the name mangler solved the issue for me. Thanks for the help
You are welcome' suggestion was dont use mangler.
Anyway glad your lab done and success
Have a nice day.
MHM
MHM
