Problems with inside accessing dmz hosts
lmbaity
I have a pix 515e with three interfaces and I do realize that I have statements for icmp but it is only for debugging.
All inside users are fine browsing outside world.
I can ping dmz webserver from inside to dmz and from outside to dmz.
I can browse website in dmz from outside.
Webserver in dmz can ping and browse outside.
I cannot browse website from inside or ping the public address.
It seems to be a interface transversal problem, I think
I even tried adding these two lines and it did not work
access-list nonat permit ip 10.0.0.0 255.255.255.0 10.0.15.0 255.255.255.0
nat (inside) 0 access-list nonat
This is my current config:
Building configuration...
: Saved
PIX Version 6.3(1)
interface ethernet0 auto
interface ethernet1 auto
interface ethernet2 auto
nameif ethernet0 outside security0
nameif ethernet1 inside security100
nameif ethernet2 dmz security50
enable password encrypted
passwd encrypted
hostname pix1
domain-name your.com
clock timezone CST -6
clock summer-time CDT recurring
fixup protocol domain 53
fixup protocol ftp 21
no fixup protocol h323 h225 1720
no fixup protocol h323 ras 1718-1719
fixup protocol http 80
no fixup protocol ils 389
no fixup protocol rsh 514
fixup protocol rtsp 554
no fixup protocol sip 5060
names
access-list 101 permit icmp any any
access-list 101 permit tcp any host 206.x.x.175 eq www
access-list 201 permit icmp any any
access-list 201 permit tcp 10.0.15.0 255.255.255.0 any eq www
access-list 201 permit tcp 10.0.15.0 255.255.255.0 any eq domain
access-list 201 permit udp 10.0.15.0 255.255.255.0 any eq domain
access-list 201 permit tcp any host 10.0.15.175 eq www
access-list 201 permit icmp any 10.0.0.0 255.255.255.0
access-list 301 permit icmp any any
access-list 301 permit tcp 10.0.0.0 255.255.255.0 any eq www
access-list 301 permit tcp 10.0.0.0 255.255.255.0 any eq https
access-list 301 permit tcp 10.0.0.0 255.255.255.0 any eq ftp
access-list 301 permit tcp 10.0.0.0 255.255.255.0 any eq domain
access-list 301 permit udp 10.0.0.0 255.255.255.0 any eq domain
access-list 301 permit tcp 10.0.0.0 255.255.255.0 any eq 2061
pager lines 24
mtu outside 1500
mtu inside 1500
mtu dmz 1500
ip address outside 206.x.x.130 255.255.x.x
ip address inside 10.0.0.6 255.255.255.0
ip address dmz 10.0.15.1 255.255.255.0
ip verify reverse-path interface outside
ip verify reverse-path interface inside
ip verify reverse-path interface dmz
ip audit info action alarm
ip audit attack action alarm
pdm history enable
arp timeout 14400
global (outside) 1 206.x.x.132-206.x.x.135 netmask 255.255.x.x
global (outside) 1 206.x.x.131
global (dmz) 1 10.0.15.2-10.0.15.8
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
nat (dmz) 1 10.0.15.0 255.255.255.0 0 0
static (inside,dmz) 10.0.0.0 10.0.0.0 netmask 255.255.255.0 0 0
static (dmz,outside) 206.x.x.175 10.0.15.175 netmask 255.255.255.255 0 0
access-group 101 in interface outside
access-group 301 in interface inside
access-group 201 in interface dmz
rip outside default version 1
rip inside default version 2
route outside 0.0.0.0 0.0.0.0 206.x.x.129
route inside 10.0.1.0 255.255.255.0 10.0.0.224 2
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
http server enable
http 10.0.0.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
telnet 10.0.0.0 255.255.255.0 inside
telnet timeout 5
ssh 10.0.0.0 255.255.255.0 inside
ssh timeout 5
console timeout 0
terminal width 80
end
[OK]
pcomeaux
I think the Pix may be confused with all the Xlates you have in the config b/w the inside and the DMZ.
1) static (inside,dmz) 10.0.0.0 10.0.0.0 netmask 255.255.255.0 0 0
2)global (dmz) 1 10.0.15.2-10.0.15.8
3) access-list nonat permit ip 10.0.0.0 255.255.255.0 10.0.15.0 255.255.255.0
It looks like you may have confused the Pix by implementing multiple translation strategies for this network.
If you remove statements in 1 and 3, then clear xlate (affects all connections through Pix), please test your connections from the inside to the dmz.
The benefit of 1 is if hosts on the DMZ need to initiate connections to hosts on the inside. Doesn't look like it from your ACL 201.
2 translates addresses of inside machines to an address on the DMZ.
3 does not translate the addresses at all.
So, whichever way you prefer, remove the other 2 and clear the xlates and try again and let us know.
Please post some show statements if you reply back with problems:
1) show access-group
2) show access-list
3) show xlate
4) show global
5) show nat
6) show static
This will let us see what is exactly happenining from the Pix's perspective. Remove whatever parts you need to.
thanks
peter
The entry for number 3 access-list nonat permit ip 10.0.0.0 255.255.255.0 10.0.15.0 255.255.255.0
nat (inside) 0 access-list nonat I had tried at one time but removed. I also remove entry 1 and then cleared xlate and still no go. I cannot ping the outside address from inside or bring up the browser with that address. I can put the natted address in the browser and bring up the site but not the public address. Here is the result from the show commands.
1. show access-group
2. show access-list
access-list 101 permit tcp any host 206.x.x.175 eq www (hitcnt=12)
access-list 201 permit icmp any any (hitcnt=232625)
access-list 201 permit icmp any 10.0.0.0 255.255.255.0 (hitcnt=0)
access-list 201 permit tcp 10.0.15.0 255.255.255.0 any eq www (hitcnt=0)
access-list 201 permit tcp 10.0.15.0 255.255.255.0 any eq domain (hitcnt=0)
access-list 201 permit udp 10.0.15.0 255.255.255.0 any eq domain (hitcnt=1)
access-list 201 permit tcp any host 10.0.15.175 eq www (hitcnt=0)
3.show xlate
Global 206.x.x.175 Local 10.0.15.175
4. show global
5. show nat
6. show static
Hey lmbaity -
I am sorry - I thought I had replied to your last post. Seems like something is mixed up with the system for your post. Thanks for the show commands - they are really helpful.
So here's the order I will check things and my thoughts:
1 - Interface config check
good
2 - Interface enabled check
good
3 - Interface ip config check
good
4 - Translations for Inside to Outside
NAT with PAT - good
First 4 connections to outside will be translated to 132,133,134 and then 135. The 5th+ connetions will be translated to 131.
5 - Translations from Inside to DMZ check
and
This may be the problem
You have both dynamic NAT and static NAT configured for translations of addresses for traffic from the inside to the dmz. You may want to use on or the other.
Even though I think this could be tweaked, I don't think it is the issue, so let's keep looking.
6 - Translations from the Dmz to the Outside check
good - same comments as in 4
7 - Translations for traffic from Outside to DMZ
good
8 - Access Lists applied to any interface check
ok
9 - Let's check the ACLs for any issues
good - allows WWW traffic inbound
getting hits on it, too
the above statements permit your DMZ servers to get to any website and resolve DNS
I don't think these 2 statements are needed - but should not be impacting things right now
this looks good, if you are using internal DNS. Notice you have no hits probably because no DNS resolution can occur because the ACL blocks it. Tell us more about how you are doing DNS for internal hosts.
10 - Let's wrap this up by checking routing
looks good
Take a look at #9 and tell us more about your DNS.
thanks
peter
I did remove the line static (inside,dmz) 10.0.0.0 10.0.0.0 netmask 255.255.255.0 and clear xlate. For our public dns registrations we use our isp, it makes it alot easier. I do allow from access-list 301 udp 53 out. We have no problem accessing any type of sites from the inside. For this problem I am not even using a fqdn just an IP address that I would type in the browser or try to ping to eliminate dns problems. So from the inside I can ping the translated public ip but not the untranslated. From another isp I can ping the public IP and browse the IP address for my test website in our dmz. I have set up pixes in the past but only with conduits, the acl change has made it interesting. Is thier anything I am missing?
